Old 07-12-2007, 09:32 PM   #1 (permalink)
Pee into the Wind...
shady_inc's Avatar
Red face Gutsy Gibbon install: help me with the steps!!
Greetings!!
This is my first post from Gutsy Gibbon.Using the LiveCD version given in this month's digit DVD.Now I tried to install linux,but have no idea what I should select on this screen:
I have a 40 gb HDD with two 20 gb partitions and have 8 gb (C:\) and 4.5 gb (D:\) free in each respectively.Windows installed in D: drive.So I guess linux will need to be installed in C: drive.
Now,I don't wanna lose any data on either drive and neither render my Windows XP unusable because of some wrong options I selected during installation.So,please guide me in absolutely basic language since this is my first tryst with linux.
Thanks,
shady_inc
shadyEdit: By the way,is it safe to use net while booting linux from CD??
Life is as complicated as you say it is.
shady_inc is offline
Old 07-12-2007, 09:49 PM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: Gutsy Gibbon install: help me with the steps!!
You should choose " manual" option. I am a liitle tentative about giving help on partition issues as your Windows resides in D: drive, so i will let others give you the required help.
And yes it is safe to browse through the Live CD. Remember you are using Linux, so no virus,spyware,malware,etc to worry about.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 07-12-2007, 09:58 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by shady_inc
Greetings!!
Thanks,
shady_inc
First thing is that you haf a bit messy system!!! Since you are new to Linux the ideal way is to install Windows in the first partition (so called C: Drive) and free up some space and create an empty partition next to it. That would mean you install Windows in C Drive and then create 3 more partitions. The second "drive" houses the contents of your "D Drive". The third is the Linux root paritition (of at least 5GB) and the last "drive" is the Linux swap partition (of about 400mb or so).
When you are done with this then hit back. We'll help you further. Coz giving too much info can be confusing and dangerous! So its better if step by step instructions are provided
Also, its SAFEST to log on to the net via LiveCD. ITS SAFER THAN USING THE NET ON WINDOWS!!!!
infra_red_dude is offline
Old 07-12-2007, 10:01 PM   #4 (permalink)
MMO Addict
amitava82's Avatar
Ok, first thing you have to do is go back to windows and install some kinda partition resizing software such as Partition Magic. With this software take out about 6 GB free space from any of your partitions. Once you are done come back..
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 07-12-2007, 10:04 PM   #5 (permalink)
shady_inc's Avatar
Partition magic ain't a freeware... .Read about Gparted while googling just now.Will Gparted be able to do the job??
So I guess I will take 5 gb from C; drive for linux primary partition.Another 1 gb from either drive for swap partition.[I heard it must equal the amount of RAM you have?? ].
Old 07-12-2007, 10:05 PM   #6 (permalink)
Wire muncher!
I'd suggest NOT to rely solely on partitioning software. They can mess up with your data!!! Neither free nor paid!
Backup your data and then free up about 5-6GB of space.
Old 07-12-2007, 10:05 PM   #7 (permalink)
Married!
Rahim's Avatar
Good learner indeed.
Rahim is offline
Old 07-12-2007, 10:08 PM   #8 (permalink)
MMO Addict
amitava82's Avatar
I dunno.. Couple of months back I used Gparted to resize my linux partition and It screwed up my linux installation. Though I did not loose any data from windows partition.. Hopefully it should work..
Old 07-12-2007, 10:13 PM   #9 (permalink)
shady_inc's Avatar
Ok..will hit back tomorrow when I am done with the partitioning thing.Thanks for your super quick responses.Now I atleast have an idea of what I should be my first step towards installing linux.!!
Have already made the required backups on 3 DVDs.So no worries there!!
Old 07-12-2007, 10:15 PM   #10 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
@shady:if I were you I would have backupped(lol) all the data from C: drive and formatted it,Then would've made a home partition(mount point /,and file system ext3) of about 5gb+swap partition of about .5-1gb(filesystem-swap)[these steps to be done while installing gutsy).Then after installing Ubuntu,you can reclaim your free hard disk space(i.e. 20-6gb=14gb left after installing ubuntu) by making another partition in windows.
Mind you Gutsy supports native read and write support in NTFS so you can enjoy all your data in gutsy too.Hope it heps.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 07-12-2007, 10:17 PM   #11 (permalink)
unless u can make a partition of abt 4gb for linux home
500mb for swap
things are not that simple.
post ur sys spec.
Note: backup ur data before playin around
Faun is offline
Old 07-12-2007, 10:25 PM   #12 (permalink)
Married!
Rahim's Avatar
The solution could have been simpler had your Windows been in C: drive
Rahim is offline
Old 07-12-2007, 10:25 PM   #13 (permalink)
TheSaint
NucleusKore's Avatar
FIRST BACK UP YOUR DATA
I suggest you get Gparted from http://gparted.sourceforge.net and repartition your hard disk to have a swap partition (size=2xRAM) and a ext3 partition for root filesystem (/). You will have to resize your C partition from the end (not the beginning), AND WILL HAVE TO HAVE 10 gb free space on your C partiiton before you start resizing. Gparted has a nice GUI for doing that.
Resize your C to 14 GB. Now to set up the free space you've just reclaimed If you have 256 MB RAM, you can set 512 MB as swap and remaining space as ext3. This will accommodate your root filesystem (which will contain your home folder, maybe not a very good idea but you have a space constraint).
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 07-12-2007, 10:27 PM   #14 (permalink)
shady_inc's Avatar
Actually this sounds better but more time-consuming than using a third party utility like Partition magic or Gparted.Since the backup has already been made,which would be better: Devil's method or using Partition Magic,Gparted etc. [haven't used any of it before.so unless it's point and click,I wouldn't prefer using them] to make space for linux.??
Originally Posted by T159
post ur sys spec.
Celeron 2.4 Ghz
40 gb HDD
1 Gb DDR RAM
64 Mb onboard intel 845g graphics.
shadyEdit: NucleosKore beat me to posting.!!Seeing his reply,I guess I will just use Gparted to do the job.By the way,you have mentioned filesystem (/)..What's the significance of the "/" here...or is it just a misspelt smiley...??
Old 07-12-2007, 10:36 PM   #15 (permalink)
dude just use my method cos it is the best IMO.lol.Seriously shrinking and expanding partitions doesn't always work and besides you have backed up all your data so formatting will help you get rid of all the junk.
Old 07-12-2007, 10:38 PM   #16 (permalink)
Celeron 2.4 Ghz
40 gb HDD
1 Gb DDR RAM
ok u may consider setting ur swap partition to 1.5 times of the total RAM.
i.e. 1500MB
yeah if everything is backed up then simple format is the straight decision
Faun is offline
Old 07-12-2007, 10:39 PM   #17 (permalink)
and did you juat say 'more time consuming'?lol man it is as easy as it gets----boot up using livecd,format your c: partition(you said you have backed up data),make another partition of about 5gb--mount it as /+use file system ext3,make yet another aprtition of about .5-1gb using swap filesystem(no mounting point for this),then just install gutsy.Reclaim your letf out space by making another ntfs partition either in gutsy or in windows.
here's is a more refined guide I wrote for someone else.
Originally Posted by me
1.Boot up using ubuntu livecd/dvd
2.double click install icon
3.answer some basic questions like keyboard layout,time zone,etc.
4.Gutsy can import your wallpaper and documents from windows installation that you have(i found this pretty cool) though firefox doesn't import settings and bookmarks iirc.
5.Ubuntu needs two partitions for a normal install one home(/) partition and one swap partition.delete your c: partition and make a new partition out of it by formatting it with 'ext3' filesystem and specifying mount point as '/'.Make another partition and select 'swap' from filesystem dropdown menu.no mounting point needed for it.
6.Thats it just hold back and enjoy while ubuntu installs and reboot onto your harddisk when told to reboot.
7.grub will recognize all your current installations and make your system dual boot accordingly(windows+ubuntu).
if you face some problems then feel free to ask.
NOTE:
Swap partition:it is necessary to specify a separate swap partition while installing ubuntu gutsy gibbon.It is just like pagefile in windows,i.e. it is used to store data temporarily from memory.It should be twice the size of your RAM for lesser than 512MB system RAM,and equal to your system RAM after that.
ok enough help provided kid now go and install gutsy and welcome abroad.
Old 07-12-2007, 10:41 PM   #18 (permalink)
/ is ur main partition(type ext3), where all data will reside.
swap is pagefile partition
another partition is
/boot which generally contains bootloader(type ext3) etc.
Faun is offline
Old 07-12-2007, 10:43 PM   #19 (permalink)
Married!
Rahim's Avatar
i.e. 1500MB
He already has 1 GB RAM, he just have to create 256 /512 MB Swap. That would be enough.
Rahim is offline
Old 07-12-2007, 10:48 PM   #20 (permalink)
shady_inc's Avatar
Thanks for the respones!!
Will be doing the partitioning and installing tomorrow.Will get back once I get linux running,or if I encounter any more difficulties in installing.
Just had this small doubt.Can the linux swap partition be used for storing any other data??And will the file system ext3,as mentioned by The_Devil_Himself be accessible from XP.??
Won't it be necessary to create this partition too.??
Regards,
shady_inc
Old 07-12-2007, 10:54 PM   #21 (permalink)
^^nope no need to create /boot partition.Let grub install on MBR and everything will be just fine.
No man you can't use swap partition to store any data,it won't be visible to you!!Just make and forget about it.
And yes you can access ext3 from XP through a small utility(forgot the name).
Now this is more than the help anybody would ever need!
Just follow the step by step guide I wrote above and install,Nothing can go wrong.
Old 07-12-2007, 10:59 PM   #22 (permalink)
http://ubuntuforums.org/showthread.php?t=186234
http://www.linuxforums.org/forum/mis...swap-size.html
Btw automatic partitioning in ubuntu allots 3 times the RAM.
Regards,
shady_inc
in case something happens to ur main partition the boot information will also be lost, os its better to have separate boot partition.
Mine is like
500MB /boot ext3
13GB / ext3
2GB swap
http://www.diskinternals.com/linux-reader/
Faun is offline
Old 07-12-2007, 10:59 PM   #23 (permalink)
Married!
Rahim's Avatar
No need to create /boot partition, it will be created as it will be made in / itself.
Just make two partitions: /& Swap
No linux swap is not used for storing data, you cant. Ya you can access ext3 partition from XP by installing an appz, forgot the name, just google it.
Rahim is offline
Old 07-12-2007, 11:08 PM   #24 (permalink)
shady_inc's Avatar
Ok..so it's all decided.
I will format my C: drive,create a 5 gb ext3 partition for linux [won't be storing any other data here,so it should be enough for just the OS],create a
500 mb swap partition [after having a look at the links T159 posted] and remaining 15 gb will become my current D: drive in NTFS file system.
I won't be getting into creating the boot partition.....for now.
Everything is proper according to me.Any suggestions to make it better.??
Regards,
shady_inc
Old 08-12-2007, 01:01 AM   #25 (permalink)
left this forum longback
praka123's Avatar
500MB swap is more than enough,dont waste ur hdd space!also partn resizing thingy gparted or any other s/w(win softwares too) can gurantee 100% success
praka123 is offline
Old 08-12-2007, 01:36 AM   #26 (permalink)
A LOTR fan
x3060's Avatar
i also will be getting my copy in a few days . . thanks for the steps here . . am not hijacking this thread but a small doubt , my machine is x2 3600 , 2g ram , 250 HDD, 7600 gt . . will 3d desktop work with me ?, how much swap should i put?. . thanks in advance . please , not disturbing . i will post separate thread if i get problems
x3060 is offline
Old 08-12-2007, 01:39 AM   #27 (permalink)
yeah definitely, make sure u hav net conn if u r getting cd. For AMD there is another version, downloadthat not i386 one.
U hav enuff space make swap to atleast 1GB, the more the better. Its like virtual memory.
Faun is offline
Old 08-12-2007, 01:39 AM   #28 (permalink)
praka123's Avatar
the important question is what is ur graphics card?if it is nvidia or onboard graphics except VIA,u can have compiz working.for amd ATi cards,u need to edit and tweak some conf files
praka123 is offline
Old 08-12-2007, 01:44 AM   #29 (permalink)
A LOTR fan
x3060's Avatar
man , i dont have a net connection .. . my gra is nvidia 7600 gt . .
i mean the digit dvd of Ubuntu . which i will be buying this month . i can have a reliance usb connection , but i dont think they will provide drivers for linux , so am i hopeless ?
x3060 is offline
Old 08-12-2007, 01:53 AM   #30 (permalink)
GaurishSharma.com
gary4gar's Avatar
then you can go to a cyber cafe or frinds computer & donwload stuff
gary4gar is offline
GUtsy Gibbon Queries iMav Open Source 294 01-05-2008 12:12 AM
Ubuntu 7.10 Gutsy Gibbon Master sources.list infra_red_dude Open Source 10 02-12-2007 09:52 PM
Ubuntu gutsy Gibbon 7.10 help needed ! FilledVoid Open Source 11 19-11-2007 06:35 PM
Help me run Gutsy Gibbon in my PC drgrudge Open Source 71 22-10-2007 12:23 AM
Ubuntu 7.10 (Gutsy Gibbon) Tribe 4 Dark Star Open Source 21 11-08-2007 10:36 PM
