Old 19-12-2007, 02:48 PM   #1 (permalink)
Shikher_neo's Avatar
Default Uninstalling linux help me!
Hey
i instal fedora but forgot the password.however then the option for windows stoppd coming and i was presented with a screen with only grub on it.i deleted the files in its partition from DSL however it didi nt help.please help me bring windows back!
God Does Not Play Dice
-Albert Einstein
Shikher_neo is offline
Old 19-12-2007, 02:56 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Uninstalling linux help me!
Reinstall fedora on the relevant partition and then makin windows appear on grub is a piece of cake then!
mediator is offline
Old 19-12-2007, 02:57 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
go to recovery console and perform fixmbr
Gigacore is offline
Old 19-12-2007, 02:58 PM   #4 (permalink)
nach p's Avatar
Insert xp (assuming) bootable cd.
Choose repair option i.e. click R
When u get to the console type fixmbr
Now u will be able 2 login to windows.
Then use either default Disk management utility or Partition magic soft to for mat linux partitions
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 19-12-2007, 03:03 PM   #5 (permalink)
how can do anything when i cant enter windows or do anything on that grub sreen.it does not show anything but grub in command line fashion.and isn't there some way out of the windows cd?and can it be done with atleast the windows cd(not live)?
-Albert Einstein
Old 19-12-2007, 09:43 PM   #6 (permalink)
SivaChand
Thumbs up Re: Uninstalling linux help me!
You must formatting the linux partition needed... I hav the same pro before a month... I format the linux partition using the segate partition manager with Windows 98 cd.... I hope this info helpful...
kpmsivachand is offline
Old 20-12-2007, 06:44 PM   #7 (permalink)
adi007's Avatar
Hey
u could have changed the password by entering single user mode..
so there was no need to do all these..
that's the same i would suggest..
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 20-12-2007, 08:04 PM   #8 (permalink)
Krazy_About_Technology's Avatar
Are yaar, there are three possibilities:
1. if you deleted linux files or partition accidentally and want to keep linux then you can reinstall it again and it will restore the boot loader.
2. If you haven't deleted linux yet and the grub installation itself is corrupt then boot your computer from your linux cd/dvd into rescue mode. There do a chroot to your installation and then run grub-install to reinstall grub.
3. If you have deleted linux and just want to have only windows on your computer then boot from the Windows CD and enter into Recovery Console. From there run the commands FixBoot and FixMBR. This will reinstall the Windows bootloader.
For all of these methods you need to boot from your cd. If you have selected Harddisk as the first boot device then you'll have to change it from BIOS. At the time of booting, press f2, f8 or whatever is the key combionatio for entering your bios (it generally shows in the last line on screen while booting ) and from there set the First Boot Device to CDROM. Save and exit setup and insert your cd to boot from it.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 20-12-2007, 08:56 PM   #9 (permalink)
When u boot from xp installation CD and then use the fixmbr command in the recovery console,u won't get the grub screen and u will directly boot into Windows XP when u restart ur computer.
There right click my computer...click manage->in the window that opens select DISC MANAGEMENT or something like that in the left frame->in the right frame u will see ur linux partition as unknown partition...Delete it and then recreate it and format it as NTFS(or FAT ur choice).
But now ur fedora installation is gone. otherway is to modify GRUB list manually and add ur XP installation in it. Google for it.
hope this helps
silent008 is offline
Old 23-12-2007, 12:43 AM   #10 (permalink)
can i do this reformat thing with linux say SUSE?i got to the recovery option of suse live cd but didn't kno the command
-Albert Einstein
Uninstalling linux Shikher_neo Open Source 1 09-11-2007 06:37 AM
Uninstalling Linux (FC4) and partitioning XP ashu888ashu888 Open Source 7 29-07-2006 08:46 PM
Uninstalling Linux aditya.shevade Open Source 1 16-07-2006 07:25 PM
Uninstalling Linux Aijaz Akhtar Open Source 1 23-06-2005 04:54 PM
uninstalling OS?? mario_pant QnA (read only) 6 14-04-2005 10:41 PM
