Old 02-02-2008, 12:40 PM   #1 (permalink)
ninad_mhatre85's Avatar
Default mplayer problem in suse 10.3
hi
i have installed mplayer in suse but when i play movie from command line
movie starts at the top of screen and there is no box for the screen so cant even bring it back to center of screen. is there any option to do so.
or any other player ? i have other media player already installed ( by default )
but when i play movie from those players it says need to download codecs ...
Life is not measured by moments u breath but by the moments that take ur breath away
ninad_mhatre85 is offline
Old 02-02-2008, 01:51 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: mplayer problem in suse 10.3
I really wonder why you need to use command line to start mplayer. Just press Alt and F2 and type mplayer and press enter
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 02-02-2008, 02:32 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by ninad_mhatre85 View Post
hi
I'd say install mplayer-gui which is a gui frontend for the mplayer cli and try if things are solved. It most prolly will be
Originally Posted by ImAClown View Post
i Had the same problem!!
There is only one solution to this according to Ubuntu Forums.
They asked me to use some Nitric Acid over the Hard disc and then use Ammonium Dinitro glycerine tri benzene fulro chloric acid on the speaker!!
And all of a sudden there was a huge sound which came from about 10 miles away and Voila! I had Windows Vista running! And my problem was solved!
Trust me, this works..
Awesome advice! you live upto your username!!
infra_red_dude is offline
Old 02-02-2008, 06:17 PM   #4 (permalink)
ImAClown
Posts: n/a
My post was deleted
I think it wont work on Suse..
As i have clearly mentioned that its only possible in Ubuntu. Thats why my post was deleted...
Old 02-02-2008, 07:50 PM   #5 (permalink)
left this forum longback
praka123's Avatar
^may be vista needs some acid work from u; better go pour some acid on Vista losers
ontopic:
mplayer compiled with gui support is only useful.
praka123 is offline
Old 02-02-2008, 07:55 PM   #6 (permalink)
Married!
Rahim's Avatar
The clown is really running his circus very well.
Mods do something about this troiler.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
mplayer installation problem using yum on FC6 cranky Open Source 3 10-03-2007 12:16 AM
SSH problem with Suse 10.1 & others subhayu Open Source 5 31-08-2006 02:53 PM
LOG IN problem in SUSE 9.1 zerohourkill Open Source 10 25-07-2005 11:25 AM
mplayer faq niranjan_mcarenyold Open Source 5 12-06-2005 03:59 PM
Problem in installing mplayer in fedora3 neerajvohra Open Source 2 16-02-2005 01:08 AM
