Old 16-04-2008, 11:01 AM   #1 (permalink)
Default Problem with Ubuntu!
Hi
I have compaq presario v3225au laptop. I installed 64 bit ubuntu 7.10 last week and it rocks. But I have few questions.
1. Sound does not work all time : First 2 bootups my sound did not work. I did a google search and came up with couple of tutorials. I checked everything. and all drivers etc were fine but no ound.
then in the third boot. Sound worked. I have no idea how it worked. The I used the automatic updated manager and installed some updates. Then after the restart sound was still OK. But yesterday sound stopped working. Any idea why this funny behaviour?? Please help!
2. Earlier I used to try different version of linux (along with windows) and when I want to rempve Linux, what I do is delete the partion, which has linux, usinf disk management in Windows.
and it worked fine.
now I want to do the other way round. I had windiows installed earlier. now I have bothe Win and Ubuntu. I want to remove Windows.
Can I do this by booting into ubuntu and formatting the drive which has windows installation. Will this work??
Shoban
http://curlit.in : URL Shortener
My tech blog : http://www.crankup.net
shobankr is offline
Old 16-04-2008, 11:15 AM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: Problem with Ubuntu!
1. What sound card do you have?
If you are not sure, then post the output of lspci.
2. Yep, format the partition, and remove its entry from Grub.
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 16-04-2008, 11:58 AM   #3 (permalink)
Thanks for the repliy. I am not sure about the card .. I think its Nvidia.
shobankr is offline
Old 16-04-2008, 12:03 PM   #4 (permalink)
Think Zen.
ray|raven's Avatar
^Eh? Nvidia makes soundcards? Since when?
Old 16-04-2008, 12:11 PM   #5 (permalink)
I am not completely sure.... it has Nvidia grahics card!
and i shows nvidia in the list of devices (sound)
I will let u know when I get home today!
shobankr is offline
Old 16-04-2008, 03:30 PM   #6 (permalink)
Pat
Member of Apple Family
Pat's Avatar
I have a similar lappy and believe me its the sound drivers..Last time I checked Ubuntu forums (2 months back), there were a couple of tutorials to get the sound working but none of them worked flawlessly..
Btw, the sound card is Intel HDA Audio..I have heard that if you use pulseaudio, then the audio may work as expected..
Also I have observed that sound works everytime you cold boot your laptop..I mean powering it on and starting linux (and not rebooting after starting xp for the first time or linux)
Pat is offline
Old 16-04-2008, 03:43 PM   #7 (permalink)
Thanks pat,
The processor is AMD 64 bit... I will check out pulse audio.
shobankr is offline
Old 16-04-2008, 05:20 PM   #8 (permalink)
Proud to be Linux
abhinandh's Avatar
wierd....my intel hda audio is working fine.
http://abhinandh.com
abhinandh is offline
Old 16-04-2008, 07:36 PM   #9 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
My Realtek HDA was a disaster. But then again I was using Ubuntu 64 bit.
My experiences and the methods I used and whatever links I mustered up can be found here.
http://www.filledvoid.com/2007/12/11/7/
FilledVoid is offline
Old 16-04-2008, 07:48 PM   #10 (permalink)
Pat this is right.. My sound worked when I booted directly into Ubuntu.
Any one has any idea how to solve this?
shobankr is offline
Old 16-04-2008, 11:48 PM   #11 (permalink)
in search of myself
CadCrazy's Avatar
I used this method to get sound working on My Dell 1720. But still volume level is very slow. Better wait for Ubuntu 8.04. It has pulse audio. I tried Hardy Alfa once and sound was perfectly working without applying any patch. Although volume level was still below my expectation.
CadCrazy is offline
Old 17-04-2008, 12:03 AM   #12 (permalink)
left this forum longback
praka123's Avatar
Why dont install pulseaudio now?It isnt tough.just install all the packages(not necessary though).
well,below link explains fine
https://wiki.ubuntu.com/PulseAudio
also,@Pat:I think you should try building hda drivers into kernel and try! rather than building as modules.
ie,build a kernel with ALSA.(no modules for sound)
praka123 is offline
Old 17-04-2008, 12:11 AM   #13 (permalink)
Paraka how do you do that? Is it simple because I am not an exper in Linux
Sugest me some good audioplayers.. which one is better XMMS or songbird?
shobankr is offline
Old 17-04-2008, 12:22 AM   #14 (permalink)
praka123's Avatar
^try the link I provided.
exaile,rhythmbox,beep-media-player(winamp look-a-like) are good.
praka123 is offline
Old 17-04-2008, 07:45 AM   #15 (permalink)
anarchist
Posts: n/a
^ you forgot Audacious, it is available in ubuntu repositories and XMMS skins can be used.
Old 17-04-2008, 09:56 AM   #16 (permalink)
Thanks Friends.. let me try them out!
shobankr is offline
Ubuntu Problem Ecko Open Source 9 08-03-2008 11:09 PM
Ubuntu Problem adi007 Open Source 46 18-11-2007 10:20 PM
problem in ubuntu 7.04 for PC hrushij Open Source 5 19-06-2007 08:55 AM
Ubuntu + AMD problem shivkumar Open Source 3 12-11-2006 05:58 PM
problem with ubuntu shivi4 Open Source 4 09-05-2006 11:13 AM
- by soumya
