Old 11-02-2008, 11:04 AM   #1 (permalink)
Not fresh
VINSTAR's Avatar
Default help:cannot poweroff
i cannot poweroff from fedora7
when i select system>shutdown
the screen gets distored like
half of the screen with wallpaper
and half with distored colors etc
i wait for 5 minutes but screen remains
like that didnt shutdown
i install ati driver, it installed
succesfully and also i changed the
default runlevel in inittab from 3 to 5.
Help me
gudz.org
VINSTAR is offline
Old 11-02-2008, 11:17 AM   #2 (permalink)
18 Till I Die............
Default Re: help:cannot poweroff
Try this and report what happens
1) Open a terminal
2) Type su
3) Type root password
4) Type shutdown -h now
Does it power off the PC?
http://www.bash.org/?258908
mehulved is offline
Old 11-02-2008, 12:31 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Also try init 5.
Pathik is offline
Old 11-02-2008, 02:07 PM   #4 (permalink)
Not fresh
VINSTAR's Avatar
1) Open a terminal
2) Type su
i get error that there is no command shutdown -h
gudz.org
VINSTAR is offline
Old 11-02-2008, 02:32 PM   #5 (permalink)
Are you sure you were logged in as root after typing 'su' ?
Also try
whereis shutdown
Did you upgrade system? Remove some software right before this started?
mehulved is offline
Old 11-02-2008, 02:58 PM   #6 (permalink)
String Phreak
mediator's Avatar
What bt restart?
mediator is offline
Old 11-02-2008, 03:49 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Dont know about fedora but in Ubuntu you have to issue a time like shutdown -h 1 for this to work. Otherwise it will give you the following error
biju@Venom:~$ shutdown -h
shutdown: time expected
Try `shutdown --help' for more information.
biju@Venom:~$
FilledVoid is offline
Old 12-02-2008, 05:13 AM   #8 (permalink)
left this forum longback
praka123's Avatar
@OP: "shutdown -h 00"
or "shutdown 00"
and in grub,in the line starting with kernel,u add
noapm noacpi nolapic
such that ur /boot/grub/grub.conf looks as below:
title fedora
kernel /boot/vmlinuz-xxx ....... noapm noacpi nolapic
initrd /boot/initrd-xxx.img ....
u can use gedit editor as root to edit /boot/grub/grub.conf
u can invoke
in press ALT+F2,
run,
gksu -u root gedit /boot/grub/grub.conf
praka123 is offline
Old 12-02-2008, 01:59 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
do what Prakash says & try
poweroff,reboot & halt
Function are same as there names.
btw check if
gary4gar is offline
Old 04-03-2008, 12:25 AM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
i think halt sud work it out...
btw hav u tried the above commands?
and wat was the output?
Manshahia is offline
