Old 09-04-2005, 05:40 PM   #1 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Default This newbie needs urgent help on KNOPPIX
I booted into knoppix and tried to extract some files to my hard drive, but it simply refused. Why did this happen and How can I fix this? Also, How can I browse to open my MP3s or other files from my windows FAT32 hard drive? Help please!!!!!!!!!!!!!!!!!!!
DeSmOnD dAvId is online now
Old 09-04-2005, 11:42 PM   #2 (permalink)
yes u can do these things,
did u tried to extract files on NTFS portion coz that doesn't work, NTFS writing is not supported under knowpix...
one more thing if u haven't opted to create swap portion which it ask at boot time then also it wouldn't write any thing
just go to /mnt folder from your system main ,
i think knowpix makes shortcut of your HDD on desktop,
if it haven't mounted then search this forum u'll get it..
Music is like Sex, The more you get, the more you want.
demoninside is offline
