Old 05-12-2007, 07:04 PM   #1 (permalink)
free as a bird
Default need help
I have installed fedora core , i already have windows xp on c drive now whenever i start my system it gives me a screen where i have to hit a key to reach another screen where i can select which os i want to boot. but is it possible that instead of first screen i get the second screan where i can choose the os i want to boot and the first screen gives me only 2 secs.
vicky_l7 is offline
Old 05-12-2007, 07:16 PM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: need help
wat do u get in the First screen ??
I love and Live to Design
azzu is offline
Old 05-12-2007, 07:31 PM   #3 (permalink)
yeah edit menu.lst default time out
open menu.lst with any text editor with root privilages
path is
/boot/grub/menu.lst
command is
su kate /boot/grub/menu.lst
or
su gedit /boot/grub/menu.lst
and change the value for
timeout
by default its 5 sec
Faun is offline
Old 05-12-2007, 07:33 PM   #4 (permalink)
left this forum longback
praka123's Avatar
yes,fedora just try to boot into before grub MENU appears.the solution is :
press alt+f2 to get "run" dialog.now insert below command to open grub.conf
gksu gedit  /boot/grub/grub.conf
now in the editor search(CTRL+F) for "hiddenmenu" word.prefix a "#" on hiddenmenu as is below:
#hiddenmenu
also u can make the timeout value to be 20 seconds:
timeout         20
^search and replace the value.
praka123 is offline
