I can help u may be
In fedora,u can use system-config-network to make the connection.
still,
try this if u r on bridge mode(ie,u dial from ur window$ system to get connected).
open a terminal,
run
"su -"
give root's passwd.
run /sbin/pppoe-setup.
once finished,use as root(# prompt) "pppoe-connect &" to get connected.
another way,
press ALT+F2 to get run box.inside type.
gksu gedit /etc/ppp/peers/internet
It open gedit editor the file "internet"
copy below lines to it:-
noipdefault
defaultroute
hide-password
#lcp-echo-interval 30
#lcp-echo-failure 4
noauth
persist
#mtu 1492
usepeerdns
plugin rp-pppoe.so eth0
user "urusername"
save and exit.remember to give ur broadband username in between the quote(boldletters).
now again open run dialog box(ALT+F2).
run:-
gksu gedit /etc/ppp/chap-secrets
then give ur username and passwd in below format
"urusername" * "urpasswd"
save and exit.(* is there!).
now make sure ur lan card is detected(see /sbin/ifconfig output for eth0 and lo interfaces).
now as root(# prompt use "su" to achieve)
dial
will hopefully connect.
if it cannot,do as below:-
route add default ppp0
to disconnect,use
try this only if above method(pppoe-setup) doesnot work!
