Old 13-03-2008, 04:55 PM   #1 (permalink)
Think Zen.
ray|raven's Avatar
Default Gtkrc Help Needed.
I have a theme called Samui,
http://www.opendesktop.org/content/s...?content=41263
Everything is fine with the theme, except the part that , it shows large icons on popup menus.
Could someone tell me how to change the size of the images displayed on popup menus?
Thanx,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 13-03-2008, 07:21 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Gtkrc Help Needed.
Add this line to gtkrc file:
gtk-icon-sizes = "panel-menu=20,20anel=16,16:gtk-button=24,24:gtk-large-toolbar=30,30"
Customize the size according to your preferences.
infra_red_dude is online now
Old 14-03-2008, 08:54 AM   #3 (permalink)
Think Zen.
ray|raven's Avatar
^Thanx, but i kinda fiddled with the theme yesterday night and got it working.
P.S : How abt writing a "How to make gtk+ themes?"
Old 14-03-2008, 10:45 AM   #4 (permalink)
Wire muncher!
Actually it'd be a real tuff job. It would vary for engine to engine. And gtk theming part is the worst component of gtk when it comes to documentation. No practically useful documentation exists!
Old 14-03-2008, 10:46 AM   #5 (permalink)
Think Zen.
ray|raven's Avatar
^Yeah , that was the reason why i asked you for a how-to.
I tried to get a decent how-to on the net, but even after half-an-hour of searching, i coudnt find a single one.
Wonder how all these themer's started their theming days?
Old 14-03-2008, 11:01 AM   #6 (permalink)
Wire muncher!
Thats coz, as I said, none exists!!
Ask me
Old 14-03-2008, 11:08 AM   #7 (permalink)
Think Zen.
ray|raven's Avatar
^ I was asking you
Though in a wierd and cryptic way
Should've written ,"Points finger up" with the prev post
Old 15-03-2008, 12:29 PM   #8 (permalink)
Proud to be Linux
abhinandh's Avatar
offtopic : @ray, i have made the samui icon theme to work with new gnome version.
you may want to have a look.
http://www.mediafire.com/download.php?12mnytdpkip
http://abhinandh.com
abhinandh is offline
Old 17-03-2008, 09:02 AM   #9 (permalink)
Think Zen.
ray|raven's Avatar
^Thanx , but i use Xfce , and the set from gnome-look works fine with no modifications.
Old 18-03-2008, 11:05 AM   #10 (permalink)
Think Zen.
ray|raven's Avatar
Guys, I need a no frills color chooser app, having to run gimp to just to know the hex of a color is crappy.
Old 18-03-2008, 11:44 AM   #11 (permalink)
Proud to be Linux
abhinandh's Avatar
for gnome gcolor2 is great.
can't recollect anything for Xfce.
Old 18-03-2008, 11:47 AM   #12 (permalink)
Think Zen.
ray|raven's Avatar
^Just what i was looking for.
Thanx, its a gtk+ app and needs no gnome deps.
Old 24-07-2008, 09:05 AM   #13 (permalink)
Think Zen.
ray|raven's Avatar
Ok , First up, Apologies for bumping an old thread.
But i figured a new thread is pretty much useles for the small query i had.
As for the question,
What widget class do i have to set style to , to theme the handles on the panel?
Old 24-07-2008, 01:32 PM   #14 (permalink)
Wire muncher!
Handles on the panel?? Cudn't get you...
Old 24-07-2008, 01:38 PM   #15 (permalink)
Think Zen.
ray|raven's Avatar
By Handles i mean the grip like thingies that appear as the seperators and also before and after the system tray and others.
Sorry, dont know how else to explain.
Old 24-07-2008, 02:11 PM   #16 (permalink)
Wire muncher!
Oh yes.. thats called handle alrite I'll show a sample here using the pixmap engine. The widget class is GtkHandleBox :
style "myhandlebox" = "default"
engine "pixmap"
function = SHADOW
function = HANDLE
recolorable = TRUE
overlay_file = "handle-vertical.png"
overlay_stretch = FALSE
orientation = VERTICAL
function = HANDLE
overlay_file = "handle-horizontal.png"
orientation = HORIZONTAL
class "GtkHandleBox" style "myhandlebox"
You can use the relevant pixmap. If you wanna use default one then use something like clearlooks/aurora/murrina engine. Hope this helps
Old 24-07-2008, 02:24 PM   #17 (permalink)
Think Zen.
ray|raven's Avatar
^Ah Thanx .
Ill try it and let you know if it works.
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
help needed from all easwaran Software Q&A 6 24-07-2006 06:53 AM
needed 2 buy a good camera????? help needed.. The Day Walker! Cameras and camcorders 5 02-07-2005 04:43 PM
