Old 11-02-2008, 10:18 PM   #1 (permalink)
bhunnu16's Avatar
Default yum not installing in RHEL 4.
Hi! I am trying to install yum on my RHEL 4 . But when I clicked the rpm it flashed an error 'Source Package not supported'. When I extracted & compiled ,it showed the install bar. But when I executed the commnad yum. It says yum package not available. Kindly help me as I am not able to get the yum work on RHEL.
Also the rpm packages are not installing with Software installer.
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 11-02-2008, 11:14 PM   #2 (permalink)
18 Till I Die............
Default Re: yum not installing in RHEL 4.
You got the source rpm.
http://www.bash.org/?258908
mehulved is offline
Old 11-02-2008, 11:24 PM   #3 (permalink)
String Phreak
mediator's Avatar
AFAIR, u have "up2date" and not "yum" in RHEL. Try up2date!!
mediator is offline
Old 11-02-2008, 11:31 PM   #4 (permalink)
I've got yum in CentOS 5. So, RHEL 5 should have yum too, dunno about RHEL4.
mehulved is offline
Old 19-04-2008, 06:34 PM   #5 (permalink)
can anyone tell me how to install applications in .tar.gz format in RHEL 5 ?
Suppose to install firefox 2.0.0.14 . A step by step will be very useful for a linux learner.
One more thing , is there applications like yahoo messenger and skype for voip and video conference.
Downloaded skype but it says lot of dependency problem . installed few rpm to solve but still same message. any reliable source there to install all the components necessary automatically online?
mrbgupta is offline
Old 19-04-2008, 08:53 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes, use Yum in your RHEL 5.
yum install pidgin # Installs Yahoo/GTalk/AIM/Etc.. Messenger
yum install skype # Repo dependent I suppose, might work
For .tar.gz, unpack the contents and run the program if its a binary package, else do these three commands in the extracted folder:
./configure
make
make test
make install
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-04-2008, 07:56 PM   #7 (permalink)
Nothing works !
mrbgupta is offline
How to create RHEL dvd from cds nikhilrao123 QnA (read only) 2 28-02-2007 03:07 PM
modem hangup??? in RHEL 4 Dusvidania Open Source 5 13-07-2006 08:54 PM
Replicating RHEL ?? Ankur Open Source 4 29-10-2005 02:29 PM
How to NIS Server in RHEL 4 AS praka123 Open Source 4 22-09-2005 10:32 AM
