Old 16-12-2007, 07:02 AM   #1 (permalink)
Juke Box Hero
Post Slim Down and Speed Up Linux
While Linux is pretty efficient with a computer's resources out of the box, there are still ways you can make it run leaner and meaner on your desktop. Using a little bit of know-how, a willingness to run a few terminal commands and a mind for efficiency, you can get every last bit of power from your Linux box, or get more life from an older system. Read on for a roundup of ways to slim down and speed up Linux that any level of user can implement.
I've started to like lifehacker.com a lot
Hitboxx is offline
Old 16-12-2007, 09:31 AM   #2 (permalink)
Default Re: Slim Down and Speed Up Linux
That was a good read mate. Thanks for it
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 16-12-2007, 11:04 AM   #3 (permalink)
Married!
Rahim's Avatar
Can i disable Database Server postgresql shown in my Services? I dont use it.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 16-12-2007, 11:50 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
If you are sure no application uses it then you are free to do so
Harsh J
www.harshj.com
QwertyManiac is offline
The slim and stylish W610i review devil_me QnA (read only) 3 02-06-2007 08:48 PM
