Old 16-02-2008, 11:40 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Fedora Help Needed
Hey guys.... i tried installing Fedora provided with this months digit( never tried linux b4 other than live discs) and the problem is after i finish installation, during the first boot into Linux after a particular point my keyboard n mouse stop functioning( the place wher i shud create users n all) don know wat to do
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 17-02-2008, 12:11 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Fedora Help Needed
Try reinstalling!
mediator is offline
Old 17-02-2008, 12:48 AM   #3 (permalink)
DId it 3 times...no use
Sony Vaio CW26FG
Old 17-02-2008, 05:22 AM   #4 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Welcome To The Real World My Friend.
and try reading LinuxForDummies
rollcage is offline
Old 17-02-2008, 09:51 AM   #5 (permalink)
18 Till I Die............
They stop specifically at that point only? Or at different points? Has it happened with live cd's before?
http://www.bash.org/?258908
mehulved is offline
Old 17-02-2008, 12:30 PM   #6 (permalink)
left this forum longback
praka123's Avatar
most prolly ur keyboard will be working.press CTRL+ALT+F1 to see a login screen?did u see?
praka123 is offline
Old 17-02-2008, 01:18 PM   #7 (permalink)
At the time when i should create a suer everything freezes....... only the restart button works
Sony Vaio CW26FG
Old 22-02-2008, 12:35 PM   #8 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
I've heard many users complaining the exact same thing happening. Could it be a hardware problem? I did face something like this when I was installing FC5 once, but it got resolved after I restarted the installation
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 22-02-2008, 11:19 PM   #9 (permalink)
The Unknown's Avatar
Try enabling System BIOS Caching is BIOS/CMOS Setup.
KDE on ArchLinux
The Unknown is offline
Fedora goes next gen! Fedora 8 Test 1 Released Dark Star Open Source 24 10-08-2007 11:39 AM
No more "Fedora Core" but Fedora praka123 Open Source 8 15-01-2007 10:57 AM
Help needed..Sound Blaster Live not detected on FEDORA.. yogeshglx Open Source 2 22-02-2006 09:34 PM
Fedora Core 4 link needed surdy Open Source 13 25-10-2005 07:17 PM
Fedora 3...file system check problem! URGENT HELP NEEDED! mediator Open Source 1 09-08-2005 06:52 PM
