Old 02-05-2008, 10:52 PM   #1 (permalink)
Dark Star's Avatar
Default Mandriva Boot problem..
Hi
Till I get my hands on Mandriva Spring and Hardy.. I want a temporary OS . So I use madriva 08 free edition. the problem is. When I boot normally I had black/grey sccreen after the Boot Splash finishes.. It never went to the Log-In GDM/KDM Screen. To reach there i had to bot into Safe Mode and moving further by pressing CTRL+D
how can I boot from Normal; Mode ? Is it some VGA problem ?
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 03-05-2008, 04:52 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Mandriva Boot problem..
seems to me a resolution problem.what is the resolution you need?
praka123 is offline
Old 03-05-2008, 06:48 AM   #3 (permalink)
Dark Star's Avatar
^^Resolution :S .. It doesn't even reach GDM screen when I boot via Normal Mode.. But I can acess mandriva when I boot via Safe Mode & CTRL +D/
Old 03-05-2008, 06:56 AM   #4 (permalink)
praka123's Avatar
^yeah,thats what I asked!when xorg.conf got a higher resolution set by the distro,what else can u expect?eh?it wont reach gdm
so remove the unwanted resolutions from /etc/X11/xorg.conf and then try again!
praka123 is offline
Old 03-05-2008, 08:24 AM   #5 (permalink)
Dark Star's Avatar
No .. nothing happened.. Here is my Xorg.conf.. I have removed the extra reso.. So this is the edited .conf fiile..
# File generated by XFdrake (rev 230776)
Section "Extensions"
    Option "Composite"
EndSection
# Refer to the xorg.conf man page for details about the format of
# this file.
Section "ServerFlags"
    #DontZap # disable <Ctrl><Alt><BS> (server abort)
    #DontZoom # disable <Ctrl><Alt><KP_+>/<KP_-> (resolution switching)
    AllowMouseOpenFail # allows the server to start up even if the mouse does not work
EndSection
Section "Module"
    Load "dbe" # Double-Buffering Extension
    Load "v4l" # Video for Linux
    Load "extmod"
    Load "type1"
    Load "freetype"
    Load "glx" # 3D layer
    Load "dri" # direct rendering
EndSection
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "kbd"
    Option "XkbModel" "pc105"
    Option "XkbLayout" "us"
    Option "XkbOptions" "compose:rwin"
EndSection
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol" "ExplorerPS/2"
    Option "Device" "/dev/mouse"
EndSection
Section "Monitor"
    Identifier "monitor1"
    VendorName "Plug'n Play"
    ModelName "T710BH "
    HorizSync 30-71
    VertRefresh 50-160
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
EndSection
Section "Device"
    Identifier "device1"
    VendorName "Intel Corporation"
    BoardName "Intel 810 and later"
    Driver "intel"
    Option "DPMS"
    Option "XaaNoOffscreenPixmaps" "1"
EndSection
Section "Screen"
    Identifier "screen1"
    Device "device1"
    Monitor "monitor1"
    DefaultColorDepth 24
    Subsection "Display"
        Depth 8
        Modes "1280x1024"
    EndSubsection
        Depth 15
        Modes "1280x1024"
    EndSubsection
        Depth 16
        Modes "1280x1024"
    EndSubsection
        Depth 24
        Modes "1280x1024"
    EndSubsection
EndSection
Section "ServerLayout"
    Identifier "layout1"
    InputDevice "Keyboard1" "CoreKeyboard"
    InputDevice "Mouse1" "CorePointer"
    Screen "screen1"
EndSection
Old 03-05-2008, 08:29 AM   #6 (permalink)
try to remove the subsection containing Depth 24 line
Faun is offline
Old 03-05-2008, 08:35 AM   #7 (permalink)
Dark Star's Avatar
Edit : It worked .. I mean removing the resolution. .there was some problem with /etc/fstab Lemme see if it works perfectly
Old 03-05-2008, 10:20 PM   #8 (permalink)
Dark Star's Avatar
Still not fixed: | Well lets see this error vanishes with 2008.1
Old 04-05-2008, 12:22 AM   #9 (permalink)
Pat
Member of Apple Family
Pat's Avatar
I never got Mandriva 2008 to work on my lappy! It was probably an issue with display but I never bothered to find out! 2008.1 worked fine though! One thing you could try on 2008 is selecting VESA drivers instead of ati or nv that must have been enabled by default! Anyways good luck..
P.S: Mandriva , even with the spring version, is not good enough to compete with hardy IMO
Pat is offline
Old 06-05-2008, 11:21 PM   #10 (permalink)
Dark Star's Avatar
Nothing.. Didn't worked.. .
Old 07-05-2008, 12:00 AM   #11 (permalink)
18 Till I Die............
Check for errors in Xorg.0.log are there any? They can be found by lines starting with EE
http://www.bash.org/?258908
mehulved is offline
Removable drive problem in Mandriva 08! Dumbledore Open Source 3 25-01-2008 09:37 AM
problem with root login in mandriva sarincv Open Source 20 29-11-2006 08:17 AM
MANDRIVA LINUX 2007 Instalation PROBLEM caleb Open Source 8 29-11-2006 06:22 AM
Problem with Mandriva 2006 plsoft Open Source 18 10-08-2006 10:44 PM
- by soumya
