@MetalHeadGautham Am afraid not. I uninstalled Ubuntu
OpenSuSE 10.3 x86_64
Enabling multimedia and restricted formats in systems not connected to the internet can be a pain with any linux distro with a lot of dependency problems. 64-bit systems can be a little more tricky. There is no Java plugin for mozilla, so you will have to use Konqueror for Java applets. The aim of this post is to help out such persons by providing the required
RPMs AND Dependencies in one archive. I have selected a few software which may be required on such PCs. This list is in no way complete, but just represents what I think may be the bare minimum one would like to have on a multimedia desktop PC.
I have covered the following software:
Adobe flash player - for viewing flash animations
Realplayer
Acrobat Reader - required to open encrypted pdfs
Java
Kaffiene - multimedia player
XMMS - winamp lookalike
K3b - CD/DVD ripping, burning
libdvdcss
DeVeDe - Create VCD, SVCD, DVD
Audacity - audio editor
AviDemux - similar to VirtualDub
ffmpeg
VLC player
Transcode
Amarok - mp3 player
ntfs-config
Fonts
You
will need an internet connection to download these three files. Maybe a friend can help you to download it and mail it to you on a cd if you stay in a remote area.
First download peazip-1.10.bin.LINUX.GTK2.i586-1.rpm and save it to your desktop.
File details:
Link:
http://www.mediafire.com/?czpxzmrjmd5
md5sum c0b89b1106506254f01e3c40af2771b2
Press Alt+F2 and type konsole and press Enter.
At prompt type
cd Desktop
and press Enter
Now type
rpm -ihv peazip-1.10.bin.LINUX.GTK2.i586-1.rpm
and press Enter
After the install press Ctrl+D twice in succession.
Then download these two files (yes, you require both of them simultaneously in the same folder on your pc), and save it to your Home directory.
File details:
File 1 - Mirror 1
md5sum 58454afcd0b5db3168f46e497b5c3cae
File 2 - Mirror 1
md5sum 31915b5190e9b30ef787c779de13ce4d
Double click on piece 001 and extract to your home directory. You should now see a folder called essentials in your home directory.
Press Alt+F2, type yast and press Enter, key in your root password and press Enter. This is one way of opening YaST, the system administration panel of OpenSuSE. Click on Software Repositories
Click on Add
Select Local Directory, uncheck download repository description files and click next
Give the repository a name, I have given the name essentials, click browse and browse to that folder and click Open, and check the checkbox that says plain rpm directory
This is what you will get, just select essentials and see if automatically refresh is checked, if not checked do so, and click Finish
Now open YaST->software Management and in the search box
type, search and check the following:
Adobe flash player - search for flash
Realplayer - search for real player
Acrobat Reader - search for acroread
Java - search for sun and tick java_1_5_0-sun
Kaffeine - search for kaffeine, kaffeine-mozilla, libxine, and w32 and check each of the results you get. If already ticked by default, click on the check mark once to get an update sign
XMMS - search for xmms
K3b - search for k3b and check k3b and k3b codecs. If already ticked by default, click on the check mark once to get an update sign
DeVeDe - search for devede and check the same
Audacity - search for audacity and check the same
AviDemux - search for avidemux and check the same
FFMPEG - search for ffmpeg and check the same
Transcode - search for transcode and check the same
kdeadmin - search for kdeadmin and check the same
libdvdcss - search for libdvdcss and check the same
vlc - search for vlc and check the same
amarok - search for amarok and click on the check mark once to get an update sign
ntfs-config - search for ntfs-config and check the same
Click Accept
ntfs-config setup: Go to KMenu->Applications->New Applications->Configuration Tool NTFS Configuration Tool (it will be at the bottom of the New Applications List)
Key in your root password when asked for and enable by checking in the checkboxes for internal and/or external drives.
Fonts - If you want to use windows fonts like Times New Roman:
and press enter.
You will get a Konqueror browser as a super user.
Make a new folder called core in /usr/share/fonts and copy all the TTF fonts from your C:/windows/fonts to it.
Click on Configure Desktop in KMenu->System administration->font installer->click administrator mode button below->give root password,
click on add, browse to /usr/share/fonts/core, select all by pressing Ctrl+A, and click ok.
Other irritants:
SuSE can be real slow even on mid-end systems. To overcome this you can do the following:
Click on KMenu->
Configure Desktop->Appearance and Themes->Style->Light Style 3rd revision->Apply
Configure Desktop->Window decorations->Plastik->Apply
Update Feb 2008
Archive contents:
a52dec-0.7.4-3.pm.3.x86_64.rpm
aften-0.08-0.pm.2.x86_64.rpm
amarok-1.4.8-18.1.x86_64.rpm
amarok-lang-1.4.8-100.pm.2.x86_64.rpm
amarok-xine-1.4.8-18.1.x86_64.rpm
amarok-yauap-1.4.8-18.1.x86_64.rpm
amrnb-7.0.0.0-0.pm.1.x86_64.rpm
amrwb-7.0.0.2-0.pm.1.x86_64.rpm
audacity-1.3.4-2.pm.beta.x86_64.rpm
avidemux-2.4-0.pm.4.x86_64.rpm
coreutils-6.9-43.x86_64.rpm
dcatools-0.0.5-3.i586.rpm
devede-3.6-0.pm.1.noarch.rpm
dvdauthor-0.6.14-0.pm.2.x86_64.rpm
faac-1.25-0.pm.4.x86_64.rpm
faad2-2.5-1.pm.1.x86_64.rpm
ffmpeg-0.4.9-9.pm.svn20071229.x86_64.rpm
fftw-2.1.5-117.x86_64.rpm
glibc-2.6.1-18.x86_64.rpm
glibc-32bit-2.6.1-18.x86_64.rpm
gmpc-libnotify-0.15.5.0-0.pm.1.x86_64.rpm
iso-codes-1.0a-49.noarch.rpm
k3b-1.0.4-2.1.pm.0.x86_64.rpm
k3b-codecs-1.0.4-2.1.pm.0.x86_64.rpm
k3b-lang-1.0.4-2.1.pm.0.x86_64.rpm
kaffeine-0.8.5-35.pm.0.x86_64.rpm
kaffeine-mozilla-0.2-0.pm.1.x86_64.rpm
kdemultimedia3-3.5.8-8.3.x86_64.rpm
lame-3.97-3.x86_64.rpm
libcaca-0.9_0.99.beta13-0.pm.0.x86_64.rpm
libcddb-1.3.0-60.x86_64.rpm
libcurl4-32bit-7.16.4-16.x86_64.rpm
libcurl4-7.16.4-15.x86_64.rpm
libdc1394_control12-1.2.2-1.x86_64.rpm
libdca0-0.0.5-3.i586.rpm
libdvbpsi5-0.1.6-1.pm.3.x86_64.rpm
libdvdcss-1.2.9-5.3.x86_64.rpm
libdvdnav-0.1.10-75.x86_64.rpm
libexpat0-1.95.8-32.x86_64.rpm
libexpat1-2.0.1-24.x86_64.rpm
libexpat1-32bit-2.0.1-24.x86_64.rpm
libfame-0.9.1-0.pm.8.x86_64.rpm
libffmpeg0-0.4.9-9.pm.svn20071229.x86_64.rpm
libgcc42-32bit-4.2.1_20070724-17.x86_64.rpm
libgcc42-4.2.1_20070724-17.x86_64.rpm
libgpod3-0.6.0-100.pm.6.x86_64.rpm
libgsm-1.0.10-72.x86_64.rpm
libid3tag-0.15.1b-95.x86_64.rpm
libifp4-1.0.0.2-0.pm.3.x86_64.rpm
libifp-tools-1.0.0.2-0.pm.3.x86_64.rpm
libiso9660-5-0.78.2-4.x86_64.rpm
libmms0-0.4-0.pm.2.x86_64.rpm
libmp4v2-1.5.0.1-10.pm.0.x86_64.rpm
libmpeg2-0.4.1-0.pm.4.i586.rpm
libmpeg2-0.4.1.1149-3.1.x86_64.rpm
libmpeg2-devel-0.4.1.1149-3.1.x86_64.rpm
libmspack-0.0.20060920alpha-51.x86_64.rpm
libmtp7-0.2.4-0.pm.4.x86_64.rpm
libmusicbrainz4-2.1.5-3.x86_64.rpm
libofa-0.9.3-59.x86_64.rpm
libOggFLAC++2-1.1.2-21.x86_64.rpm
libOggFLAC3-1.1.2-21.x86_64.rpm
liboggz-0.9.5-0.pm.1.x86_64.rpm
libraw1394-8-1.2.1-64.x86_64.rpm
libsexy-0.1.11-55.x86_64.rpm
libstdc++42-32bit-4.2.1_20070724-17.x86_64.rpm
libtar-1.2.11-0.pm.3.x86_64.rpm
libtunepimp-0.5.3-100.pm.7.x86_64.rpm
libtunepimp5-0.5.3-100.pm.7.x86_64.rpm
libtunepimp5-mad-0.5.3-100.pm.7.x86_64.rpm
libtunepimp5-mp4-0.5.3-100.pm.7.x86_64.rpm
libwnck-1-22-2.20.0-4.x86_64.rpm
libwnck-2.20.0-4.x86_64.rpm
libx264-57-0.0svn20071225-0.pm.1.x86_64.rpm
libxine1-1.1.8-0.pm.5.x86_64.rpm
lirc-0.7.2-0.pm.0.x86_64.rpm
mad-0.15.1b-1.pm.5.x86_64.rpm
MPlayer-1.0rc2-2.pm.0.x86_64.rpm
notification-daemon-0.3.7-65.x86_64.rpm
ntfs-config-1.0.1-14.x86_64.rpm
pvm-3.4.5-89.x86_64.rpm
speex-1.1.99_1.2beta1-0.pm.0.x86_64.rpm
transcode-1.0.4-0.pm.0.x86_64.rpm
twolame-0.3.10-0.pm.2.x86_64.rpm
vcdimager-0.7.23-83.x86_64.rpm
vlc-0.8.6d-7.1.x86_64.rpm
w32codec-all-20071007-0.pm.1.i586.rpm
wxGTK-2.8.4.0-53.x86_64.rpm
x264-0.0svn20071225-0.pm.1.x86_64.rpm
xmms-1.2.11-1.pm.1.x86_64.rpm
xmms-lib-1.2.11-1.pm.1.x86_64.rpm
xosd-2.2.12-113.x86_64.rpm
xvid-1.1.3-0.pm.0.x86_64.rpm
zlib-1.2.3-75.x86_64.rpm
Sources:
http://peazip.sourceforge.net
http://packman.links2linux.org/
http://download.opensuse.org/reposit...openSUSE_10.3/
http://download.videolan.org/pub/vlc/SuSE/10.3/
