Gmount-iso is a small tool written using PyGTK and Glade. It allows you to easily mount your cd images. This is a frontend to the '
mount -o loop -t iso9660 foo.iso /mountpoint' command...
Convert your CDs and unprotected DVDs into “virtual CDs” — disc images that run directly on your hard drive, replacing physical discs and saving wear and tear on your CD-ROM drive. Share virtual CDs over a network, and enjoy access rates up to 200 times faster than physical CDs, boosting the performance of PC games, photo CDs, and disc-based applications.
Play disc-based applications directly on your hard drive..
Installation : -
Open terminal From
Main Menu - > Accessories -> Terminal and type the following commands ..
sudo apt-get install gmountiso
You can also install it from
Synaptic Manager and from
Add/Remove Programs..
Home Page :
.:: CRANS : Cachan / Réseau @ Normale Sup' ::.
