Old 03-04-2008, 02:34 PM   #31 (permalink)
PhotonAttack
DigitalDude's Avatar
Default Re: Ubuntu to rename top level directories?
Originally Posted by mehulved View Post
Type names in ssh? Can you please explain, I didn't get you.
sorry I was blunt...
I was talking about managing my server through SSH terminal
cos of the latency its annoying to type long stuff
_
DigitalDude is offline
Old 03-04-2008, 03:05 PM   #32 (permalink)
18 Till I Die............
Use bash completion. Why was that created?
I always have a screen session running at home with irssi, elinks and mutt running within it. I ssh in from work or elsewhere attach the screen session and do my chatting, check mails, configure my systems. I find bash completion really helpful then. But, I still don't see why would new path names be a problem for ssh connections too, even with higher latencies.
http://www.bash.org/?258908
mehulved is offline
Old 04-04-2008, 02:03 AM   #33 (permalink)
PhotonAttack
I just use putty and do some small tasks occasionally on the server... for the major stuff there is lxadmin control panel dont want to install stuff that I'm not familiar with and screw it off
I feel the latency is annoying.. typing and seeing the text after sometime is in the SSH window is awkward for me
but the server hosted in singapore used to have less latency like around 50ms which is gr8... but suddenly 2 months ago I was getting more ping in sg servers than the ones in US... I did watever I can but helpless.. airtel ppl say its prob with DNS... the datacenter ppl say its problem with ISP routing.. I went mad and finally cancelled the sg server now all I have is US servers with 400ms+ latencies
_
Old 04-04-2008, 12:35 PM   #34 (permalink)
String Phreak
mediator's Avatar
Even so, but the bash completion doesn't work with shell scripts, crons, editing confs etc. U can use copy/paste though, but it certainly becomes tedious. May be thats why they have '/etc/named.conf' as a shortcut pointing towards the actual '/var/named/chroot/etc/named.conf' , I dunno. But I prefer the etc (former) one. Its the same situation, where we use 'ping SITE' instead of writing the complete path '/bin/ping SITE'. But neways thats their philosophy......Noob friendliness.
mediator is offline
Old 08-04-2008, 09:08 AM   #35 (permalink)
nach p's Avatar
it looks more systamatic though it will take bit time 2 get accustomed.
but is it really required !!
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Rename The Recycle Bin Batistabomb Tutorials 9 07-11-2007 04:30 PM
How to rename the thread? Ron QnA (read only) 1 13-01-2007 10:11 AM
how can i rename recycle bin ? kill_deep_singh QnA (read only) 12 19-02-2006 12:09 AM
Rename your RECYCLE BIN !!! anandk QnA (read only) 7 17-05-2005 09:32 PM
