Old 31-01-2008, 09:53 PM   #1 (permalink)
BSD init pwns System V
hellknight's Avatar
Default Mounting problem in openSUSE 10.3
Hey guys, I just created a new partition on my SUSE box with YaST named as /Backup and with filesystem ext3. Now the problem is that only root can write on it whereas i want to give the permissions to normal users (which is me, root is also me). What should I do. This partition was created to store all my important stuff. Please help.The id of the partition is /dev/sda2 and is primary partition it is mounted at /Backup.
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 31-01-2008, 10:04 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Mounting problem in openSUSE 10.3
sudo chmod 777 /Backup
will work.
Life is as complicated as you say it is.
shady_inc is offline
Old 31-01-2008, 10:14 PM   #3 (permalink)
hellknight's Avatar
Thanks dude,thanks a lot, I really forgot this command! Now it is able for me to write on that partition.
Problem Mounting C: in Gutsy Rahim Open Source 4 31-01-2008 08:00 PM
mounting problem in DSL romeo_8693 Open Source 8 02-02-2007 07:56 PM
Fedora Core 5 CD mounting problem borg Open Source 21 23-06-2006 02:16 PM
Problem Mounting NTFS partition on Red Hat 9.0 Moin QnA (read only) 10 16-08-2004 11:42 PM
