Old 30-04-2008, 05:08 PM   #1 (permalink)
saurabh.sauron's Avatar
Default Strange Problem in Audacity and XMMS
I am using Ubuntu 7.04 and facing a strange problem in audacity and XMMS. I cant see the menu items properly. Audacity doesnt even work properly. I am posting the screenshots.
pls help
thnx
saurabh.sauron is offline
Old 30-04-2008, 08:03 PM   #2 (permalink)
anarchist
Posts: n/a
Default Re: Strange Problem in Audacity and XMMS
i was having similar problem in 2006 in Xmms. here are similar thread, which may help you:
http://ubuntuforums.org/showthread.php?t=627522
http://ubuntuforums.org/showthread.php?t=606133
now i am using audacious, without any problems.
Old 30-04-2008, 09:40 PM   #3 (permalink)
still doesnt work at all. the menus look as bad as ever. BTW, Audacity is not able to either record or even play. pls help.
Old 01-05-2008, 04:40 AM   #4 (permalink)
left this forum longback
praka123's Avatar
ditch xmms.it uses obsolete gtk1.2 .it is pretty hard to fix gtk1.2 annoyances.
use beep media player or audacious(both are better!).
praka123 is offline
Old 01-05-2008, 09:35 AM   #5 (permalink)
Married!
Rahim's Avatar
Audacious is slick.
As for Audacity try changing your Language to English US [System>Admin>Language Support]
The solution is similar, i just dont remember it, just change the language
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 01-05-2008, 10:05 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes changing the locale from en_IN.UTF-8 to en_US.UTF-8 helped for Audacity once for me.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-05-2008, 10:13 AM   #7 (permalink)
Proud to be Linux
abhinandh's Avatar
me too got that problem once.changing language to english(us) solved it.
http://abhinandh.com
abhinandh is offline
Old 01-05-2008, 03:21 PM   #8 (permalink)
i dont know, but it became all right now. i did what anarchist said but didnt work then but it's working now. thnx
i still cant record anything in audacity. pls throw some light on that too.
thnx
Old 01-05-2008, 04:26 PM   #9 (permalink)
Commander in Chief
Mic Capture switch is turned on in volume-properties applet / alsaconfig ? Also enable Mic boost of +20db if your mic is weak.
Harsh J
www.harshj.com
xmms Display problem. vish786 Open Source 5 18-08-2007 12:15 AM
xmms player problem vish786 Open Source 1 20-05-2007 01:34 PM
Audacity and MP3 desertwind Open Source 17 29-07-2005 05:24 PM
problem with xmms surdy Open Source 19 04-04-2005 10:16 AM
- by soumya
