Old 24-12-2007, 09:00 PM   #1 (permalink)
Shikher_neo's Avatar
Default HAL missing help pleeeeaaaase
i installed open SUSE to override a malfunctioned linux that was not working but now when i select windows it says hal missing i tried to repaor it by editing the right partition no.in boot.ini howver suse doesn't allow me to do so saying i did ot hav the permissions.i am really fed up with this thingnow.pleease help me.and can i do something with the Ultimate Boot CD.i do not know how to use it(i have windows xp as well as 98 but couldn't find the boot.ini file in xp)
God Does Not Play Dice
-Albert Einstein
Shikher_neo is offline
Old 24-12-2007, 09:05 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: HAL missing help pleeeeaaaase
yep it can be repaired by editing the boot.ini file and chaging it to right partition.
anyways try logging in as root and then edit.
sudo is the command we use to becpme root in ubuntu\debian I am not sure about suse,let some pro chip in.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 24-12-2007, 09:07 PM   #3 (permalink)
and how do u enter as root it doesn't ask for a user name
-Albert Einstein
Old 24-12-2007, 09:10 PM   #4 (permalink)
open up terminal type su then enter it will ask for password enter it.
or else try doing: sudo nautilus (if you use gnome) a windows will pop up,just locate the boot.ini file from taht window itself and then make the necessary changes.hope this helps.
Old 24-12-2007, 09:15 PM   #5 (permalink)
hey how do you recgnize which is the required partition(i.e. drive).one more thing.since i could not locate boot.ini in xp i am talking abt 98.will it work?and when i select 98 in the option given for selecting windows version it goes blank and nothing happens any clue?
-Albert Einstein
Old 24-12-2007, 09:19 PM   #6 (permalink)
^^nope I don't think anybody can help you if you cannot recognise your windows partition,trial and error methid is what is left.
but wth why couldn't you locate your boot.ini file?try searching for it.
BTW did sudo nautilus work?
Old 24-12-2007, 10:10 PM   #7 (permalink)
well the su command worked but the nautilus one didnot and now i have found that the boot.ini file of xp is totally BLANK.can u tell what should it have(the content)and do i really need to do something about hal?
-Albert Einstein
Old 24-12-2007, 10:57 PM   #8 (permalink)
No idea about the contents of boot.ini file.But people facing the same problem solved it by just changing the partition no. in boot.ini file.
Old 24-12-2007, 11:29 PM   #9 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Pls go thru Point 8:
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
May be it'll help you?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-12-2007, 11:32 PM   #10 (permalink)
^^well that would reinstall windows bootloader I guess and then he won't be able to boot into opensuse.
arunks faced the same exact problem,he just edited his boot.ini file(changed the partition no.) but this guy couldn't locate his boot.ini file.strange.
Old 25-12-2007, 12:50 AM   #11 (permalink)
well i have figured out a little bit.the xp file appeared to be blank because it wasn't there the terminal creaed a new file with that name as there was no such file .one question .would it work fine if i do not have a boot file in xp.it is there in 98 and since the menu.lst is linked with 98(perhaps) xp should be accesible one more thing this partition no.starts with 0 or1?
-Albert Einstein
Missing anything ?? red_devil QnA (read only) 2 14-10-2007 05:36 PM
Admdll.dll missing Krish_88 Software Q&A 13 30-01-2007 11:47 PM
missing OS rounit QnA (read only) 2 28-09-2006 02:27 PM
Boot.ini tab is missing abhijitroy Software Q&A 1 12-02-2006 02:13 PM
30 GB missing!!!!! computerwizard QnA (read only) 14 05-07-2005 05:54 AM
