Old 22-03-2008, 10:16 AM   #1 (permalink)
hullap's Avatar
Default Problem while installin packages(ubuntu)
i downloaded secondlife installer from www.getdeb.com .but due to power cut my computer shut up. Now whenever i install any package(only tried .deb) or open any package manager like synaptic or use apt i get error
Originally Posted by Ubuntu
E: The package secondlife-install needs to be reinstalled, but I can't find an archive for it.
E: Internal error opening cache (1). Please report.
PLEASE HELP
hullap is offline
Old 22-03-2008, 10:57 AM   #2 (permalink)
Default Re: Problem while installin packages(ubuntu)
Here is the solution:
http://ubuntuforums.org/showpost.php...91&postcount=3
1. sudo gedit /var/lib/dpkg/status
2. Delete the section for libavahi-core5.
3. sudo mv /var/lib/dpkg/info /var/lib/dpkg/info_old
4. sudo mkdir /var/lib/dpkg/info
5. sudo apt-get update
6. sudo apt-get -f install
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is offline
Old 22-03-2008, 01:42 PM   #3 (permalink)
hullap's Avatar
Thnx Fixed.
PLease close this thread
hullap is offline
Old 22-03-2008, 01:49 PM   #4 (permalink)
Juke Box Hero
Closed as per request.
Hitboxx is offline
Pidgin plugin problem installin Kenshin Open Source 4 26-11-2007 01:38 PM
installin soft in ubuntu Arun the Gr8 Open Source 2 13-03-2007 01:53 PM
help installin php mukul Tutorials 7 07-07-2006 01:58 PM
Problem installing msi-based packages as it shows "access denied" message catalyst Software Q&A 2 29-05-2006 09:02 PM
Problem using Wine Packages in Linux? prashu Open Source 3 02-11-2004 07:24 PM
