Old 05-01-2008, 11:36 AM   #1 (permalink)
Ishan's Avatar
Default slow sound in ubuntu
i installed ubuntu 7.04 on my Hp laptop core 2 duo
sound is of connexant
now the problem is whem i play some audio or video files.......i m able to hear it very slow......even though every where the volume is at full.....
But sound is high in headphones connected in its jack......but though it is not clear..much noise is coming........
what should i do?
Also i've downloaded all the required codecs in the players....
but still when i play .avi or .vob files i cant seee the video just hear the slow sound...
players i tried.......
Amrok,audacious,gxine,audacity,movie player, vlc player
Please help
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 05-01-2008, 12:04 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: slow sound in ubuntu
did you update your installion?
there were some bugs, which were fixed in updated, download & install them.
see if it works, else post back
gary4gar is offline
Old 05-01-2008, 12:55 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
this might help Remastered Ubuntu 7.10 from Dell!
n00b forever...
~Phenom~ is offline
Old 05-01-2008, 09:31 PM   #4 (permalink)
Ishan's Avatar
yes i have updated..........i mean...i was connected
to net and allowed it to automatically update...
it showed me that these plugins are required...download them? yes or no?
i went for yes...
my problem yet not solved
Ishan is offline
Old 06-01-2008, 12:21 AM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
Have you checked the PCM volume.
right click on the volume control and click preferences - try fiddling with some of those settings.
gary4gar is offline
Old 06-01-2008, 08:29 AM   #6 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Heh.. I thought you could hear it "slow" like "hhhhhhhhheeeeeeeeeeeeeellllllllllllllooooooooooo" . What you are experiencing is "LOW" volume, not "SLOW" volume! Anyway, type "alsamixer" in command line and fiddle with all the volume mixers.
kalpik is offline
Old 06-01-2008, 08:34 AM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Your PCM is definitely low. Boost up that and everything else under your Volume Control. But PCM's got to be above 60% for proper sound to play through.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-01-2008, 09:45 AM   #8 (permalink)
Dark Star's Avatar
Yep PCM Volume is the main cause of low volume it might be set to low value increase it from Volume COntrol which looks like this
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 06-01-2008, 09:07 PM   #9 (permalink)
Ishan's Avatar
I'll check that ... But what about the sound clearity? Its too bad
Ishan is offline
Old 07-01-2008, 11:43 AM   #10 (permalink)
Cool and Calm
abhi_10_20's Avatar
yea...me too experiencing the same....sound clarity isn't good with totem player.... but with VLC, songs are playing fine.. try that...
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 11-01-2008, 01:25 PM   #11 (permalink)
Ishan's Avatar
ya alsamixer solved my problem...........Thank you all of u.....
but the sound clearity is still a problem....if u think its software problem as ABHI told then can u please suggeest me a good music player?
And ya i have even installed all the required video codecs...but while playing video files like .avi,.vob etc only black screen comes and sound comes...this happens in vlc also......So please provide with the solution....BYE
Ishan is offline
Old 11-01-2008, 09:10 PM   #12 (permalink)
Dark Star's Avatar
This will help you regarding Multimedia support and as far as Music Player my recommendations goes for Amarok and XIne Ui player for Video files How to : Enable Multimedia Suport in Ubuntu 7.10.
Old 12-01-2008, 04:28 AM   #13 (permalink)
left this forum longback
praka123's Avatar
exaile,rhythmbox sounds better!.
praka123 is offline
Old 12-01-2008, 05:28 AM   #14 (permalink)
MMO Addict
amitava82's Avatar
Actually ALSA produce better sound than windows drivers. I have Creative audigy 2 sound card and inspire 5.1 and it produce better sound in Ubuntu than windows. Sound are more clear and vivid. Key is that you have to play around alsamixer and keep PCM mid level. If you keep PCM to 100 then sound gets distorted.
There are some bugs in ALSA 1.0.13 (comes with Ubuntu 7.04). So, update your ALSA driver to 1.0.15 and your problem will be taken care off.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 12-01-2008, 08:35 PM   #15 (permalink)
Dark Star's Avatar
^^ I find OSS to be much better in my system .. While using Alsa there is no sound output during Music/Movie playabck while not the case with OSS
sound gets disabled in between & slow booting... ninad_mhatre85 Software Q&A 3 01-01-2008 05:19 PM
ubuntu running very slow mak1012 Open Source 1 21-09-2007 04:22 PM
Ubuntu 6.1 servers slow? shaunak Open Source 9 11-11-2006 12:47 AM
Slow Broadband in ubuntu saurabh.sauron Open Source 6 10-10-2006 04:42 PM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
