Old 18-12-2007, 08:15 PM   #1 (permalink)
never forgot your roots!
Default network connection 'n' shortcut in linux?
hi! tell me how to make a network connection in linux as made in windows means i can connect 'n' dissconnect manually as to use free rapidshare downloading 'n' can i create shortcut on desktop or menu rather than assigning a static ip connection specially using broadband
SUKHI99 is offline
Old 18-12-2007, 10:22 PM   #2 (permalink)
nach p's Avatar
Default Re: network connection 'n' shortcut in linux?
can you please give some details
which broadband do u use ? do they provide any packages for installation in linux.
you can download free from rapidshare by disconnecting n connecting again and also u can create shortcut (soft link)
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 19-12-2007, 06:18 AM   #3 (permalink)
i use BSNL BB 'n' in windows i download from rapidshare as u told since a long time 'n' can i download using this method in linux (OpENSuSE 10.3) or ubuntu 7.10 plz tell me how to do i! previously i connect to net in ubuntu using some method from net. now i'm in examz after that i'll install both these distro permanently along with window so help me
SUKHI99 is offline
Old 19-12-2007, 10:28 AM   #4 (permalink)
Married!
Rahim's Avatar
I am using Ubuntu 7.10, so i will give instructions about Ubuntu only.
First install pppoeconf through Synaptic.
Open a Terminal and type
sudo pppoeconf
. It will ask for Root Password. Enter your password when prompted.A Blue Window will pop-up.
The first page would recognise your ethernet as etho> continue to next will check for connection> till you get to username page. Enter your username like xyz@dataone , remember .in is not required. Next enter your Password. COntiue further without changing anything. Select No when asked for BootUp Connection.
To connect enter in the Terminal
pon dsl-provider
To Disconnect enter
poff
You can create Shortcuts on the Desktop. Enter the respective commands in the command option. To create shortcuts Right-Click oon the Desktop and select "Create launcher"
For Detail Instructions Click https://help.ubuntu.com/community/ADSLPPPoE
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 19-12-2007, 10:59 AM   #5 (permalink)
Think Zen.
ray|raven's Avatar
Or you could install rp-pppoe frontend.
Read here on how to do it: http://www.ubuntux.org/how-to-instal...lient-rp-pppoe
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 19-12-2007, 11:42 AM   #6 (permalink)
in search of myself
CadCrazy's Avatar
or GnomePPP
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Shortcut creation in linux - FC7 pradeepbp Open Source 4 30-09-2007 07:59 PM
Xubuntu - Network Monitor for GPRS connection sariq Open Source 3 15-11-2006 09:39 AM
Lost my cable and dial up network connection icons ? mkmkmk Networking 3 28-04-2006 12:40 PM
