Old 11-02-2008, 11:30 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default Trouble shooting DSL connection in Ubuntu
Today while I was surfing the net on Ubuntu OS , my system shutdown due to UPS failure. When I restart the system, DSL modems Lan light not glowing. I cant connect the net. I tried to reconfigure the Setting by command "pppoeconf" it detect the Lan card but failed to continue the setting with a msg " Check your modem connection or cable or another connection is running".
I restarted the system in Win OS. there it is OK and I am writing this thread in Win OS.
I cant understand what is the problem. Any One any solution please ?
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 12-02-2008, 05:03 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Trouble shooting DSL connection in Ubuntu
fsck ur ubuntu via livecd.
boot Ubuntu live cd and open a terminal run:
sudo fsck.ext3 -fvy /dev/sdx
^where /dev/sdx is ur hdd ubuntu partition.
If ur modem dsl light is showing up,then ur net is up.Ubuntu can connect.why do u run pppoeconf again
if u try to connect via pon dsl-provider,what is the error message showing in "plog" command?open a terminal and observe.
also,with dsl light glowing only does u try to configure via pppoeconf
praka123 is offline
Old 12-02-2008, 07:57 AM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Today morning when I switched on my pc in Ubuntu, !st I looked in the LAN light and it is glowing. I start the net and it is connected. Now, I can't understand what was the problem last night, today which is automatically fixed. I think there was a ghost in the modem last night for Ubuntu. Because it was fine in WIN OS.
OK. thanks god without any hassel now it is running.
Old 12-02-2008, 02:01 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
well, if this happens next time, try boot into windows & see if it works there.
if it works in windows & its then Ubuntu problem
if NOT, then your connection might be down from ISP end
gary4gar is offline
Old 12-02-2008, 07:44 PM   #5 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Immediately I checked the status in Windows and there it was fine. Hence I was nervous whats the wrong with ubuntu.
Old 12-02-2008, 08:15 PM   #6 (permalink)
praka123's Avatar
@ghosh:make sure ur lan is up @ boot by seeing ifconfig o/p
also if u shutdown ubuntu dirty,boot with a livecd and run a fsck.ext3 -fvy /dev/xxx ,make sure ur hdd ubuntu is NOT mounted in livecd.
also if lan is up,u can see the o/p of "pppoe-discovery" for whether the connection is able or not.
praka123 is offline
Old 12-02-2008, 10:31 PM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
how to bring a connection up at boot time?
sat eth1
gary4gar is offline
Old 12-02-2008, 11:02 PM   #8 (permalink)
The Unknown's Avatar
This is not at all OS problem. This happens when the PC isn't reset properly. Suppose a power failure occurs and your UPS did not give the power immediately and a msecs after that, then the mobo isn't reset properly which leads to non-working of the LAN card. After switch-off and switch-on of the PC, its back to normal.
KDE on ArchLinux
The Unknown is offline
Old 13-02-2008, 05:30 AM   #9 (permalink)
18 Till I Die............
It's not a big issue. Just that your connection wasn't terminated last time because your PC shutdown due to UPS failure before it could terminate the connection.
So, when your PC restarted the connection wasn't on from the client side but at the ISP end it will still on, thus the error message.
just typing
poff dsl-provider
would have solved it IMO.
http://www.bash.org/?258908
mehulved is offline
Old 13-02-2008, 10:11 AM   #10 (permalink)
Married!
Rahim's Avatar
Is it possible? If the modem is powered-off then both connections would be terminated, isnt it?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 13-02-2008, 10:35 AM   #11 (permalink)
GaurishSharma.com
gary4gar's Avatar
All TCP connections are required to be terminated explicitly, however is a client does not reply to server for a longer period of time the connection is terminated by the client.
This period of wait by server is called time out.
if client disconnects & connected within the period of timeout he may experience problem with most servers.
I am not a expert in networking, so this is my half knowledge.
@Experts
Please point out, any errors
gary4gar is offline
Old 13-02-2008, 09:19 PM   #12 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
On that that day night I tried several time to reestablish the LAN in Ubuntu by restarting the PC, Modem, changing the cable etc also tried to configure the "pppoeconf" all are useless. During the experiment I restart in Windows, as soon as the booting process over LAN/ethernat light is OK and net is connected with in a seconf.
Again I rebooted in Ubuntu to see what is the condition. NO, the LAN/Ethernet light is not glowing on modem as well as LAN port on the PC.
Next day morning there is no problem. The problem is solved automatically.
@mehuldev
It may be possible when I first rebooted in Ubuntu, but how than it works in windows? After closing Windows and resatrted again on Ubuntu the same things happened.
Old 13-02-2008, 09:22 PM   #13 (permalink)
praka123's Avatar
ur lan card may be faulty(??) else,missing drivers.
what is ur lancard?
go through "lspci" output and post here.
most prolly it will be realtek made and runs on 8139cp kernel driver
praka123 is offline
Old 13-02-2008, 10:16 PM   #14 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
what is ur lancard?
Lan card is not faulty. It is working fine in Ubuntu from Morning.
And in windows there is no any problem. ( GHOST is there in UBUNTU !!!!)
Pc Trouble Shooting pvsraao Hardware Q&A 3 26-10-2007 11:00 AM
Internet Explorer 7 Trouble Shooting meghraj Software Q&A 2 20-07-2007 03:46 PM
GPU trouble shooting shashank_digitreader Graphic cards 1 09-06-2006 02:21 PM
WMV TROUBLE SHOOTING !!!! chetan.g Software Q&A 2 06-02-2006 04:17 PM
