Old 09-04-2008, 09:31 AM   #1 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Basic Debian Questions
If I was considering to install Debian . I'm guessing that I should be installing Debian Etch. However what scares me is that all the packages seem to be prehistoric . An example.
Openoffice.org in Etch = 2.0.4
Actual Version available = 2.4.0
How difficult is upgrading your applications to the right versions. Should I be trying out Lenny instead. It says testing so I am sort of hesitant of trying it on it. PS. Any knowledge about the 64 bit version?
Thanks in advance.
FilledVoid is offline
Old 09-04-2008, 09:52 AM   #2 (permalink)
Proud to be Linux
abhinandh's Avatar
Default Re: Basic Debian Questions
You should be trying lenny or sid.Etch is the stable version.(outdated packages)
lenny is more stable than sid.
http://abhinandh.com
abhinandh is offline
Old 09-04-2008, 11:04 AM   #3 (permalink)
Try debian lenny netinst cd (145MB). It will install base system.
Then just sudo aptitude xorg (67MB)
and to install desktop manager
sudo apttitude install gnome-core (200+MB)
That would be a minimum install, a breeze fast desktop experienc.
Though packages are a bit old but that doesnt break the fun.
Afterall you can add to the sources.list the ubstable repos to get the latest (but its prone to break ur system).
sources.lst file is attached here, just copy paste it to the directory /etc/X11/
after base system install
File Type: zip sources.zip (364 Bytes, 0 views)
Faun is online now
Old 09-04-2008, 08:29 PM   #4 (permalink)
FilledVoid's Avatar
Well I doubt I can download all that unless I stay up and do it on my free time . However I'm also looking for the DVD so it might ease off some of the downloads I need.
Old 09-04-2008, 08:55 PM   #5 (permalink)
18 Till I Die............
Not much more than you're prone to breakage in ubuntu.
http://www.bash.org/?258908
mehulved is offline
Old 09-04-2008, 10:50 PM   #6 (permalink)
^^atleast Ubuntu used to boot in IDE emulation mode but for Debian I had to use AHCI emulation and then gave generic.all_generic_ide=1 boot parametr.
But I enjoy Debian more than Ubuntu, No more Oo-boon-tu now, only The-bee-yen . I have learned a lot while configuring the sh!t out of it.
On 500NU it takes only 1hour to get a clean graphical desktop
And the advantage comes later, if u want to install again on another desktop, copy the debs in /var/cache/apt/archives to a pen drive and paste to the new installation, just edit the sources.list to the one in installed system.
connect to net and it will ask u for only a bit of MBs to download (15-20MB), if any.
Else there are 21CDs or 5DVDs in total to burn, choose what u like
http://cdimage.debian.org/cdimage/we.../i386/iso-dvd/
Faun is online now
Old 09-04-2008, 11:59 PM   #7 (permalink)
FilledVoid's Avatar
Thanks for the info. Although my page for usage on BSNL says its a home 500 now and shows free usage I want to get the first bill after change before I start doing this. The last thing I need to have is a bloated phone bill
Old 10-04-2008, 12:57 AM   #8 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^OMFG,do I smell a pussy here?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 10-04-2008, 01:13 AM   #9 (permalink)
FilledVoid's Avatar
Your informative post lacks content, quality or any kind of resemblance to sanity in the least. I have two words for you. You Fail!. So basically, screw you and the horse you rode in on.
Thanks.
Old 10-04-2008, 01:25 AM   #10 (permalink)
Thanks.
NP,anything for you.
Old 10-04-2008, 04:25 PM   #11 (permalink)
left this forum longback
praka123's Avatar
Debian Lenny @biju.it have newer packages.
While,I use Debian Sid which is a daily 10-30mb+ updates
My bet is,you should stick with Debian Lenny if u dont have fast net connxn.it is easy to install
also,Lenny got a gfxical installer along with classic curses based installer.
else,use apt-pinning to get needed package's latest version from Sid or experimental repositories
here is a sources.list db:http://tuxicity.wordpress.com/my-sou...bian-lennysid/
praka123 is offline
Old 10-04-2008, 07:37 PM   #12 (permalink)
FilledVoid's Avatar
Prakash you have Debian Lenny for 64 bit at home ?
Old 10-04-2008, 07:40 PM   #13 (permalink)
praka123's Avatar
NO! have to download
praka123 is offline
Have some basic questions about processor and SLI debsuvra CPU / Motherboards 6 19-11-2007 02:25 AM
How many are Using Debian and derviatives praka123 Open Source 62 25-01-2006 09:50 PM
Debian ? vandit QnA (read only) 6 19-08-2005 07:41 PM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
All Basic Linux Questions /Faq/Doubts whatever klinux Open Source 7 15-02-2005 11:42 PM
