18-12-2007, 04:21 PM
GaurishSharma.com
VIA UniChrome Pro Display Driver ver 0.8
Originally Posted by ubuntuforums.org
VIA recently released their binary driver for their integrated graphics for linux. To install it:
1. I downloaded the driver from http://www.viaarena.com/default.aspx?PageID=2&Type=3.
2. Choose your distro.
3. Then pick Integrated Graphics.
4. Pick the appropriate driver category. If you are not sure which one, check this site http://www.viaarena.com/default.aspx...ticleID=68&P=5.
5. Click on "Click here to begin free download." Save it.
6. Unzip the file.
7. Make a backup of your xorg.conf.
8. CD to the directory where you unzipped the file to.
9. Execute the *.run file. example "sudo sh VIA_U710_UniChrome-GFX-v40072d.run"
10. Ctrl-Alt-Bckspce
That's it. You should be able to run wine and other 3D applications.
http://ubuntuforums.org/showthread.php?t=636368
https://bugs.launchpad.net/ubuntu/+s...via/+bug/43154
sounds like a dream, but it didn't work for me
did it work for any else?
18-12-2007, 05:36 PM
left this forum longback
Re: VIA UniChrome Pro Display Driver ver 0.8
@gauri:try installing!make sure all dependencies are installed.also choose correct driver.does this driver supports 3D  ?
I gave up with my via board on Linux.now using intel 915GV chipset based board.
18-12-2007, 10:12 PM
GaurishSharma.com
they have very tall claims, in the reame me it says it also supports Compiz-fusion
can you help me building & installing the new driver?
18-12-2007, 10:15 PM
^hidden mode
So...Hope the first compiz screenshot from a via gfx here
18-12-2007, 10:52 PM
GaurishSharma.com
Originally Posted by praka123
^hidden mode
not so soon
i tried but the system hangs
can you help me complie from the source?
19-12-2007, 12:18 AM
afaik via drivers needs root access for DRI to work.
tell me which chipset are ur onboard gfx based on from this page below:
http://www.viaarena.com/default.aspx...=43&CatID=3190
You can find ur chipset from /var/log/Xorg.0.log  post it here.before that i hope ur in ubuntu
do when internet is connected "sudo apt-get update && sudo apt-get build-essential".
19-12-2007, 10:31 AM
GaurishSharma.com
i was not using ubuntu rather a alpha version of a distro but just now did a freash install of gutsy from DVD.
my chipset is VIA K8m800+VIA 8237
the source drivers: VIA Linux K8M64XF41061 Driver kernel Source Code
which date a release date of 02 December 2005
Binary driver for Ubuntu:
VIA UniChrome Pro Driver Binary
Version - 0.8 04 December 2007
attached installion readme for driver binary
also i didn't try the root thingy
right now my xorg file looks like
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Section "Device"
Identifier "VIA Technologies, Inc. S3 Unichrome Pro VGA Adapter"
Driver "via"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-64
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "VIA Technologies, Inc. S3 Unichrome Pro VGA Adapter"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
# Uncomment if you have a wacom tablet
# InputDevice "stylus" "SendCoreEvents"
# InputDevice "cursor" "SendCoreEvents"
# InputDevice "eraser" "SendCoreEvents"
EndSection
gaurish@MOODY-MACHINE:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_EXT_texture_from_pixmap
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (2.1 Mesa 7.0.1)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_fragment_program,
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_program,
GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
GL_ATI_draw_buffers, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_fragment_program, GL_NV_light_max_exponent, GL_NV_point_sprite,
GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x22 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x24 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x3e 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
gaurish@MOODY-MACHINE:~$ cat /var/log/Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Ubuntu (xorg-server 2:1.3.0.0.dfsg-12ubuntu8)
Current Operating System: Linux MOODY-MACHINE 2.6.22-14-generic #1 SMP Sun Oct 14 23:05:12 GMT 2007 i686
Build Date: 29 September 2007
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 19 09:52:32 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "VIA Technologies, Inc. S3 Unichrome Pro VGA Adapter"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81ea440
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0204 card 1106,0204 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:00:1: chip 1106,1204 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:2: chip 1106,2204 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:3: chip 1106,3204 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:4: chip 1106,4204 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:7: chip 1106,7204 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b188 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0a:0: chip 134d,2189 card 134d,1002 rev 04 class 07,03,00 hdr 00
(II) PCI: 00:0f:0: chip 1106,3149 card 1462,7142 rev 80 class 01,04,00 hdr 80
(II) PCI: 00:0f:1: chip 1106,0571 card 1462,7142 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 1462,7142 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 1462,7142 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 1462,7142 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3038 card 1462,7142 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:4: chip 1106,3104 card 1462,7142 rev 86 class 0c,03,20 hdr 80
(II) PCI: 00:11:0: chip 1106,3227 card 1106,3227 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:5: chip 1106,3059 card 1462,0430 rev 60 class 04,01,00 hdr 00
(II) PCI: 00:12:0: chip 1106,3065 card 1462,7142 rev 78 class 02,00,00 hdr 00
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 1106,3108 card 1462,7142 rev 01 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) unknown vendor (0x1106) unknown chipset (0x3108) rev 1, Mem @ 0xf0000000/26, 0xf4000000/24
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe8000000 from 0xefffffff to 0xe7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xf6002000 - 0xf60020ff (0x100) MX[B]
[1] -1 0 0xf6001000 - 0xf60010ff (0x100) MX[B]
[2] -1 0 0xf6000000 - 0xf6000fff (0x1000) MX[B]
[3] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[4] -1 0 0xf4000000 - 0xf4ffffff (0x1000000) MX[B](B)
[5] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B](B)
[6] -1 0 0x0000ed00 - 0x0000edff (0x100) IX[B]
[7] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[8] -1 0 0x0000eb00 - 0x0000eb1f (0x20) IX[B]
[9] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
[10] -1 0 0x0000e900 - 0x0000e91f (0x20) IX[B]
[11] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[12] -1 0 0x0000e700 - 0x0000e70f (0x10) IX[B]
[13] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[14] -1 0 0x0000e500 - 0x0000e50f (0x10) IX[B]
[15] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[16] -1 0 0x0000e300 - 0x0000e307 (0x8) IX[B]
[17] -1 0 0x0000e200 - 0x0000e203 (0x4) IX[B]
[18] -1 0 0x0000e100 - 0x0000e107 (0x8) IX[B]
[19] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf6002000 - 0xf60020ff (0x100) MX[B]
[5] -1 0 0xf6001000 - 0xf60010ff (0x100) MX[B]
[6] -1 0 0xf6000000 - 0xf6000fff (0x1000) MX[B]
[7] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[8] -1 0 0xf4000000 - 0xf4ffffff (0x1000000) MX[B](B)
[9] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B](B)
[10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[12] -1 0 0x0000ed00 - 0x0000edff (0x100) IX[B]
[13] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[14] -1 0 0x0000eb00 - 0x0000eb1f (0x20) IX[B]
[15] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
[16] -1 0 0x0000e900 - 0x0000e91f (0x20) IX[B]
[17] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[18] -1 0 0x0000e700 - 0x0000e70f (0x10) IX[B]
[19] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[20] -1 0 0x0000e500 - 0x0000e50f (0x10) IX[B]
[21] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[22] -1 0 0x0000e300 - 0x0000e307 (0x8) IX[B]
[23] -1 0 0x0000e200 - 0x0000e203 (0x4) IX[B]
[24] -1 0 0x0000e100 - 0x0000e107 (0x8) IX[B]
[25] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.3.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "via"
(II) Loading /usr/lib/xorg/modules/drivers//via_drv.so
(II) Module via: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.2.1
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
(II) VIA: driver for VIA chipsets: CLE266, KM400/KN400, K8M800,
PM800/PM880/CN400
(II) Primary Device is: PCI 01:00:0
(--) Chipset K8M800 found
(!!) VIA Technologies does not support or endorse this driver in any way.
(!!) For support please contact the driver maintainer or your X vendor.
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[10] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[11] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[12] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000ed00 - 0x0000edff (0x100) IX[B]
[16] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[17] -1 0 0x0000eb00 - 0x0000eb1f (0x20) IX[B]
[18] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
[19] -1 0 0x0000e900 - 0x0000e91f (0x20) IX[B]
[20] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[21] -1 0 0x0000e700 - 0x0000e70f (0x10) IX[B]
[22] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[23] -1 0 0x0000e500 - 0x0000e50f (0x10) IX[B]
[24] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[25] -1 0 0x0000e300 - 0x0000e307 (0x8) IX[B]
[26] -1 0 0x0000e200 - 0x0000e203 (0x4) IX[B]
[27] -1 0 0x0000e100 - 0x0000e107 (0x8) IX[B]
[28] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[29] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[30] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.1.0
(**) VIA(0): Depth 24, (--) framebuffer bpp 32
(==) VIA(0): RGB weight 888
(==) VIA(0): Default visual is TrueColor
(==) VIA(0): Using XAA acceleration architecture
(==) VIA(0): Using HW cursor
(--) VIA(0): Chipset: "K8M800"
(--) VIA(0): mapping MMIO @ 0xf4000000 with size 0x9000
(--) VIA(0): mapping BitBlt MMIO @ 0xf4200000 with size 0x10000
(II) VIA(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(--) VIA(0): Chipset Rev.: 0
(--) VIA(0): Detected MSI K8MM-V.
(==) VIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) VIA(0): videoram = 65536k
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module already built-in
(II) VIA(0): I2C bus "I2C bus 1" initialized.
(II) VIA(0): I2C bus "I2C bus 2" initialized.
(II) VIA(0): I2C bus "I2C bus 3" initialized.
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module already built-in
(II) VIA(0): I2C device "I2C bus 1:ddc2" registered at address 0xA0.
(II) VIA(0): I2C device "I2C bus 1:ddc2" removed.
(II) VIA(0): Manufacturer: SAM Model: 117 Serial#: 1279406391
(II) VIA(0): Year: 2005 Week: 20
(II) VIA(0): EDID Version: 1.3
(II) VIA(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) VIA(0): Sync: Separate
(II) VIA(0): Max H-Image Size [cm]: horiz.: 31 vert.: 23
(II) VIA(0): Gamma: 2.20
(II) VIA(0): DPMS capabilities: Off; RGB/Color Display
(II) VIA(0): Default color space is primary color space
(II) VIA(0): First detailed timing is preferred mode
(II) VIA(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
(II) VIA(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
(II) VIA(0): Supported VESA Video Modes:
(II) VIA(0): 720x400@70Hz
(II) VIA(0): 640x480@60Hz
(II) VIA(0): 640x480@67Hz
(II) VIA(0): 640x480@72Hz
(II) VIA(0): 640x480@75Hz
(II) VIA(0): 800x600@56Hz
(II) VIA(0): 800x600@60Hz
(II) VIA(0): 800x600@72Hz
(II) VIA(0): 800x600@75Hz
(II) VIA(0): 832x624@75Hz
(II) VIA(0): 1024x768@60Hz
(II) VIA(0): 1024x768@70Hz
(II) VIA(0): 1024x768@75Hz
(II) VIA(0): 1152x870@75Hz
(II) VIA(0): Manufacturer's mask: 0
(II) VIA(0): Supported Future Video Modes:
(II) VIA(0): #0: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) VIA(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) VIA(0): #2: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) VIA(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) VIA(0): #4: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) VIA(0): Supported additional Video Mode:
(II) VIA(0): clock: 94.5 MHz Image Size: 312 x 234 mm
(II) VIA(0): h_active: 1024 h_sync: 1072 h_sync_end 1168 h_blank_end 1376 h_border: 0
(II) VIA(0): v_active: 768 v_sync: 769 v_sync_end 772 v_blanking: 808 v_border: 0
(II) VIA(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 71 kHz, PixClock max 110 MHz
(II) VIA(0): Monitor name: SyncMaster
(II) VIA(0): Serial No: HHAY525998
(II) VIA(0): EDID (in hex):
(II) VIA(0): 00ffffffffffff004c2d17013731424c
(II) VIA(0): 140f0103681f17782eee91a3544c9926
(II) VIA(0): 0f5054bfee806159455931598180714f
(II) VIA(0): 010101010101ea240060410028303060
(II) VIA(0): 130038ea1000001e000000fd0032a01e
(II) VIA(0): 470b000a202020202020000000fc0053
(II) VIA(0): 796e634d61737465720a2020000000ff
(II) VIA(0): 00484841593532353939380a202000ff
(II) VIA(0): Using hsync ranges from config file
(II) VIA(0): Using vrefresh ranges from config file
(II) VIA(0): Printing DDC gathered Modelines:
(II) VIA(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
(II) VIA(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
(II) VIA(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
(II) VIA(0): Modeline "640x480" 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
(II) VIA(0): Modeline "640x480" 30.24 640 704 768 864 480 483 486 525 -hsync -vsync
(II) VIA(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
(II) VIA(0): Modeline "720x400" 28.32 720 738 846 900 400 412 414 449 -hsync +vsync
(II) VIA(0): Modeline "1024x768" 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
(II) VIA(0): Modeline "1024x768" 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
(II) VIA(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
(II) VIA(0): Modeline "832x624" 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
(II) VIA(0): Modeline "800x600" 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
(II) VIA(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
(II) VIA(0): Modeline "1152x864" 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
(II) VIA(0): Modeline "1024x768" 94.50 1024 1096 1200 1376 768 771 775 809 -hsync +vsync
(II) VIA(0): Modeline "800x600" 56.75 800 848 928 1056 600 603 607 633 -hsync +vsync
(II) VIA(0): Modeline "640x480" 35.00 640 664 728 816 480 483 487 507 -hsync +vsync
(II) VIA(0): Modeline "1280x1024" 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
(II) VIA(0): Modeline "1152x864" 104.00 1152 1224 1344 1536 864 867 871 905 -hsync +vsync
(II) VIA(0): Modeline "1024x768" 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
(II) VIA(0): Generic Monitor: Using hsync range of 28.00-64.00 kHz
(II) VIA(0): Generic Monitor: Using vrefresh range of 43.00-60.00 Hz
(II) VIA(0): Clock range: 20.00 to 230.00 MHz
(II) VIA(0): Not using default mode "640x350" (vrefresh out of range)
(II) VIA(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "640x400" (vrefresh out of range)
(II) VIA(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "720x400" (vrefresh out of range)
(II) VIA(0): Not using default mode "360x200" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "640x480" (vrefresh out of range)
(II) VIA(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "800x600" (vrefresh out of range)
(II) VIA(0): Not using default mode "1024x768" (interlace mode not supported)
(II) VIA(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1024x768" (vrefresh out of range)
(II) VIA(0): Not using default mode "1024x768" (hsync out of range)
(II) VIA(0): Not using default mode "1152x864" (hsync out of range)
(II) VIA(0): Not using default mode "576x432" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "640x480" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1280x960" (hsync out of range)
(II) VIA(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) VIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) VIA(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) VIA(0): Not using default mode "896x672" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) VIA(0): Not using default mode "928x696" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "832x624" (vrefresh out of range)
(II) VIA(0): Not using default mode "416x312" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "640x384" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "640x400" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "576x384" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1400x1050" (hsync out of range)
(II) VIA(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan)
(II) VIA(0): CrtcHSyncEnd out of range.
(II) VIA(0): Not using default mode "1400x1050" (horizontal sync too wide)
(II) VIA(0): Not using default mode "1440x900" (horizontal sync too wide)
(II) VIA(0): Not using default mode "720x450" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "800x512" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1680x1050" (hsync out of range)
(II) VIA(0): Not using default mode "840x525" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1920x1200" (hsync out of range)
(II) VIA(0): Not using default mode "960x600" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) VIA(0): Not using driver mode "640x480" (vrefresh out of range)
(II) VIA(0): Not using driver mode "720x400" (vrefresh out of range)
(II) VIA(0): Not using driver mode "1024x768" (vrefresh out of range)
(II) VIA(0): Not using driver mode "832x624" (vrefresh out of range)
(II) VIA(0): Not using driver mode "800x600" (vrefresh out of range)
(II) VIA(0): Not using driver mode "1152x864" (hsync out of range)
(II) VIA(0): Not using driver mode "1024x768" (hsync out of range)
(--) VIA(0): Virtual size is 1280x1024 (pitch 1280)
(**) VIA(0): *Driver mode "1280x1024": 109.0 MHz (scaled from 0.0 MHz), 63.7 kHz, 59.9 Hz
(**) VIA(0): *Driver mode "1024x768": 65.0 MHz (scaled from -0.0 MHz), 48.4 kHz, 60.0 Hz
(**) VIA(0): *Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
(**) VIA(0): *Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(**) VIA(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) VIA(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
(**) VIA(0): Default mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
(II) VIA(0): Modeline "1280x960" 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
(**) VIA(0): Default mode "1280x800": 83.5 MHz (scaled from 0.0 MHz), 49.7 kHz, 60.0 Hz
(II) VIA(0): Modeline "1280x800" 83.46 1280 1344 1480 1680 800 801 804 828
(**) VIA(0): Default mode "1280x768": 80.1 MHz (scaled from 0.0 MHz), 47.7 kHz, 60.0 Hz
(II) VIA(0): Modeline "1280x768" 80.14 1280 1344 1480 1680 768 769 772 795
(**) VIA(0): Default mode "1152x768": 65.0 MHz (scaled from 0.0 MHz), 44.2 kHz, 54.8 Hz
(II) VIA(0): Modeline "1152x768" 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
(**) VIA(0): Default mode "1024x768": 65.0 MHz (scaled from -0.0 MHz), 48.4 kHz, 60.0 Hz
(**) VIA(0): Driver mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
(**) VIA(0): Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
(**) VIA(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
(**) VIA(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
(II) VIA(0): Modeline "640x480" 25.18 640 656 752 800 480 490 492 525 -hsync -vsync
(**) VIA(0): Display dimensions: (310, 230) mm
(**) VIA(0): DPI set to (104, 113)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module already built-in
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf4000000 - 0xf4ffffff (0x1000000) MS[B]
[1] 0 0 0xf0000000 - 0xf3ffffff (0x4000000) MS[B]
[2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1 0 0xf6002000 - 0xf60020ff (0x100) MX[B]
[7] -1 0 0xf6001000 - 0xf60010ff (0x100) MX[B]
[8] -1 0 0xf6000000 - 0xf6000fff (0x1000) MX[B]
[9] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[10] -1 0 0xf4000000 - 0xf4ffffff (0x1000000) MX[B](B)
[11] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B](B)
[12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000ed00 - 0x0000edff (0x100) IX[B]
[18] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[19] -1 0 0x0000eb00 - 0x0000eb1f (0x20) IX[B]
[20] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
[21] -1 0 0x0000e900 - 0x0000e91f (0x20) IX[B]
[22] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[23] -1 0 0x0000e700 - 0x0000e70f (0x10) IX[B]
[24] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[25] -1 0 0x0000e500 - 0x0000e50f (0x10) IX[B]
[26] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[27] -1 0 0x0000e300 - 0x0000e307 (0x8) IX[B]
[28] -1 0 0x0000e200 - 0x0000e203 (0x4) IX[B]
[29] -1 0 0x0000e100 - 0x0000e107 (0x8) IX[B]
[30] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[31] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[32] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(--) VIA(0): mapping framebuffer @ 0xf0000000 with size 0x4000000
(==) VIA(0): Write-combining range (0xf0000000,0x4000000)
(--) VIA(0): Frame buffer start: 0xb3b6e000, free start: 0x500000 end: 0x4000000
(II) VIA(0): 3D Engine has been initialized.
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
[drm] failed to load kernel module "via"
(II) VIA(0): [drm] drmOpen failed
(EE) VIA(0): [dri] DRIScreenInit failed. Disabling DRI.
(II) VIA(0): VIAInternalScreenInit
(II) VIA(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
8x8 color pattern filled rectangles
Solid Lines
Dashed Lines
Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
31 128x128 slots
24 256x256 slots
7 512x512 slots
32 8x8 color pattern slots
(==) VIA(0): Backing store disabled
(**) Option "dpms"
(**) VIA(0): DPMS enabled
(II) VIA(0): direct rendering disabled
(II) VIA(0): Benchmarking video copy. Less is better.
(--) VIA(0): Timed libc YUV420 copy... 18981483. Throughput: 56.3 MiB/s.
(--) VIA(0): Timed kernel YUV420 copy... 18979006. Throughput: 56.3 MiB/s.
(--) VIA(0): Timed SSE YUV420 copy... 18980700. Throughput: 56.3 MiB/s.
(--) VIA(0): Timed MMX YUV420 copy... 18983191. Throughput: 56.3 MiB/s.
(--) VIA(0): Timed 3DNow! YUV420 copy... 18968865. Throughput: 56.3 MiB/s.
(--) VIA(0): Timed MMX2 YUV420 copy... 18978526. Throughput: 56.3 MiB/s.
(--) VIA(0): Using 3DNow! YUV42X copy for video.
(WW) VIA(0): [XvMC] Cannot use XvMC without DRI!
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(EE) AIGLX: Screen 0 is not DRI capable
(II) Loading local sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "CoreKeyboard"
(**) Generic Keyboard: Core Keyboard
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Generic Keyboard: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Configured Mouse: Sensitivity: 1
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
[edit]
removed invisible mode
bug link: http://bugs.freedesktop.org/show_bug.cgi?id=5092
19-12-2007, 10:45 AM
Think Zen.
Perhaps this might help,
http://sourceforge.net/docman/displa...roup_id=102048
EDIT: Also , i dont see the modules section in ur xorg.
AFAIK,You should load "dri" and "glx" for dri to work.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
20-12-2007, 02:51 AM
GaurishSharma.com
i installed binary driver but
libGL error: open DRM failed (Operation not permitted)
libGL error: reverting to (slow) indirect rendering
i tried running as root but same results
20-12-2007, 11:26 AM
Think Zen.
Check ur xorg.conf,The one u posted doesnt contain the modules section.
AFAIK u need to load "dri","glx" for dri to work.
Regards,
ray
20-12-2007, 01:11 PM
GaurishSharma.com
thats was my old config file prior to installing the driver, the current one after installing the binary driver
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# Edit this file with caution, and see the xorg.conf(5) manual page.
# package.
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "freetype"
Load "int10"
Load "vbe"
Load "extmod"
Load "dri"
Load "glx"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Generic Video Card"
BoardName "via"
VendorName "VIA Tech"
Driver "via"
EndSection
Section "Monitor"
Option "DPMS"
ModeLine "848x480" 47.4 848 888 976 1104 480 481 484 505
ModeLine "1440x1050" 184.5 1440 1544 1704 1968 1050 1051 1054 1103
ModeLine "1280x768" 118.5 1280 1368 1504 1728 768 769 772 807
ModeLine "1440x1050" 160.0 1440 1536 1696 1952 1050 1051 1054 1096
ModeLine "1280x768" 103.0 1280 1360 1496 1712 768 769 772 802
ModeLine "1024x512" 53.3 1024 1072 1176 1328 512 513 516 535
ModeLine "856x480" 41.3 856 888 976 1096 480 481 484 502
ModeLine "848x480" 41.0 848 880 968 1088 480 481 484 502
ModeLine "720x576" 42.6 720 760 832 944 576 577 580 602
ModeLine "720x480" 34.9 720 752 824 928 480 481 484 502
ModeLine "1920x1080" 172.9 1920 2043 2249 2578 1080 1081 1084 1118
ModeLine "1440x1050" 126.2 1440 1536 1688 1936 1050 1051 1054 1087
ModeLine "1440x900" 106.47 1440 1520 1672 1904 900 901 904 932 -HSync +Vsync
ModeLine "1366x768" 85.86 1366 1440 1584 1800 768 769 772 795 -HSync +Vsync
ModeLine "1360x768" 85.50 1360 1392 1712 1744 768 783 791 807 +HSync +Vsync
ModeLine "1280x768" 80.1 1280 1344 1480 1680 768 769 772 795
ModeLine "1280x720" 74.6 1280 1341 1474 1688 720 721 724 746
ModeLine "1024x512" 41.3 1024 1056 1160 1296 512 513 516 531
ModeLine "856x480" 31.7 856 872 960 1064 480 481 484 497
ModeLine "848x480" 31.5 848 864 952 1056 480 481 484 497
ModeLine "800x480" 29.58 800 816 896 992 480 481 484 497
ModeLine "720x576" 32.7 720 744 816 912 576 577 580 597
ModeLine "720x480" 26.7 720 736 808 896 480 481 484 497
#Refresh Rate 60Hz
Identifier "MonitorGeneric Video Card"
EndSection
Section "Screen"
Device "Generic Video Card"
Monitor "MonitorGeneric Video Card"
DefaultDepth 24
Modes "1024x768"
Depth 1
EndSubSection
Modes "1024x768"
Depth 4
EndSubSection
Modes "1024x768"
Depth 8
EndSubSection
Modes "1024x768"
Depth 15
EndSubSection
Modes "1024x768"
Depth 16
EndSubSection
Modes "1024x768"
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
Group 0
EndSection
20-12-2007, 01:25 PM
Think Zen.
That means u dont have enuf priveleges.
Remove the 'Group 0' from the "DRI" Section and try again,
Its not needed AFAIK.
Regards,
ray
20-12-2007, 01:42 PM
GaurishSharma.com
lol, i even tried to login as a root user, but same (Operation not permitted) msg is coming
[edit]
i guess it worked somehow, now the rendering says yes
but there are many other errors, that have crept in
attacthing output
libGL warning: 3D driver claims to not support visual 0x22
libGL warning: 3D driver claims to not support visual 0x23
libGL warning: 3D driver claims to not support visual 0x24
libGL warning: 3D driver claims to not support visual 0x25
libGL warning: 3D driver claims to not support visual 0x26
libGL warning: 3D driver claims to not support visual 0x27
libGL warning: 3D driver claims to not support visual 0x28
libGL warning: 3D driver claims to not support visual 0x29
libGL warning: 3D driver claims to not support visual 0x2a
libGL warning: 3D driver claims to not support visual 0x2b
libGL warning: 3D driver claims to not support visual 0x2c
libGL warning: 3D driver claims to not support visual 0x2d
libGL warning: 3D driver claims to not support visual 0x2e
libGL warning: 3D driver claims to not support visual 0x2f
libGL warning: 3D driver claims to not support visual 0x30
libGL warning: 3D driver claims to not support visual 0x31
direct rendering: Yes
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGI_swap_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
OpenGL vendor string: VIA Technology
OpenGL renderer string: Mesa DRI UniChrome (K8M800) 20060710 x86/MMX+/3DNow!+/SSE2
OpenGL version string: 1.2 Mesa 6.5.1
OpenGL extensions:
GL_ARB_point_parameters, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_histogram,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_light_max_exponent, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_OES_read_format, GL_SGI_color_matrix,
GL_SGI_color_table, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
0x22 24 tc 1 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x23 24 tc 1 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x24 24 tc 1 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x25 24 tc 1 24 0 r . . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x26 24 tc 1 24 0 r y . 8 8 8 0 0 32 0 0 0 0 0 0 0 None
0x27 24 tc 1 24 0 r . . 8 8 8 0 0 32 0 0 0 0 0 0 0 None
0x28 24 tc 1 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x29 24 tc 1 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x2a 24 tc 1 24 0 r y . 8 8 8 0 0 0 0 16 16 16 16 0 0 None
0x2b 24 tc 1 24 0 r . . 8 8 8 0 0 0 0 16 16 16 16 0 0 None
0x2c 24 tc 1 24 0 r y . 8 8 8 0 0 16 0 16 16 16 16 0 0 None
0x2d 24 tc 1 24 0 r . . 8 8 8 0 0 16 0 16 16 16 16 0 0 None
0x2e 24 tc 1 24 0 r y . 8 8 8 0 0 32 0 16 16 16 16 0 0 None
0x2f 24 tc 1 24 0 r . . 8 8 8 0 0 32 0 16 16 16 16 0 0 None
0x30 24 tc 1 24 0 r y . 8 8 8 0 0 24 8 16 16 16 16 0 0 None
0x31 24 tc 1 24 0 r . . 8 8 8 0 0 24 8 16 16 16 16 0 0 None
0x53 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
Current Operating System: Linux MOODY-MACHINE 2.6.22-14-generic #1 SMP Tue Dec 18 08:02:57 UTC 2007 i686
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 20 13:34:55 2007
(**) | |-->Monitor "MonitorGeneric Video Card"
(**) | |-->Device "Generic Video Card"
(**) |-->Input Device "stylus"
(**) |-->Input Device "cursor"
(**) |-->Input Device "eraser"
(WW) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(==) AIGLX enabled
compiled for 4.3.99.902, module version = 4.1.72
(II) LoadModule: "wacom"
(II) Loading /usr/lib/xorg/modules/input//wacom_drv.so
(II) Module wacom: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
(II) Wacom driver level: 47-0.7.7-7 $
(II) via: driver for VIA chipsets: CLE266, KM400/KN400, K8M800/K8N800,
PM800/PM880/CN400, P4M800PRO, CX700, K8M890, P4M890, CN750, P4M900
(--) Assigning device section with no busID to primary device
(--) Chipset K8M800/K8N800 found
(II) VIA(0): MergedFB mode forced off.
(==) VIA(0): Not using video BIOS to set modes
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) VIA(0): Primary V_BIOS segment is: 0xc000
(II) VIA(0): MapBase = b79ef000, MmioBase=f4000000
(II) VIA(0): RegCR08 = 0, RegCR09=4f
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules//libvbe.so
(II) VIA(0): VESA BIOS detected
(II) VIA(0): VESA VBE Version 3.0
(II) VIA(0): VESA VBE Total Mem: 65536 kB
(II) VIA(0): VESA VBE OEM: VIA K8M800
(II) VIA(0): VESA VBE OEM Software Rev: 1.0
(II) VIA(0): VESA VBE OEM Vendor:
(II) VIA(0): VESA VBE OEM Product:
(II) VIA(0): VESA VBE OEM Product Rev:
(--) VIA(0): Chipset: "K8M800/K8N800"
(--) VIA(0): mapping BitBlt MMIO @ 0xf4200000 with size 0x200000
(II) VIA(0): VESA VBE DDC supported
(II) VIA(0): VESA VBE DDC Level 2
(II) VIA(0): VESA VBE DDC transfer in appr. 1 sec.
(II) VIA(0): VESA VBE DDC read successfully
(II) VIA(0): Using EDID range info for horizontal sync
(II) VIA(0): Using EDID range info for vertical refresh
(--) VIA(0): Max Monitor H = 1280
(--) VIA(0): Max Monitor V = 1024
(II) VIA(0): MonitorGeneric Video Card: Using hsync range of 30.00-113.00 kHz
(II) VIA(0): MonitorGeneric Video Card: Using vrefresh range of 50.00-160.00 Hz
(II) VIA(0): Clock range: 20.00 to 270.00 MHz
(II) VIA(0): Not using mode "1440x1050" (mode clock too high)
(II) VIA(0): Not using mode "1280x768" (mode clock too high)
(II) VIA(0): Not using mode "1920x1080" (mode clock too high)
(II) VIA(0): Not using default mode "640x350" (vertical timing out of range)
(II) VIA(0): Not using default mode "640x400" (vertical timing out of range)
(II) VIA(0): Not using default mode "720x400" (vertical timing out of range)
(II) VIA(0): Not using default mode "1024x768" (vertical timing out of range)
(II) VIA(0): Not using default mode "1280x960" (mode clock too high)
(II) VIA(0): Not using default mode "1280x1024" (mode clock too high)
(II) VIA(0): Not using default mode "1600x1200" (mode clock too high)
(II) VIA(0): Not using default mode "1792x1344" (mode clock too high)
(II) VIA(0): Not using default mode "1856x1392" (mode clock too high)
(II) VIA(0): Not using default mode "1920x1440" (mode clock too high)
(II) VIA(0): Not using default mode "832x624" (horizontal timing out of range)
(II) VIA(0): Not using default mode "1152x768" (vertical timing out of range)
(II) VIA(0): Not using default mode "1152x864" (mode clock too high)
(II) VIA(0): Not using default mode "1400x1050" (mode clock too high)
(II) VIA(0): Not using default mode "1680x1050" (mode clock too high)
(II) VIA(0): Not using default mode "1920x1200" (mode clock too high)
(II) VIA(0): Not using default mode "2048x1536" (mode clock too high)
(II) VIA(0): Not using driver mode "720x400" (vertical timing out of range)
(II) VIA(0): Not using driver mode "832x624" (horizontal timing out of range)
(II) VIA(0): Not using driver mode "1280x1024" (width too large for virtual size)
(II) VIA(0): Not using default mode "1280x1024" (width too large for virtual size)
(II) VIA(0): Not using mode "1440x900" (width too large for virtual size)
(II) VIA(0): Not using default mode "1280x960" (width too large for virtual size)
(II) VIA(0): Not using mode "1366x768" (width too large for virtual size)
(II) VIA(0): Not using mode "1360x768" (width too large for virtual size)
(II) VIA(0): Not using default mode "1280x800" (width too large for virtual size)
(II) VIA(0): Not using driver mode "1152x864" (width too large for virtual size)
(II) VIA(0): Not using default mode "1152x864" (width too large for virtual size)
(II) VIA(0): Not using mode "1280x768" (width too large for virtual size)
(II) VIA(0): Not using mode "1280x720" (width too large for virtual size)
(--) VIA(0): Virtual size is 1024x768 (pitch 1024)
(**) VIA(0): *Driver mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(**) VIA(0): Driver mode "1024x768": 94.5 MHz, 68.7 kHz, 84.9 Hz
(**) VIA(0): Driver mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) VIA(0): Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) VIA(0): Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) VIA(0): Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(**) VIA(0): Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) VIA(0): Modeline "1024x768" 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
(**) VIA(0): Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) VIA(0): Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) VIA(0): Mode "1024x512": 53.3 MHz, 40.1 kHz, 75.0 Hz
(II) VIA(0): Modeline "1024x512" 53.30 1024 1072 1176 1328 512 513 516 535
(**) VIA(0): Mode "1024x512": 41.3 MHz, 31.9 kHz, 60.0 Hz
(II) VIA(0): Modeline "1024x512" 41.30 1024 1056 1160 1296 512 513 516 531
(**) VIA(0): Driver mode "800x600": 56.8 MHz, 53.7 kHz, 84.9 Hz
(**) VIA(0): Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) VIA(0): Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) VIA(0): Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) VIA(0): Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) VIA(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) VIA(0): Modeline "800x600" 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
(**) VIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) VIA(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) VIA(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) VIA(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) VIA(0): Mode "720x576": 42.6 MHz, 45.1 kHz, 75.0 Hz
(II) VIA(0): Modeline "720x576" 42.60 720 760 832 944 576 577 580 602
(**) VIA(0): Mode "720x576": 32.7 MHz, 35.9 kHz, 60.1 Hz
(II) VIA(0): Modeline "720x576" 32.70 720 744 816 912 576 577 580 597
(**) VIA(0): Mode "856x480": 41.3 MHz, 37.7 kHz, 75.1 Hz
(II) VIA(0): Modeline "856x480" 41.30 856 888 976 1096 480 481 484 502
(**) VIA(0): Mode "856x480": 31.7 MHz, 29.8 kHz, 59.9 Hz
(II) VIA(0): Modeline "856x480" 31.70 856 872 960 1064 480 481 484 497
(**) VIA(0): Mode "848x480": 47.4 MHz, 42.9 kHz, 85.0 Hz
(II) VIA(0): Modeline "848x480" 47.40 848 888 976 1104 480 481 484 505
(**) VIA(0): Mode "848x480": 41.0 MHz, 37.7 kHz, 75.1 Hz
(II) VIA(0): Modeline "848x480" 41.00 848 880 968 1088 480 481 484 502
(**) VIA(0): Mode "848x480": 31.5 MHz, 29.8 kHz, 60.0 Hz
(II) VIA(0): Modeline "848x480" 31.50 848 864 952 1056 480 481 484 497
(**) VIA(0): Mode "800x480": 29.6 MHz, 29.8 kHz, 60.0 Hz
(II) VIA(0): Modeline "800x480" 29.58 800 816 896 992 480 481 484 497
(**) VIA(0): Mode "720x480": 34.9 MHz, 37.6 kHz, 74.9 Hz
(II) VIA(0): Modeline "720x480" 34.90 720 752 824 928 480 481 484 502
(**) VIA(0): Mode "720x480": 26.7 MHz, 29.8 kHz, 60.0 Hz
(II) VIA(0): Modeline "720x480" 26.70 720 736 808 896 480 481 484 497
(**) VIA(0): Driver mode "640x480": 35.0 MHz, 42.9 kHz, 84.6 Hz
(**) VIA(0): Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) VIA(0): Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) VIA(0): Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz
(**) VIA(0): Driver mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) VIA(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) VIA(0): Modeline "640x480" 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
(**) VIA(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) VIA(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) VIA(0): Modeline "640x480" 31.50 640 664 704 832 480 489 492 520 -hsync -vsync
(**) VIA(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
(**) VIA(0): DPI set to (83, 84)
(**) VIA(0): Option: Cap0 auto detect= 0
(**) VIA(0): Option: Cap1 auto detect= 0
(**) VIA(0): Option: Cap0_FieldSwap Disabled
(**) VIA(0): Option: Cap0_HFilter Enabled
(**) VIA(0): Option: Cap1_HFilter Enabled
(**) VIA(0): Option: Capture Over Scan ON
(**) VIA(0): Option: HQV Filter Manual Select Disabled
(**) VIA(0): Option: Set MPEG decode frame buffer number Disable
(**) VIA(0): Option: Capture 1 use H/W auto flip
(**) VIA(0): Option: Capture 0 use V1 engine : Default path
(**) VIA(0): Option: HQV Manual Switch Disabled
(**) VIA(0): Option: No mpeg add one line on bottom = 0
(**) VIA(0): Option: DeBlocking Disable!!
(**) VIA(0): DeBlocking Minimum Width Default : 320
(**) VIA(0): DeBlocking Minimum Height Default: 240
(**) VIA(0): Option: Use 2D BitBlt method to write event-tag into VQ and make sure MPEG decode END Disable
(II) VIALoadVideoOption
(--) VIA(0): Frame buffer start: 0xb3758000, free start: 0x300000 end: 0x4000000
(EE) VIA(0): Couldn't open "/dev/video2"
(II) VIA(0): VIAScreenInit : V4L Disabled : fd2 = -1
(II) VIA(0): I2C device "I2C bus 2:TV" registered at address 0x40.
(II) VIA(0): I2C device "I2C bus 2:TV" removed.
(II) VIA(0): 3D Engine has been initilized.
drmOpenByBusid: Searching for BusID PCI:1:0:0
drmOpenDevice: open result is 7, (OK)
drmOpenByBusid: drmOpenMinor returns 7
drmOpenByBusid: drmGetBusid reports pci:0000:00:00.7
drmOpenDevice: node name is /dev/dri/card1
drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
(II) VIA(0): [drm] loaded kernel module for "via" driver
(II) VIA(0): [drm] DRM interface version 1.3
(II) VIA(0): [drm] created "via" driver at busid "PCI:1:0:0"
(II) VIA(0): [drm] added 8192 byte SAREA at 0xf8bb6000
(II) VIA(0): [drm] mapped SAREA 0xf8bb6000 to 0xb7f8f000
(II) VIA(0): [drm] framebuffer handle = 0xf0000000
(II) VIA(0): [drm] added 1 reserved context for kernel
(II) VIA(0): [drm] drmAgpEnabled succeeded
(II) VIA(0): [drm] agpAddr = 0xe8000000
(II) VIA(0): [drm] agpBase = 0x00000000
(II) VIA(0): [drm] agpSize = 0x02000000
(II) VIA(0): [drm] agp physical addr = 0x00000000
(II) VIA(0): [dri] use agp.
(II) VIA(0): [dri] frame buffer initialized.
(II) VIA(0): [dri] visual configs initialized.
(II) VIA(0): [drm] register handle = 0xf4000000
(II) VIA(0): [drm] mmio Registers = 0xf4000000
(II) VIA(0): [dri] mmio maped.
(II) VIA(0): Frame Buffer From (0,0) To (1024,1280)
(II) VIA(0): Using 1280 lines for offscreen memory.
CPU to Screen color expansion
Solid Lines
Dashed Lines
Image Writes
Offscreen Pixmaps
15 128x128 slots
4 256x256 slots
(II) VIA(0): [drm] FBFreeStart= 0x00500000 FBFreeEnd= 0x03fba000 FBSize= 0x03aba000
(==) VIA(0): Silken mouse enabled
(**) Option "dpms"
(II) VIA(0): X context handle = 0x1
(II) VIA(0): [drm] installed DRM signal handler
(II) VIA(0): [DRI] installation complete
(II) VIA(0): [dri] kernel data initilized.
(II) VIA(0): [drm] Initialized AGP ring-buffer, size 0x1000000 at AGP offset 0x0.
(II) VIA(0): direct rendering enabled
(==) RandR enabled
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: drmOpenMinor returns 8
(WW) AIGLX: 3D driver claims to not support visual 0x22
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x25
(WW) AIGLX: 3D driver claims to not support visual 0x26
(WW) AIGLX: 3D driver claims to not support visual 0x27
(WW) AIGLX: 3D driver claims to not support visual 0x28
(WW) AIGLX: 3D driver claims to not support visual 0x29
(WW) AIGLX: 3D driver claims to not support visual 0x2a
(WW) AIGLX: 3D driver claims to not support visual 0x2b
(WW) AIGLX: 3D driver claims to not support visual 0x2c
(WW) AIGLX: 3D driver claims to not support visual 0x2d
(WW) AIGLX: 3D driver claims to not support visual 0x2e
(WW) AIGLX: 3D driver claims to not support visual 0x2f
(WW) AIGLX: 3D driver claims to not support visual 0x30
(WW) AIGLX: 3D driver claims to not support visual 0x31
(II) AIGLX: Loaded and initialized /usr/lib/dri/via_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(**) Option "SendCoreEvents"
(**) stylus: always reports core events
(**) stylus device is /dev/input/wacom
(**) stylus is in absolute mode
(**) stylus: forcing TabletPC ISD V4 protocol
(**) WACOM: suppress value is 2
(**) Option "BaudRate" "9600"
(**) stylus: serial speed 9600
(**) cursor: always reports core events
(**) cursor device is /dev/input/wacom
(**) cursor is in relative mode
(**) cursor: forcing TabletPC ISD V4 protocol
(**) cursor: serial speed 9600
(**) eraser: always reports core events
(**) eraser device is /dev/input/wacom
(**) eraser is in absolute mode
(**) eraser: forcing TabletPC ISD V4 protocol
(**) eraser: serial speed 9600
(II) XINPUT: Adding extended input device "eraser" (type: Wacom Eraser)
(II) XINPUT: Adding extended input device "cursor" (type: Wacom Cursor)
(II) XINPUT: Adding extended input device "stylus" (type: Wacom Stylus)
(**) Option "Device" "/dev/input/wacom"
(EE) xf86OpenSerial: Cannot open device /dev/input/wacom
No such file or directory.
Error opening /dev/input/wacom : Bad file descriptor
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
# package.
Section "Files"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "freetype"
Load "int10"
Load "vbe"
Load "extmod"
Load "dri"
Load "glx"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "wacom"
Identifier "stylus"
EndSection
Driver "wacom"
Identifier "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
EndSection
Section "Device"
BoardName "via"
Driver "via"
EndSection
Section "Monitor"
Option "DPMS"
#Refresh Rate 60Hz
EndSection
Section "Screen"
DefaultDepth 24
Modes "1024x768"
Depth 1
EndSubSection
Modes "1024x768"
Depth 4
EndSubSection
Modes "1024x768"
Depth 8
EndSubSection
Modes "1024x768"
Depth 15
EndSubSection
Modes "1024x768"
Depth 16
EndSubSection
Modes "1024x768"
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Reason: Automerged Doublepost
20-12-2007, 01:47 PM
Think Zen.
Congrats
So,where's that compiz screenshot.?
Regards,
ray
20-12-2007, 02:02 PM
GaurishSharma.com
Originally Posted by rayraven
Congrats
Regards,
ray
hey wait, it says "Desktop effects could not be enabled"
i guess i need to troubleshoot the errors first "libGL warning: 3D driver claims to not support visual"
20-12-2007, 02:11 PM
Think Zen.
20-12-2007, 02:21 PM
GaurishSharma.com
its for ATI
gaurish@MOODY-MACHINE:~$ lsmod | grep via
via 43904 2
drm 83348 3 via
snd_via82xx 29336 0
gameport 16776 1 snd_via82xx
snd_ac97_codec 100644 1 snd_via82xx
snd_pcm 80388 3 snd_via82xx,snd_ac97_codec,snd_pcm_oss
snd_page_alloc 11400 2 snd_via82xx,snd_pcm
snd_mpu401_uart 9600 1 snd_via82xx
i2c_viapro 10004 0
i2c_core 26112 1 i2c_viapro
snd 54660 11 snd_via82xx,snd_ac97_codec,snd_pcm_oss,snd_mixer_o ss,snd_pcm,snd_mpu401_uart,snd_seq_oss,snd_rawmidi ,snd_seq,snd_timer,snd_seq_device
via82cxxx 10372 0 [permanent]
ide_core 116804 2 ide_cd,via82cxxx
via_rhine 25992 0
mii 6528 1 via_rhine
sata_via 12548 7
libata 125168 2 ata_generic,sata_via
20-12-2007, 02:29 PM
Think Zen.
Re: VIA UniChrome Pro Display Driver ver 0.8
Not quite,its been found on a couple of other chipsets too.
Read this : https://bugs.freedesktop.org/show_bug.cgi?id=6624
Regards,
ray
20-12-2007, 03:00 PM
#19 (permalink)
GaurishSharma.com
some more informations, when i try to run glxgears it runs smoothly, and some times i also get 5000 or 6400 FPS which is very good considering
8600GT gives 7600FPS, however my FPS aren't stable
gaurish@MOODY-MACHINE:~$ glxgears
2921 frames in 5.0 seconds = 584.115 FPS
3074 frames in 5.0 seconds = 614.655 FPS
3074 frames in 5.0 seconds = 614.703 FPS
8499 frames in 5.0 seconds = 1699.795 FPS
32420 frames in 5.0 seconds = 6483.904 FPS
32340 frames in 5.0 seconds = 6467.845 FPS
15242 frames in 5.0 seconds = 3048.340 FPS
25751 frames in 5.0 seconds = 5148.552 FPS
3035 frames in 5.0 seconds = 606.896 FPS
3059 frames in 5.0 seconds = 611.652 FPS
also i tried running, compiz from terminal here is what i get
gaurish@MOODY-MACHINE:~$ compiz
Checking for Xgl: not present.
No whitelisted driver found
aborting and using fallback: /usr/bin/metacity
it clearly indicates that i am missing Xgl
22-12-2007, 02:09 PM
#20 (permalink)
GaurishSharma.com
<<<BUMP>>>
i even can't play simple movies, it just freezes
