Old 11-03-2008, 07:06 PM   #1 (permalink)
Default Automount partition at bootup using UUID in Ubuntu 7.10
Here is a tutorial to mount your drive partitions using UUID (even if u change the label and swap ur hard drives this thing will not change). The UUID of a particular partition changes only after format/deletion of that drive.
Step by step approach:
Step 1 (Create a directory in media folder to mount the desired partition)
use this command
sudo mkdir /media/dld
Here dld is the directory on which I want to mount sda6 partition
Step 2 (Find out UUID of the desired partition sda6)
use this command to find out UUID
blkid
or sudo vol_id /dev/sdxx or ls -l /dev/disk/by-uuid
Step 3 (Open fstab file inside /etc directory)
use this command to open fstab file
sudo gedit /etc/fstab
Step 3 (Edit you fstab file to include the partition sda6 to mount on dld)
include this line (assuming the partition is NTFS)
# dld
UUID=C21477C91477BECB /media/dld     ntfs   defaults,force,umask=007,gid=46 0       1
Do the same for other partitions
Faun is online now
Old 11-03-2008, 07:10 PM   #2 (permalink)
No longer here..
Default Re: Automount partition at bootup using UUID in Ubuntu 7.10
Thanks man ... I was looking for just a tut like this.Just starting out with ubuntu ...
indian_samosa is offline
Old 11-03-2008, 07:10 PM   #3 (permalink)
^^anytime
Faun is online now
Old 11-03-2008, 07:12 PM   #4 (permalink)
left this forum longback
praka123's Avatar
in ubuntu "vol_id" also reveals UUID
praka123 is offline
Old 11-03-2008, 07:15 PM   #5 (permalink)
yup and one more command i dont remember too reveals UUID
post updated
Faun is online now
Old 12-03-2008, 12:16 AM   #6 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Gr8 one.. Didn't knew this..
(still a lin n00b I am hehe )
Thanks.. (I grabbed this tut from your blog though)
Quiz_Master is offline
Old 12-03-2008, 03:11 AM   #7 (permalink)
^^actually formatting in blog is a lil difficult so i first post here then just copy/paste there
Faun is online now
Long bootup time in Ubuntu 7.10 (MTA Error) cool_techie_tvm Open Source 2 06-03-2008 02:30 PM
Find and add UUID in fstab phreak0ut Open Source 22 07-11-2007 12:41 PM
ubuntu partition expansion legolas Open Source 7 11-06-2007 07:27 AM
Windows partition in Ubuntu zegulas Open Source 5 15-10-2006 09:58 AM
ubuntu and kubuntu on same partition?? mannu_techy Open Source 2 26-08-2006 12:55 PM
