LinkBack (2) Thread Tools Display Modes
Old 04-05-2008, 02:25 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
JGuru's Avatar
Thumbs up Fine-tuning FireFox : Tips, tricks & tweaks!!!
Fine-tuning FireFox : Tips, tricks & tweaks:
Here I'll present the tips, tricks, tweaks for FireFox browser. You can apply these tricks on Firefox
running in any platform - Linux, Windows, Mac etc.,
Type about:config in the textfield where you type the URL like www.yahoo.com, www.google.com etc.,
press Enter key.
You'll now see a "Filter" label, followed by a textfield. Whatever changes you want to make, you can type
the 'first-word.second-word' .For eg., type : network.http in the filter textfield, Firefox will
list all Preferences Name in Tabular format. Also note that now Firefox only lists those Preference names
that start with "network.http". So Firefox has filtered only those Preference names that start with
"network.http".
Let's move on to the next step. We need to change the values of the Preference names, so that we can tweak
FireFox as per our needs. There are three data types - 'String' , 'integer' and 'boolean'.
To change a String data type, select it , right-click, from the Popup dialog select 'Modify'. Now enter
the new String value , click on 'OK' button. For eg., Select network.http.version from the Table,
right-click select 'Modify'. Now a dialog box that appears "Enter string value". Type a new value you
want to set.Click on 'OK' to make the changes, or 'Cancel' to discard the changes you have made.
To modify an 'integer' value, select the row in the table like network.http.max-connections,
right-click , select 'Modify', now enter a new value you want to set. The last data-type is 'boolean'
A boolean data-type has only two states 'true' and 'false' (ie., On & Off). To change a boolean data type,
select the row from the table, right-click select 'Toggle' If the previous value is 'true' ,it changes
to 'false' after toggling and vice-versa.
Now let's get started. I'll be listing topic-wise on what changes to make in Firefox.
Load web pages faster: Speed-up Firefox:
"Broadband : 128kbps to 512 kbps"
network.http.max-connections -> 28
network.http.max-connections-per-server -> 16
network.http.max-persistent-connections-per-proxy -> 16
network.http.max-persistent-connections-per-server -> 16
network.http.pipelining -> true
network.http.pipelining.maxrequests -> 24
network.http.proxy.pipelining -> true
network.http.redirection-limit -> 8
network.http.request.max-start-delay -> 0
"Broadband : > 512 kbps"
network.http.max-connections -> 48
network.http.max-connections-per-server -> 24
network.http.max-persistent-connections-per-proxy -> 24
network.http.max-persistent-connections-per-server -> 24
network.http.pipelining.maxrequests -> 32
Reduce Memory Usage:
Firefox caches the data that it fetches from the webpages. There are two types of cache :
a) disk cache
b) memory cache
To view the cache type: about:cache
Disk cache speeds up loading of webpages since FireFox already has the Images, Flash & other
media types stored in the disk. So it will load only the new changes in the webpage & rest
it will load from the disk cache. So we'll leave disk-cache as it is.
As far as Memory Cache is concerned, it also speeds things up like faster loading of webpages,
but at the cost of memory!!! So if you browse lots of webpages with high-resolution Images & media,
Firefox slowly eats up memory & more memory until the O.S itself crawls to it's knees!!!
System becomes very slow, there is solution but to reboot the System or free memory using some
software. To reduce memory usage of Firefox, change the following Preference name value.
browser.cache.memory.enable -> false
Force Firefox to open the link in the same Window:
browser.link.open_newwindow -> 1
This also reduces memory usage considerably. If Firefox opens up new Window(forced to).It will
consume more memory & also it makes it difficult to switch between a pile of Windows!!!
Block Annoying Image Ads:
permissions.default.image -> 3
NOTE: If the Image Ad originates from a different website then it will be blocked.
If it is from the same website, it won't be blocked!!
You can also install Firefox extensions like 'Adblock', 'Adblock Plus', 'ImgLikeOpera', 'BlockSite' etc.,
Enable Auto-completion:
By enabling auto-completion ,you need not type the entire URL of the website.Just start typing a few
characters, Firefox will complete the rest!!!
browser.urlbar.autoFill -> true
Enable Spell-checking:
spellchecker.dictionary -> en_US
Increase Font-size:
If you viewing a webpage in a 17" monitor or higher then you'll notice that the fonts are so small.It's becomes
difficult to read webpages!! One way to overcome this is by : From the Firefox menu "View"-> "Text Size"->" Increase"
or "Ctrl++" But these changes won't persist!!! To overcome this, from the menu "Edit" -> "Preferences"
From the "FireFox Preferences" dialog, click on the tab 'Content' In 'Font & Colors' click on 'Advanced'
This opens up the "Fonts" dialog. Here next to label 'Monospace', set the 'Size' as '14' and also set the
'Mimimum font size' as '14'. Click on 'OK' button.
Get rid of annoying security dialogs:
Every time when you login to webpage like GMail, Yahoo, HotMail Banking sites & other Secure sites, Firefox displays
a annoying warning dialog "You are entering a secure site", "You are leaving a secure site" & so on.To get rid
of these irritants, do the following:
security.warn_entering_secure -> false
security.warn_entering_secure.show_once -> false
security.warn_entering_weak -> false
security.warn_entering_weak.show_once -> false
security.warn_leaving_secure -> false
security.warn_leaving_secure.show_once -> false
security.warn_submit_insecure -> false
security.warn_submit_insecure.show_once -> false
security.warn_viewing_mixed -> false
security.warn_viewing_mixed.show_once -> false
To view the Plugins installed:
Type aboutlugins
NOTE: Apply these changes , you need to 'Quit' Firefox & restart it.
Happy Surfing!!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 04-05-2008, 07:58 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Fine-tuning FireFox : Tips, tricks & tweaks!!!
Very nice attempt mate. Good work.
I have also posted a few tricks for Firefox at following link:
Mozilla Firefox Tweaks
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 04-05-2008, 08:27 PM   #3 (permalink)
JGuru's Avatar
Thanks for your review @Vishal. We all know that @Vishal is a "Registry & System"
fine-tuning expert in Windows. Ok, I'll checkout your webpage.
-Albert Einstein
JGuru is offline
Old 04-05-2008, 08:37 PM   #4 (permalink)
^^lool
Faun is offline
Old 04-05-2008, 08:43 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
Good post.
no offense meant but i knew most of the tricks
Still it will help the newbies.
Here my Contribution for a bug workaround:
In Firefox 3 Beta5(default broswer in Ubuntu)
BUG: excessive CPU usage and disk I/O
Problem: Browsing with Firefox 3.0b5 on Hardy leads to excessive CPU usage and disk I/O. The high CPU usage makes browsing very jerky - switching tabs takes more time than it should, pages appear frozen for a brief moment
Workarounds:
1) remove FF3 beta & install FF2(Recommended, see below for exact procedure )
2) Delete urlclassifier3.sqlite file in your profile & restart FF3
3) Reduce Cache Size
Bugzilla@Mozilla – Bug 430530
Bug #215728 in firefox-3.0 (Ubuntu)
This sounds like a Linux only problem, still Windows users please confirm
[Howto] Remove Firefox 3 Beta5 in Ubuntu 8.04 & install Firefox 2(stable)
Open terminal(Applications->Accessories)
sudo apt-get remove firefox-3.0
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install firefox-2
gary4gar is offline
Old 04-05-2008, 09:04 PM   #6 (permalink)
Beneath The Eyelids
The Outsider's Avatar
its good to see you back JGuru, nice tips nonetheless.
The Outsider is offline
Old 04-05-2008, 09:13 PM   #7 (permalink)
sudo apt-get update
there is also an option in add/remove
Btw I kinda like FF3, so dont really want to uninstall it, will try to reduce the cache size
or
any good workaround ?
Faun is offline
Old 04-05-2008, 09:22 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
The Fix was out yesterday itself. 3rd may
so you want install the latest via cvs repos of mozilla
gary4gar is offline
Old 06-05-2008, 03:27 PM   #9 (permalink)
JGuru's Avatar
Be brave & patient when using Products (in Beta state), If you want a stable version,
wait for some time until the annoying bugs are fixed or use the older version of
the product.
-Albert Einstein
JGuru is offline
Old 06-05-2008, 05:14 PM   #10 (permalink)
The Devil's Advocate
iMav's Avatar
[offtopic]Twitter habit?[/offtopic]
http://beingmanan.com
iMav is offline
Old 08-05-2008, 02:35 PM   #11 (permalink)
JGuru's Avatar
For an Indepth, Complete, Comprehensive, detailed Analysis of about:config
options in FireFox , checkout this link :
http://kb.mozillazine.org/Firefox_:_...config_Entries
-Albert Einstein
JGuru is offline
Old 08-05-2008, 02:35 PM   #12 (permalink)
left this forum longback
praka123's Avatar
using ff3 for few months.I hate its annoying db updates every 5-6 mins(sqlite?) .
praka123 is offline
Old 08-05-2008, 02:37 PM   #13 (permalink)
JGuru's Avatar
@Prakash, Then, why don't you switch to FireFox 2?
-Albert Einstein
JGuru is offline
Old 08-05-2008, 02:42 PM   #14 (permalink)
GaurishSharma.com
gary4gar's Avatar
then this post it written only for you
gary4gar is offline
Old 08-05-2008, 03:00 PM   #15 (permalink)
praka123's Avatar
^hey @gori,thank you
praka123 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/86996-fine-tuning-firefox-tips-tricks-tweaks.html
Firefox Browser - Making it even faster! - TeenDreams Member Forum This thread Refback 08-10-2011 01:47 PM
Firefox Browser - Making it even faster! - TeenDreams Member Forum This thread Refback 20-08-2010 11:19 PM
All About Wordpress - Themes, Plugins, Tips and Tweaks DigitalDude Software Q&A 329 01-06-2009 03:26 PM
CS 1.6 Tips and Tricks BULLZI Gamerz 38 22-12-2008 08:05 AM
All Vista Tips and Tweaks in here!!! rakeshishere Tutorials 5 11-02-2007 10:59 AM
Confusion about Oct 06 Tips & Tweaks aritrap Mobiles and Tablets 3 10-10-2006 10:09 PM
Firefox Tips-n-Tricks / Tweaks / Secrets / Codes etc. Vishal Gupta Tutorials 10 30-07-2005 07:04 PM
- by soumya
