16-02-2008, 10:15 PM
Help!!! Urgent!!!! Internet Not Working!!!!
My internet story-
Internet was working in F7. I formatted and installed F8.
Now I am unable to get the IP address.
On setting a local ip 192.168.1.2 ; i can login to the DSL router 192.168.1.1 though I don't require it to tune coz reliance dsl is a web-login system @ reliancebroadband.co.in
NOW I AM NEITHER ABLE TO ACCESS INTERNET ON F8 OR F7
AND MY LAN CARD IS WORKING. PLEASE HELP!!!!
KDE on ArchLinux
16-02-2008, 10:37 PM
left this forum longback
Re: Help!!! Urgent!!!! Internet Not Working!!!!
doesnt redhat systems default with iptables FW ON?
try as root "iptables -F" for a test and try.I think ur on pppoe builtin dialer mode?
16-02-2008, 10:46 PM
GTK+ programmer
Nilesh,
Im facing the same problem. Even i have reliance broadband connection
when I give the command "sudo /etc/init.d/networking restart"
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 15
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
It worked perfect before without any configuration. Its been like this for 2 days
16-02-2008, 10:57 PM
I configed that using GUI. Also I said LAN is working.
Originally Posted by ChaiTan3
Nilesh,
Yeah its like this since 2 days. I am sending a complaint to broadband@relianceada.com
If they keep this like this then I think I'll have to move to some other ISP
KDE on ArchLinux
16-02-2008, 11:05 PM
GTK+ programmer
Seems a Reliance problem.
16-02-2008, 11:13 PM
Yeah I have sent them a strong email. I also stated that if they do not resolve this, then I am going to move to another ISP like Airtel or BSNL.
KDE on ArchLinux
17-02-2008, 01:46 AM
18 Till I Die............
lol format once again. Maybe you formatted your ISP's servers.
http://www.bash.org/?258908
17-02-2008, 07:47 AM
hahaah. nice joke. then how am i on the same internet from my dad's win32 lappy ?
KDE on ArchLinux
17-02-2008, 09:33 PM
KDE on ArchLinux
17-02-2008, 09:46 PM
check logs, always.
17-02-2008, 10:14 PM
does it come with a router?esp ut300r2u?u can switch OFF the router and connect again while fedora is running.try if fedora's dhcp system detects the IP .
the simple thing u may have tried before?as root,
service network restart
I think fedora got a gui for services;right?
also restart dhcp service too.
17-02-2008, 10:26 PM
TheSaint
Your local IP is set correctly (192.168.1.2, subnet mask 255.255.255.0)
It looks like a DNS problem. Please update your DNS to OpenDNS and see.
208.67.220.220
208.67.222.222
Update: Oops, my bad, didn't read properly. Anyway just try changing the DNS numbers.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
17-02-2008, 10:39 PM
"The Gentleman"
prob lies with ur system not with ISP.... roflmao
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
17-02-2008, 10:57 PM
GTK+ programmer
Same case here. The reliance connection is working in Windows but not in linux( ubuntu in my case).
In both the OS i have set configuration to automatic.
17-02-2008, 11:00 PM
"The Gentleman"
do you manually give any ip in windows ?
or its set to "Obtain IP automatically"
- Dijkstra
17-02-2008, 11:01 PM
GTK+ programmer
Its set to Obtain IP automatically
17-02-2008, 11:08 PM
TheSaint
I am still wondering how can it be a ISP problem. You said Windows is browsing fine. And since you can log into you router, the only two things left to check are
1. Default gateway (192.168.1.1)
2. Primary and Secondary DNS
3. Driver issues !!! funny but see this
Just see this too
Reason: Update: 3. Driver issues
17-02-2008, 11:43 PM
"The Gentleman"
system->admin->network *->set it to DHCP settings
on ubunbu -> sudo /etc/init.d/networking restart
on fedora ->login root: /etc/init.d/network start
or else reboot
btw wats the hostname u gave while installing fedora ?
- Dijkstra
17-02-2008, 11:54 PM
#19 (permalink)
Can you explain how exactly you connect? You have a dialler or something? Any idea?
17-02-2008, 11:56 PM
#20 (permalink)
TheSaint
You won't believe I just woke up to post this message, it might just work.
DISABLE IPV6
Goodnight
17-02-2008, 11:59 PM
#21 (permalink)
"The Gentleman"
digit addiction :-P
- Dijkstra
18-02-2008, 12:16 AM
#22 (permalink)
brilliant ideas usually strike in the bed
18-02-2008, 12:26 AM
#23 (permalink)
"The Gentleman"
ur wrong go school & ask ur teacher... answer is LOO
- Dijkstra
18-02-2008, 12:33 AM
#24 (permalink)
Originally Posted by vish786
digit addiction :-P
^exactly. LOL!
@NG aka "unknown":try switch OFF & ON ur modem while in fedora.then run(ALT+F2):
gksu system-config-services
^restart suspected services.
18-02-2008, 09:56 PM
#25 (permalink)
GTK+ programmer
I've disabled IPv6 but still the same prob
heres the output of network restart
* Reconfiguring network interfaces... There is already a pid file /var/run/dhclient.eth0.pid with pid 5739
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.5
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/eth0/00:1a:4b:5d:31:fd
Sending on LPF/eth0/00:1a:4b:5d:31:fd
Sending on Socket/fallback
DHCPRELEASE on eth0 to 220.225.160.3 port 67
send_packet: Network is unreachable
send_packet: please consult README file regarding broadcast address.
There is already a pid file /var/run/dhclient.eth0.pid with pid 134519120
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
18-02-2008, 10:20 PM
#26 (permalink)
TheSaint
Why is DHCPDISCOVER running, haven't you disabled dhcp? Please do so and assign a static ip. Also restart the network post the output of your ifconfig
18-02-2008, 10:41 PM
#27 (permalink)
@chaitanya:the problem is network is unreachable.I am not an expert with n/wing;still it seems that u have to edit the local ip range and/or subnet mask
what about the o/p of subnet mask and be clear,are u on fedora?
also,if u have network-manager thing installed on ur distro,why not purge it out?it is for n00b's who cannot do any network settings.
and what is this service?reliance broadnet using a router ? with webbased activation?
anyways observe the o/p of
also acc.to google reliance IP address is like 123.236.x.x or 124.x.x.x etc which is class A afaik  so,In router,u may have to set these esp SUBNETMASK value to things may be.also this VPI/VCI things too needs to be noted.
I think reliance CC must be asked regarding the technical details like VPi/VCi,dhcp range,any other technical info to be done in router.
use subnet calculator to calculate if u know the ip assigned by reliance:
http://www.subnet-calculator.com/
I think you should assign 255.128.0.0 as Subnetmask.try!
18-02-2008, 10:59 PM
#28 (permalink)
TheSaint
Praka123 I'd beg to differ. I have a class "A" IP (AirTel), but my subnet mask is still 255.255.255.0
That's the job of any hardware router (or even a linux router  ) to interface between two different networks. His internal network can be class C and his external can be anything else.
I still feel as you said, its an IP and subnetting problem, that's why I asked for the output of ifconfig above.
I asked for IPv6 to be disabled as Reliance DNS servers may not be configured properly to handle IPv6 requests. Also, if I am not mistaken, if IPv6 is available, the TCP/IP stack preferrably communicates in IPv6 first and then in IPv4.
So it is advisable to
1) Disable IPv6. Use the system network config tool
Select your interface, click edit, and uncheck the Enable IPv6 configuration option. Enter static IP 192.168.1.2, subnet 255.255.255.0 and save.
2) Then click on manually, type gateway 192.168.1.1, primary and secondary DNS whatever Reliance gives you, or even better, OpenDNS - 208.67.220.220 and 208.67.222.222
Go Next and save your settings
3) In a terminal as root: service network restart
4) ifconfig
and post the output here
For reference: Fedora 8 Network configuration
19-02-2008, 12:08 AM
#29 (permalink)
yup.it is the function of h/w router to resolve the different IP classes.but..here the network is unreachable!some way subnetmask thing needs to be edited to correct value.
I think it needs the help of reliance CC to solve areas along with some linux knowledge
19-02-2008, 07:26 AM
#30 (permalink)
TheSaint
Ok Praka123 lets see. Apparently our man here gets to use the net only at night  Hope he is able to get to the bottom of this. I wonder though, why he did not have any problems with Fedora 7.
