Old 14-03-2008, 12:01 AM   #1 (permalink)
bharat_r's Avatar
Default Problems Installing Beryl manager
I installed Beryl from Package Manager in Linux Mint 4.
But when I try to install Beryl-manager, it gives an error.
I cant understand what it means & how to I solve it?
This is the message:
bharat_r is offline
Old 14-03-2008, 12:18 AM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: Problems Installing Beryl manager
^^Have you enabled all the repo?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 14-03-2008, 05:40 AM   #3 (permalink)
bharat_r's Avatar
yes. I have added the repos given at http://linuxmint.com/wiki/index.php/..._on_Linux_Mint
I downloaded beryl & beryl manager as .gz files from beryl website. How do I install that. I have extracted them to a folder,now what do I do?
bharat_r is offline
Old 14-03-2008, 06:40 AM   #4 (permalink)
MMO Addict
amitava82's Avatar
AKAIK its because Mint 4 comes with Compiz. I think you need to remove compiz before you could install Beryl... Not sure though..
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 14-03-2008, 08:56 AM   #5 (permalink)
left this forum longback
praka123's Avatar
beryl is already a dead project as it re-merged with compiz to form compiz-fusion.try using Ubuntu compiz-fusion repository.
purge beryl completely using synaptic package manager.
refer http://ubuntuguide.org for compiz-fusion help
praka123 is offline
Old 14-03-2008, 11:08 AM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
What Prakash said. Mint 4.0 Daryna comes with Compiz-Fusion.
FilledVoid is offline
Old 14-03-2008, 09:01 PM   #7 (permalink)
bharat_r's Avatar
Thanks guys! I installed Compiz Fusion and set up all the desktop effects!!
bharat_r is offline
Old 14-03-2008, 10:05 PM   #8 (permalink)
bharat_r's Avatar
btw what do I enable in the compiz manager so that if I take my mouse pointer to the corner of the screen ,it forms a preview of all the windows ?
bharat_r is offline
Old 15-03-2008, 06:27 AM   #9 (permalink)
anarchist
Posts: n/a
Extra>> window previews.
it will give this type of previews:
Old 15-03-2008, 09:21 AM   #10 (permalink)
bharat_r's Avatar
I didn't mean this. I meant when many windows are open & u take the mouse pointer to the upper right corner of ur screen, all the windows that are open are aligned on the desktop from which we can click & select the window we want.
I figured it out. It's the scale plugin
bharat_r is offline
Old 15-03-2008, 11:45 AM   #11 (permalink)
FilledVoid's Avatar
Yeah its the scale Plugin. To get a similar view of al your workspaces with the programs in it Use the Expose Plugin. Refer to the shortcuts in the Advanced Desktop Effect Settings Window.
Old 15-03-2008, 02:21 PM   #12 (permalink)
praka123's Avatar
^alt+tab for expose?
praka123 is offline
Old 15-03-2008, 04:00 PM   #13 (permalink)
FilledVoid's Avatar
Alt + Tab is not expose. Alt + Tab just lets you switch between programs in the same workspace if IM correct. Expose lines up yopur workspaces and you can click on any of the programs in the workspaces and send focus on it.
Old 15-03-2008, 04:24 PM   #14 (permalink)
praka123's Avatar
my bad! I havent booted into ubuntu,for long time
praka123 is offline
Beryl on 64-Bit ubuntu hellknight Open Source 2 14-08-2007 10:05 PM
Beryl in Ubuntu faraaz Open Source 21 16-06-2007 11:11 AM
Beryl Problem. LEARNER_LEARNER Open Source 7 24-01-2007 04:34 PM
Beryl on centOS, how? amitava82 Open Source 1 22-01-2007 04:05 PM
