Old 24-01-2008, 12:53 PM   #1 (permalink)
Default Removable drive problem in Mandriva 08!
Mandriva Linux 2008 Power Pack does not seem to detect removable drives at all lately for me. It used to work before. This includes even my MP3 player. Please help.
Configuration:
AMD Athlon 3200+
160GB SATA hard disk
Leadtek 6600GT graphics
Creative PCI sound
Please help!!!
Dumbledore is offline
Old 25-01-2008, 01:03 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Removable drive problem in Mandriva 08!
^opt for a generic kernel.else,the auto detection and mounting of removable drives is the job of HAL and dbus.so,may be ur hal(hardware abstraction layer) service is in problem or not running.
You can manually mount usb drive in a directory using terminal(gnome-terminal for Gnome and konsole for kde).
login as root in terminal:
su -
^give root password.
now in "#" prompt,mount ur usb device if it is detected.usb devices are normally assigned /dev/sdb /dev/sdc etc.try!
mount /dev/sd* /mnt
and for unmounting,
umount /dev/sd* /mnt
where "*" is the device file name.
If usb is not detected,check the logs.check the end of /var/log/dmesg file.
praka123 is offline
Old 25-01-2008, 06:25 AM   #3 (permalink)
HAL is running alright. Only when the drive appears in the /media folder or /mnt folder, mounting is possible, right? But it is not getting detected at all.
Old 25-01-2008, 09:37 AM   #4 (permalink)
18 Till I Die............
Run dmesg in a terminal when you insert a removable drive.
http://www.bash.org/?258908
mehulved is offline
modifying removable drive mightyboosh Software Q&A 1 16-12-2007 08:01 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Problem with Mandriva 2006 plsoft Open Source 18 10-08-2006 10:44 PM
iPod not recognized on computer, appears as removable drive. Tallywacker Hardware Q&A 6 03-03-2006 03:04 AM
