Old 19-02-2008, 12:53 PM   #1 (permalink)
Fedora User
LEARNER_LEARNER's Avatar
Exclamation Problem in IM during connect.
Hi Every1.i have facing problem in IM during Connect nd getting Error Msg is "Raju_tiwari@yahoo.com was disconnected due to an error:invalid username.Gaim will not attempt to recconect the account until you correct the error and re-enable the account.
My Distro is FC6.
My username is right but sorry for that in any mistake configure or anything.can u tell me plz .
1:-I'm a killer,I kill people 4 money,but u r my friend.I kill u 4 free!!! :lol:
2:-Why does a Donkey eat grass?!..Oops...sorry.That's your personal matter! :lol:
LEARNER_LEARNER is offline
Old 19-02-2008, 01:55 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Problem in IM during connect.
Upgrade to pidgin!
mediator is offline
Old 19-02-2008, 03:01 PM   #3 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
try signing on only with your username and not the @yahoo.com portion? That is use raju_tiwari only.
FilledVoid is offline
Old 21-02-2008, 05:22 PM   #4 (permalink)
Fedora User
ThanKs for Solving Problem In Fedora Core 6.
But I have been trying install Pidgin in RHEL5 for 2 hours but getting error .can u help me please ?
ERROR is :-
Loading "installonlyn" plugin
Loading "rhnplugin" plugin
This system is not registered with RHN.
RHN support will be disabled.
Setting up Install Process
Setting up repositories
Reading repository metadata in from local files
Parsing package install arguments
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package pidgin.i386 0:2.3.1-0.el5 set to be updated
--> Running transaction check
--> Processing Dependency: libpurple = 2.3.1 for package: pidgin
--> Processing Dependency: perl(Purple) for package: pidgin
--> Processing Dependency: libpurple.so.0 for package: pidgin
--> Processing Dependency: libgtkspell.so.0 for package: pidgin
--> Restarting Dependency Resolution with new changes.
---> Package libpurple.i386 0:2.3.1-0.el5 set to be updated
--> Processing Dependency: libsilc-1.0.so.2 for package: libpurple
--> Processing Dependency: cyrus-sasl-md5 for package: libpurple
--> Processing Dependency: libsilcclient-1.0.so.1 for package: libpurple
--> Finished Dependency Resolution
Error: Missing Dependency: libgtkspell.so.0 is needed by package pidgin
Error: Missing Dependency: libsilc-1.0.so.2 is needed by package libpurple
Error: Missing Dependency: cyrus-sasl-md5 is needed by package libpurple
Error: Missing Dependency: libsilcclient-1.0.so.1 is needed by package libpurple
Old 21-02-2008, 06:00 PM   #5 (permalink)
String Phreak
mediator's Avatar
Goto rpmfind.net n search for the missing dependencies i.e "libgtkspell.so.0", n the remaining three. Download the ones corresponding to redhat n install em first and then try again.
Also, did u use yum? Try up2date! "up2date install pidgin". It might work.
mediator is offline
Vodafone Mobile Connect Problem ::cyborg:: Buying Advice 3 09-04-2008 12:05 PM
r-connect problem Amir.php Hardware Q&A 6 27-11-2007 04:23 PM
A problem when I connect to Internet ramprasad Internet & WWW 4 01-12-2004 05:50 PM
R-CONNECT PROBLEM venu2004 QnA (read only) 5 05-10-2004 06:32 PM
