Old 19-12-2007, 06:37 PM   #1 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile ubuntu not showing up in normal mode
hi
i have ubuntu 7.04 on my sys now the problem is that when i boot into its default
mode "ubuntu" after ubuntu boot screen nothing comes up total blank screen
earlier it use to work perfectly
as of result of this problem i have to boot into recovery mode from which i m able to work on Gui
whats the problem plz suggest
saurabh kakkar is offline
Old 19-12-2007, 09:30 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: ubuntu not showing up in normal mode
When the Ubuntu picture appears with a orange moving bar, press Alt + F2 to see the diagonistic messages and then post what error is happenning ?
debsuvra is offline
Old 20-12-2007, 04:17 PM   #3 (permalink)
Married!
Rahim's Avatar
Default Re: ubuntu not showing up in normal mode
While working in Recovery Mode, check /etc/usplash.conf file and see if the resolution is set properly. Paste its content here.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 20-12-2007, 06:07 PM   #4 (permalink)
adi007's Avatar
i have a suggestion.. don't know if it will solve ur problem or not..
edit the boot menu by pressing 'e'
no go to the line kernel and press 'e'...
go to the end of the line and delete splash silent or something after ro or rw..
press esc and press 'b' to test..
if this works the u have to edit the /boot/menu.lst file...
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
My system Tempratures in ubuntu, are they normal?? gary4gar Open Source 9 25-06-2007 02:33 PM
Windows Vista boots into Normal Mode but that there are still problems with Windows. sabret00the Tutorials 7 28-10-2006 02:33 PM
HELP:Optical Drive doesnt work in Normal mode works inSafeMo maximus999 QnA (read only) 4 15-03-2006 02:45 AM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
what is standby mode and hibernate mode.. thegame_rulez QnA (read only) 1 16-03-2005 11:46 AM
