Old 18-04-2005, 07:23 PM   #1 (permalink)
Default Help Reqd:Redhat installation on SATA HDD
Hi All,
I bought a new pc with the following configuration
AMD 64bit 3000+
MSI RS480M2( Phoenix Bios)
Seagate 120GB SATA Hdd.
I intend to install linux onto it...
I tried installing various Redhat flavours RH9,FC1,PCQLinux2k5 ..
All those installers failed to recognize my harddisk..
The error says that it could not detect any harddisk attached to the system...
i checked thro google..but couldnot find any appropriate solution...i saw some posts suggesting legacy Parallel ATA selection but i could not find that option in my BIOS.
Please Help me in resolving this issue..
i badly want to install Linux in my PC
yarapavan is offline
Old 18-04-2005, 07:40 PM   #2 (permalink)
cool_dude_prav's Avatar
Why not go for Ubuntu!! Presumably the best one out there according to Distro Watch
It surely supports SATA disks!!!
A SATA Discussion
The Bloglines of an Angry Indian -
www.angry-indian.com
If only life were as easy as Ctrl+Z (undo) and F4/Ctrl+Y (redo)...
cool_dude_prav is offline
Old 18-04-2005, 07:54 PM   #3 (permalink)
Its quite strange FC should recognise your HDD it did in my case i hava a 865 with dual 160G sata. Please tell us more about the partitions and is it a dual boot setup that you are trying ? do you have an ide drive also.
**** happens
pradeep_chauhan is offline
Old 19-04-2005, 01:01 PM   #4 (permalink)
hi prav,
thanx for the reply
i do not have ubuntu with me..
And Pradeep,
i got 3 partitions with my HDD.
yes it is a dual boot machine that i am trying to set up with winxp
I do not have any ide drive
Old 19-04-2005, 01:34 PM   #5 (permalink)
In the bios disable the IDE controller(one not being used for CDrom etc) and set the OS type as plug and play. Please try now and see.
**** happens
Old 19-04-2005, 04:38 PM   #6 (permalink)
Hi Pradeep,
Thanx for the info..
But the problem still continues..
may be i should look at knoppix or any other live cd that can autodetect my SATA
harddisk..?
Old 19-04-2005, 09:49 PM   #7 (permalink)
Yes my friend is facing the same problem,
as i hv installed FC3 in mine on SATA 80GB, worked fine for me but didn`t worked in his system,
Live distro is supported check it out,
even if u hv some previous distro then it should recognise, just first installation can`t be linux(* in my friend case atleast.)
Music is like Sex, The more you get, the more you want.
demoninside is offline
- by soumya
