Old 09-02-2008, 01:12 PM   #1 (permalink)
Digit Addict
suyashpandit's Avatar
Default help in Ubuntu
Lil prob here
Audio and video not playing
guide me the easy way..
suyashpandit is offline
Old 09-02-2008, 01:52 PM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: help in Ubuntu
Hi suyash, Have You installed Gstreamer plugins? Search them in Synaptic Package Manager(System>Administration) or Add/Remove and install them and will be able to make your Ubuntu Multimedia-enabled. Make sure universe, multiverse,etc is enabled (Synaptic>Reposotories).
You will be prompted for root password. Enter YOUR Password when prompted.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 09-02-2008, 03:57 PM   #3 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Lil prob here
Could be numerous problems. Maybe it would help if you said when ti doesnt work . Like when playing what file ? Or viewing a dvd? Or watching youtube? Usually installing ubuntu-restricted-extras take care of that though.
FilledVoid is offline
Old 11-02-2008, 05:25 PM   #4 (permalink)
Digit Addict
hey dude when i goes to install codecs it says "Pllease insert Ubuntu_gatsy_gibbion Disc " and then i put Digit DvD of ubuntu it doesn't expect it
Old 11-02-2008, 05:38 PM   #5 (permalink)
Married!
Rahim's Avatar
Ubuntu DVD doesnot contain proprietary stuff.
Open Software Sources(System>Admin) and uncheck Ubuntu Installation DVD and then reload by typing this in the Terminal(Application>Accessories)
sudo apt-get update
and now install the codecs. Enter your password when prompted.
Rahim is offline
Old 11-02-2008, 05:53 PM   #6 (permalink)
FilledVoid's Avatar
Do the above ^ Or refer to Darkstars guide on how to play Audio files.
Old 12-02-2008, 10:58 AM   #7 (permalink)
Digit Addict
@rahim i unmark this
but when i play a mp3 song it says
Search for suitable codec?
The required software to play this file is not installed. You need to install suitable codecs to play media files. Do you want to search for a codec that supports the selected file?
The search will also include software which is not officially supported.
{cancel} {search}
i pressed search and then a window opened titled "install multimedia codecs" GStremer extra plugins "codecs to play mp3 sid........." This application is provided by the Ubuntu community.
and when i mark{plugin box} the box a new win. appear "Confirm installation of restricted software" The use of this software may be restricted in some countries. You must verify that one of the following is true:
• These restrictions do not apply in your country of legal residence
• You have permission to use this software (for example, a patent license)
• You are using this software for research purposes only
{cancel } {
confirm}
i pressed confirm then it says "The list of applications is not availabe"Click on 'Reload' to load it. To reload the list you need a working internet connection.
{refresh} {cancel}
i pressed refresh and nothing good here same prob again and again
An error occurred
The playback of this movie requires a MPEG-1 Layer 3 (MP3) decoder plugin which is not installed.
Old 12-02-2008, 11:04 AM   #8 (permalink)
18 Till I Die............
DO you have a internet connection? Else try to get these codecs using apt-on-cd from nearby LUG.
http://www.bash.org/?258908
mehulved is offline
Old 12-02-2008, 11:11 AM   #9 (permalink)
Married!
Rahim's Avatar
Hey suyash you have to be connected to the Internet to get Gstreamer Codes Are your internet working in Ubuntu? Just a query.
You did everything allright but should be online while doing it.
One more thing make sure universe, multiverse, restricted are enabled in Software Sources and then reload.
Rahim is offline
Old 12-02-2008, 11:24 AM   #10 (permalink)
Digit Addict
yes i hav internet connection and i am sending these msg. from ubuntu
Old 12-02-2008, 11:27 AM   #11 (permalink)
Married!
Rahim's Avatar
then do as i said and see.
Rahim is offline
Old 12-02-2008, 11:39 AM   #12 (permalink)
Digit Addict
its downloading something...... 14 packets
maybe now it will work
Yoooooooooo its done!!!!!! thanks so lot...
Koolll man you rocks i appreciate :d
Last edited by suyashpandit; 12-02-2008 at 11:39 AM. Reason: Automerged Doublepost
Old 12-02-2008, 11:40 AM   #13 (permalink)
Married!
Rahim's Avatar
Yes it will.
You might add Medibuntu Repo to download some multimedia packages to watch DVDs and other formats.
You are usint Ubuntu 7.10 "Gutsy Gibbon", right?
Open A terminal and enter this to add Medibuntu Repo:
sudo wget http://www.medibuntu.org/sources.list.d/gutsy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key:
wget -q http://packages.medibuntu.org/medibuntu-key.gpg -O- | sudo apt-key add - && sudo apt-get update
Now Install w32codecs & libdvdcss2 packages:
sudo apt-get install w32codecs libdvdcss2
Just take your time and dont get figgity with those commands.
Rahim is offline
Old 12-02-2008, 11:41 AM   #14 (permalink)
Digit Addict
Digit Rocks And LINUX Rocks
its the right place of Experts.... i am really happy to being with you Guys
Old 12-02-2008, 11:42 AM   #15 (permalink)
Married!
Rahim's Avatar
Bhai Linux ka Jadoo chal gayaa
Calling me an Expert? Wait till you see praka123(Prakash Bhai)
Rahim is offline
Old 12-02-2008, 11:45 AM   #16 (permalink)
Digit Addict
i know him
he helped me many times
and yes Linux ka jaadu Chal Gaya he he he
Last edited by suyashpandit; 12-02-2008 at 11:45 AM. Reason: Automerged Doublepost
Old 12-02-2008, 01:54 PM   #17 (permalink)
GaurishSharma.com
gary4gar's Avatar
Buddy please search before posting, this was been discussed many times before
gary4gar is offline
Old 12-02-2008, 02:48 PM   #18 (permalink)
Digit Addict
oh..
can u tell me is here discussed any topic about HP and samsung printer's driver
for ubuntu?
Old 12-02-2008, 03:42 PM   #19 (permalink)
HP usually works out of the box. Also, check https://help.ubuntu.com/7.10/printing/C/printing.html
More importantly see https://wiki.ubuntu.com/HardwareSupp...onentsPrinters first.
mehulved is offline
Tweaking Hidden Ubuntu Settings With Ubuntu Tweak subratabera Open Source 4 02-02-2008 07:47 PM
How to upgrade from ubuntu 7.04 to 7.10 using ubuntu dvd which came with DEC digit.! arunks Open Source 4 13-12-2007 03:48 PM
Wats the differnce b/w Ubuntu & Ubuntu Gigacore Open Source 5 02-06-2007 04:15 PM
Ubuntu Dapper ( 6.06 ) | vs.| Ubuntu Edgy (6.10) Maverick340 Open Source 24 28-12-2006 05:19 PM
