Old 04-04-2008, 11:55 AM   #1 (permalink)
heartripple's Avatar
Smile help to install OPEN SUSE 10.3
hi i am new to LINUX and i am trying to install OPEN SUSE 10.3 so pls help me
thanks in advance
heartripple is offline
Old 04-04-2008, 12:12 PM   #2 (permalink)
Wanna be *****ised...
jithudigitised's Avatar
Default Re: help to install OPEN SUSE 10.3
please post this thread on the relevant section.post it in the Open Source section.
thread reported for changing the section
and what is your problem exactly.anywhere u stuck while installing the suse 10.3
JAI HIND
free ur mind,free ur soul,use free softwares and live freely in the most free country in the world.
JITHIN
jithudigitised is offline
Old 04-04-2008, 12:19 PM   #3 (permalink)
Linux Learner
PcEnthu's Avatar
Head here for all OpenSUSE installation queries. They have neatly organised all possible installation methods with step-by-step guides for those methods.
BTW, PM any Mod to move this thread to the Open Source section, where you will get more supoort
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 04-04-2008, 12:49 PM   #4 (permalink)
Juke Box Hero
Moved to the proper section so your thread will receive the attention it deserves.
Hitboxx is offline
Old 04-04-2008, 12:58 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
state your system configuration
state your hard disc partitions
state your experience level(I know its propably clueless newbie)
I think NucleusKore will be the best guy in this forum who can help a newbie switch to OpenSuSE.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 04-04-2008, 02:43 PM   #6 (permalink)
Cool Re: help to install OPEN SUSE 10.3
My PC cofigration is :
AMD ATHLON 64 x 2 4200
ASUS M2N-MX
1 GB DDR 2 667 Mhz
320 GB WESTERN DIGITAL HDD
SONY DRU 170 AW DVD writer
i have a prtition named d with 30 gb space
and when i chosed the option to install open SUSE 10.3 process started but after extrecting some file black colored balnk screen appears and after that nothing happens
finaly i am newbie in the world of LINUX i also requsted UBUNTU 7.10 CD from SHIPIT.UBUNTU.COM but i wanted to install some kind of LINUX on my pc till i get the UBUNTU CD
sorry for this,i hope guys you will help me
Old 04-04-2008, 02:51 PM   #7 (permalink)
check the OpenSUSE cd, may be damaged
what all other operating systems are installed ?
and what is the partition layout of your drive ?
Faun is online now
Old 04-04-2008, 02:53 PM   #8 (permalink)
i think its working fine it is the dvd from DIGIT november 2007
i am using windows xp sp 2 and all of my prtition is in NTFS format
Old 04-04-2008, 03:18 PM   #9 (permalink)
could u please elucidate what exactly u did, to where the installation reached and then went kaput
Faun is online now
Old 04-04-2008, 03:37 PM   #10 (permalink)
Smile Re: help to install OPEN SUSE 10.3
i chosed the second option which shows INSTALLATION and after that it extrcted the kernel file it shows black colored balnk screen appears and after that nothing happens
Old 04-04-2008, 03:39 PM   #11 (permalink)
try seeing the output in other terminals
press
ALT + F(1-6)
And see where the processing stopped
Faun is online now
Old 04-04-2008, 03:45 PM   #12 (permalink)
what do u want to say i dont understand
Old 04-04-2008, 03:56 PM   #13 (permalink)
press
ALT + F1 key after u see the blank screen
and try from F1 to F6 to see if any of the virtual terminal logs the processing.
ALT + F1 brings up virtual terminal 1.
Faun is online now
Old 04-04-2008, 05:45 PM   #14 (permalink)
Console Junkie
aditya.shevade's Avatar
if you are saying that the nothing is displyed on the screen after you go to installation then select the correct resolution at boot before you start with instllation.
In the boot screen, there is option to change screen resolution, F3 I think.
I had the same problem and it was solved by changing the resolution.
--- Console Junkie
aditya.shevade is online now
Old 04-04-2008, 08:29 PM   #15 (permalink)
i am using 1024 x 768 resolution with my onboard grafics nvidia geforce 6100 nforce 430
Old 04-04-2008, 08:32 PM   #16 (permalink)
left this forum longback
praka123's Avatar
you may have to edit /etc/X11/xorg.conf if driver are not bundled
praka123 is offline
Old 04-04-2008, 08:41 PM   #17 (permalink)
how to edit that sorry i am newbie at LINUX
press
now i am trying your trick so will here after some time stay tuned
and thanks to all of you
Old 04-04-2008, 08:45 PM   #18 (permalink)
TheSaint
NucleusKore's Avatar
I have the same board. You do not have to edit anything
You have to go to other options at boot, then add the extra words
noapic
then press enter
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 04-04-2008, 09:10 PM   #19 (permalink)
i have seen that there are so many commands from f1 to f6 and on f6 i saw no video driver what's that
nothing is seems to working for me i tried every functions key after blank screen but its not working and i also tried with noapic but it also displays the blank screen
Old 04-04-2008, 09:26 PM   #20 (permalink)
did u follow the advice of NucleusKore ?
look here
http://www.linuxquestions.org/questi...n-card-583522/
http://suseforums.net/index.php?showtopic=38671
Faun is online now
Old 05-04-2008, 01:56 PM   #21 (permalink)
noapic
then press enter
sorry I am very late to post here.
after my last post in this thread i have tried second time on your trick in i worked suddenly and when i have istalled i was 11:00 pm and my mom was got angry on me saying that what are you doing from 8:00 am to 11:00 pm at night just got to your bed room and give some rest to your computer .
after that i have tried to post in this thred but this page was not opening and today it was jst same taking long time but not able to login.so sorry for that.
Finally THANKING ALL OF YOU, you have helped me so much.
Old 05-04-2008, 07:54 PM   #22 (permalink)
TheSaint
You're welcome. To have a faster set up you may want to see this thread
OpenSuSE 10.3 for standalone PCs without an internet connection
Old 05-04-2008, 10:21 PM   #23 (permalink)
help me .vob file is not playing on open suse 10.3 and no 3d graphics accleration found
Old 05-04-2008, 10:36 PM   #24 (permalink)
TheSaint
for .vob install mplayer
To make life easy go through OpenSuSE 10.3 for standalone PCs without an internet connection
else add the Packman repository from here and install mplayer, win32 codecs, mplayer plugin
For 3D graphics, which card do you have?
Old 05-04-2008, 10:40 PM   #25 (permalink)
install
libdvdcss2
w32codecs
Faun is online now
Old 05-04-2008, 10:42 PM   #26 (permalink)
Old 05-04-2008, 10:49 PM   #27 (permalink)
TheSaint
1. Click on the green one-click install icon here, give you root password when prompted and follow the steps.
2. Then Press Ctrl+Alt+Backspace
3. Relogin to the system
4.Then press Alt+F2
Type console
Type su and press ENTER
Give your root password
Now type
sax2 -r
and press ENTER
Your 3D graphics should be activated. For one click install of compiz fusion see here
Old 05-04-2008, 10:51 PM   #28 (permalink)
wait for minute i will restart my pc in login linux because from ther the fonts on net are to small to read
Old 05-04-2008, 10:56 PM   #29 (permalink)
TheSaint
If you cannot read what's in firefox press ctrl and plus key to enlarge
Old 06-04-2008, 08:08 AM   #30 (permalink)
is there no other way than downloadinf from net and then it installs necessory software by it self
How To Uninstall Open Suse 100.dx Software Q&A 1 06-11-2007 08:48 AM
need Open SuSE 10.2 DVD Garbage Open Source 9 15-07-2007 08:08 PM
Open SuSE 10.1 update NucleusKore Tutorials 1 20-10-2006 04:11 PM
Softwares for Open SuSE nishant_nms Open Source 2 07-02-2006 11:17 PM
