Old 25-01-2008, 04:24 PM   #1 (permalink)
chitvan's Avatar
Default sound problem in SuSE 10.3 on 915GVWB chpst???
i installed SuSE 10.3.
but i didnt get sound in it,
my MB is intel original 915GVWB onboard sound card,......
SuSE detects my sound card,,see this here......
http://i215.photobucket.com/albums/c...reenshot-1.jpg
i have installed SuSE 10.3 in my 2 friend`s PC having intel 845 from same DVD(Digit November),they got sound automatically.....
how to configure sound in 915GVWB?????
plzzzzz help..........
chitvan is offline
Old 25-01-2008, 08:06 PM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: sound problem in SuSE 10.3 on 915GVWB chpst???
your link is not working..
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 27-01-2008, 03:42 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Originally Posted by chitvan View Post
i have done same that u told but don`t get sound yet.
i also unchecked all mute options..
Try this page http://en.opensuse.org/AudioTroubleshooting
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 28-01-2008, 05:55 AM   #4 (permalink)
left this forum longback
praka123's Avatar
@chitvan:can u post the "lspci" output from konsole?.It seems that ur onboard sound is different than normal hda Azalia found in Intel mobos but still the specs shows it is Realtek ALC860 !.also hope it is a original intel mobo?
One thing is you should either have "snd-hda-intel" module available or compiled inside the kernel
You shud really look forward for STEP-5: Add “model” to /etc/modprobe.d/sound file in http://en.opensuse.org/AudioTroubleshooting
Also,post the o/p of "cat /proc/asound/version", "cat /proc/asound/cards"
also, update and upgrade your alsa and necessary packages via yum.@nucleus can help u reg this.
praka123 is offline
Old 28-01-2008, 04:54 PM   #5 (permalink)
chitvan's Avatar
chitvan is offline
Old 28-01-2008, 11:50 PM   #6 (permalink)
Resistance is Futile.
coolpcguy's Avatar
ALSA and intel-hda always have problems. First check: If all volume sliders are set to MAx(esp PCM and Front)
@praka Yum is in Fedora not openSUSE, in openSUSE it's YaST/zypper/smart
Super User ♦ Moderator | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | iPhone 3GS | Dell U2312HM
coolpcguy is offline
Old 29-01-2008, 01:27 AM   #7 (permalink)
praka123's Avatar
^still backend is yum i think
@chitvan: do as root in a terminal
modprobe snd-hda-intel
praka123 is offline
Old 29-01-2008, 06:51 AM   #8 (permalink)
TheSaint
Yes, uses YUM
Try deleting the card from above, click finish and close the window.
Press Alt+F2 and open a Konsole
Type su, press ENTER, and give your root password and press ENTER
Now type alsaconf and press ENTER to configure your card
Old 30-01-2008, 07:22 PM   #9 (permalink)
chitvan's Avatar
ok i will try....then post reults
chitvan is offline
Suse Problem :D Ecko Open Source 5 14-01-2008 06:11 PM
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
no sound on laptop using suse 10.1 linux roxisayshi Open Source 8 28-03-2007 03:36 AM
SSH problem with Suse 10.1 & others subhayu Open Source 5 31-08-2006 02:53 PM
SUSE 9.1 Problem shwetanshu Open Source 11 24-03-2005 07:39 PM
