| Forum |
#1 (permalink) |
If I am using only browser (for Internet access ), Outllok for mail and Ipmsg (for chatting within Lan ) and ACDC ,Word ,XLS and nothing else than which Linux Distributor should it use . It should be very Light ,Fast and stable. I am using Windows XP right now , I don’t want to use XP any more , is this possible ? Please Help me .. Say Byebye to Microsoft |
#2 (permalink) |
Who stole my Alpaca!
I believe that everyone could help you out a bit better if everyone knew your hardware which you will be using. This will allow the person to suggests distro which will be light and stable to your hardware.
The Ultimate Chess Strategy : "Hit Hard, Hit Fast and Hit Often" |
#3 (permalink) |
Well, to start with, if you are entirely unfamiliar or relatively uncomfortable with linux, you should start with ubuntu linux.
almost all the programs you mentioned is available, a browser, even similar to outlook for mail, word (openoffice), (i only know the ACDC band
A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of handguns and tequila. |
#4 (permalink) |
Think Zen.
Like FilledVoid said, unless you specify the hardware you will be running on,
we cannot suggest a distribution for you. But , regardless of distro,you can use, Firefox/Opera - Browser. Abiword/OpenOffice.org - Word. Gnumeric/OperOffice.org - Excel. Evolution/Thunderbird/Spicebird - Outlook. I have no idea what ACDC is.
Do what you will; but not because you must. -- Zen Quote |
#5 (permalink) |
left this forum longback
I remember acdsee
yes,Ubuntu will be ideal for new users.
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#9 (permalink) |
dont expect to run compiz-fusion with full bells and whistles(will drag?)
#10 (permalink) |
TheSaint
For a moment there I thought ACDC ! (that's what he's typed !) XMMS would do
Now on topic, you can use Ubuntu.
http://www.neville.in http://www.linuxrocks.in "The Future Is Open" |
#12 (permalink) |
TheSaint
@T159 I'll be very honest with you, my experience with Fedora and Mandriva is zero. The last distro of Fedora I used was FC4, and Mandriva, well Mandrake 8.2. I can't say about Mandriva, but Fedora does not match the ease of use of OpenSuSE.
One strong point I find in OpenSuSE is YaST, one place where you can find EVERYTHING and configure stuff easily. It's like a big control panel. In case you did not know, YaST even works in CLI mode. Try pressing CTRL+Alt+F1 and login, and type yast at prompt and press Enter. So even if your display fails for any reason you can repair it in CLI mode using YaST. If you however want to fiddle around with config files and do things the hard way you can try other distros, even Slackware To the best of my knowledge, you have to subscribe for software updates in Mandriva, they are not free, which i why I would not recommend it. Bottom line, do you want to learn linux, technical? You have to look beyond OpenSuSE. If you just want to enjoy your linux look no further.
#13 (permalink) |
yep i want to learn abt the RPM based distros (am quite familiar with deb based distros), but not from scratch (i would like to hav it easy way).
K i have got one spare 8 gb partition, tonight i will install mandriva 2008 (Fedora 8 is ruled out), currently OpenSUSE 10.3 is installed and Ubuntu 7.10 on another 13 GB partition. |
#14 (permalink) |
RPM distros the best is fedora IMO.suse is slow with its yast(although kde suse is almost windowi$h).the best 3rd party repos also comes for fedora.
#16 (permalink) |
Juke Box Hero
I would say start with Linux Mint, which is essentially Ubuntu with codecs and plugins installed and then a little more. Try the live cd to check about hardware compatibility.
Stick with Mint for a few months and then you will essentially want to try other distros and we can discuss then. |
#17 (permalink) | |
http://ubuntuforums.org/showthread.php?t=272104 Furthermore do you have a good internet connection. Cause if you don't then go for Mint cause its Out of Box Experience is much more viable than that of Ubuntu. Other beginner friendly distros I guess would be Mandrake and from what I here from some people is fedora is ok too? Hitboxx can confirm if it is since he is/was a Fedora user
#18 (permalink) | |
GaurishSharma.com
it has what Ubuntu can offer + some extra stuff |
#19 (permalink) |
see i am a System administrator and i think i will remove some XP systems and add linux box .. coz some systems need very less aplications so need not install log list of aplications, limited aplications and more H/W resorces.
If some one using only Browser , and one or two other software for that why install bunch on software's from any OS if it is (XP or Linux) Just install minimum software less time to load , works fast and limited access to users. Just wana know if any stable OS is there which i easy to add softwares |
#21 (permalink) |
of course Debian
| Bookmarks |
| Thread Tools | |
| Display Modes | |
