Old 17-12-2007, 07:27 PM   #1 (permalink)
anarchist
Posts: n/a
Default linux suggestion for tv tuner card
i have used ubuntu 6.06 and 7.04 in the past, but switched to XP for some harware isues with my laptop (card reader). now i have my desktop PC with "Enter" TV tuner card, which distro will support this card?
2. i have many movies in flv format (some of them i have already converted to DivX / Xvid). can i view them without converting?
i use my desktop mainly for TV / Movies / MP3. please suggest suitable distro
system: P4 3.0HT, Intel chipset 945, 1GB DDR2, 80GB HDD, DVD-Combo
Old 17-12-2007, 08:17 PM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: linux suggestion for tv tuner card
Enter is only the brand name. Thats not going to help much. You will need to know the chipset to configure TV Tuner properly if any is needed at all. Most likely im guessing its one of Phillips Saa7134 chipset. If it is I have heard that someone has had success with Mandriva 2008 out of box. however I haven't tried it so don't quote me on it. I have a TechCom Tv Tuner and its sound isn't exactly very good. If you Tv Tuner has a cable from the TV Tuner Audio out to the sound card Audio in then your chances of getting audio increases. From peoples experience I think that some have had success with PixelView Tv Tuners you might want to check around for this.
Yes you can view flv videos in Ubuntu not sure about 6.06 as I run 7.10 . Getting the TV Tuner card to work on any distro is going to be hard or at least it was in my experience. Personally Im biased towards Ubuntu so you might want to wait for others to suggest a distro.
FilledVoid is offline
Old 23-12-2007, 09:06 PM   #3 (permalink)
FilledVoid's Avatar
Out of curiosity what company card is this?
Old 23-12-2007, 09:14 PM   #4 (permalink)
anarchist
Posts: n/a
as mentioned in first post, it is "Enter" brand. but i think Enter, Intex are just stamps, and does not matter for getting it worked.
i am presently studying linuxtv.org if i could find something there
Old 24-12-2007, 09:46 AM   #5 (permalink)
FilledVoid's Avatar
Sorry what I meant to ask is if it had a certain model name. Anyway I have a TechCom tv Tuner and I posted how I got my partially workable TV Tuner card as shown at my blog http://www.filledvoid.com/2007/12/15...ion-in-ubuntu/ Let me know if any of this helps . before configuring make sure you read the whole posts. There are two gentoo wikis posted in there which might help configuring as well.
Old 11-03-2008, 10:22 AM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
Wow, computer rants too
look at the funny kernel messages
Originally Posted by anarchist View Post
still audio is not coming through standard sound output of MB, using audio output directly from the audio out of tv tuner card.
Plug a cable from TV tuner card to the line in jack., of at the back of MOBO
there would be three sound jacks at back of mobo
1) MIC
2) sound( where you plug your speaker in)
3) the line( plug the cable here)
When you finish, how about posting a tut for it?
it will help others too
system: P4 3.0HT, 512MB, Intel 865, 80GB, DVD-Combo
Mplayer can plays any format till date i have thrown at it
gary4gar is offline
Old 11-03-2008, 11:49 AM   #7 (permalink)
FilledVoid's Avatar
Let me know if you get good audio from it. I cant get audio no matter what I do. Well at least nice quality audio.
Old 11-03-2008, 07:51 PM   #8 (permalink)
anarchist
Posts: n/a
@ filledVoid: audio quality is very good through tuner out. i think problem is in "alsa mixer" which is unable to use "rear speaker out" as "line in". as the same socket is used for rear speaker out in 4 way audio.
in windows for my motherboard (intel 945) i can use these sockets as either line in or stereo out.
@gary4gar: i am using that audio cable from tuner out to line in. and movie player in my ubuntu already searched and installed itself necesy codecs to play all type of movies
Old 11-03-2008, 10:05 PM   #9 (permalink)
FilledVoid's Avatar
I couldnt get any sound out of the Rear out of the card :/ . Im waiting for Ubuntu Hardy heron to start to tinker on it again.
Old 12-03-2008, 09:47 AM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
the "line in" socket works as "rear out" / "line in" in windows. but in ubuntu i am unable to get it worked for either purpose. so i am not getting "rear out" in ubuntu.
regarding non-clear sound at your tuner card, it may be being decoded in different system like PAL-DK or PAL-I
By default Line in is muted.
Double-click on The Volume Icon near the System clock On Gnome desktop. from there Un-mute it
gary4gar is offline
Old 12-03-2008, 10:00 AM   #11 (permalink)
Dark Star's Avatar
How to : Enable Multimedia Suport in Ubuntu 7.10. This is for format querie/.. Also .. You said that you got you TV tuner working in Ubuntu and you have posted a screenshot too http://www.thinkdigit.com/forum/show...&postcount=771
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 12-03-2008, 10:03 AM   #12 (permalink)
GaurishSharma.com
gary4gar's Avatar
btw try http://www.mythtv.org/
gary4gar is offline
Old 12-03-2008, 10:40 AM   #13 (permalink)
left this forum longback
praka123's Avatar
i have a small time experience with pinnacle pctv 50i(saa7134 based).I have configured it to work with dth.with tvtime,we can watch programs fine.for dth users,we have to switch on line-in each time
I tried "xawtv" for recording purpose,but it turned out to be too buggy for me.I have got a few hours only to play with this card though(not my system!)
mythtv is bulky and confusing?
for ur info,there is mythubuntu-a complete distro that may suit these purposes.configure mythtv imho is pita
praka123 is offline
Old 12-03-2008, 04:03 PM   #14 (permalink)
FilledVoid's Avatar
The main reason this happens is something acting funny with ALSA> I got it to work previously after downloading the new ALSA packages and then compiling them on my system. By any chance are you using Realtek or Intel High definition Audio if yo do then you are facing the same problem that I did. I have blogged on how I was able to get the solution.
Need an LCD monitor and TV Tuner card suggestion Aparajith Hardware Q&A 3 23-11-2006 09:52 PM
Tv tuner card / Graphics card for my config ... gsenthil PC Components / Configurations 4 08-09-2006 07:23 PM
Suggestion About Tv Tuner card indian QnA (read only) 15 10-10-2005 07:41 PM
Query Reg Graphics card/TV Tuner card tiwariG QnA (read only) 10 10-09-2004 06:38 PM
