Old 28-11-2007, 06:15 PM   #1 (permalink)
Unmountable Boot Volume
Cyrus_the_virus's Avatar
Question Enabling write permission on File system partition in Ubuntu
Can someone tell me as to how do I enable write permission for my Ubuntu file system partition. I have write permission for all the other drives except for the file system partition.
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
Cyrus_the_virus is offline
Old 28-11-2007, 06:40 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Enabling write permission on File system partition in Ubuntu
file system partition u mean "/"? I think for root (/) file system,root must be only give write access.a local user must be limited to his ~/ directory.the root permission 755 is perfectly fine.u can have access to /tmp fully.the root permission system that protects the system.use nautilus as root by making a launcher is /usr/share/applications/root-nautilus.desktop containing the details and the command "gksudo nautilus --browser".use alacarte gui editor to achieve that.it is in preferences>menu editor.
praka123 is offline
Old 28-11-2007, 09:01 PM   #3 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^hey praka even I can't paste my saved .deb file in var\apt\archives folder(paste option is grayed out).Please help a bit.And please be a lil elaborative as I am still a 'half noob'.
One more thing:How do I make a root user with all the powers?
ah just one more question:How do I mount Iso images in gutsy?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 28-11-2007, 09:17 PM   #4 (permalink)
I logged in as root rather than the user and I was able to do exactly what you're trying to do..
BTW, I also wanted to know how to log into root on the console while still logged in as a user.
Old 28-11-2007, 09:21 PM   #5 (permalink)
^i remember trying logging in as root user at startup but if I recall correctly it showed something like 'can't log in as root at startup' or something.not sure though.
Old 28-11-2007, 09:22 PM   #6 (permalink)
you need to go into the 'login window' option and check the option on the 4th tab called, let system admin log in at startup.
Old 28-11-2007, 09:30 PM   #7 (permalink)
ok done that,will try it out next time I start/reboot(tomorrow maybe).thanks.
ok one question remains How do I mount iso images in gutsy?I tried acetoneiso(i compiled it and all) but just can't seem to get it work,and i heard gutsy can automount iso images without any software.
Old 29-11-2007, 01:30 AM   #8 (permalink)
praka123's Avatar
u can extract isoimage contents using isomaster.apt-get install it.
while u can mount iso image as
(sudo -for ubuntu) mount /dir-of-iso/xyz.iso /mnt -o loop
^where / dir-of-isois the dir path where iso rests.
u can open a terminal and type "su" press enter give roots passwd and run above command.
above command mounts iso image in /mnt dir.
u can install
u can use chmod command as root/sudo to allow the dir u want to give full access to.
using su to login as root in a terminal,
try chmod 777 /var/cache/apt/archives
^will make it writable and vulnerable to.this is not the way to do it.
u can add the user's group to be there.and this is not a good practice i believe.
In my opinion dont do that instead make a shortcut on ur Gnome applications>system menu as following link describes.this is the way.
How to browse files/folders as root user in Nautilus
http://ubuntuguide.org/wiki/Ubuntu:F...er_in_Nautilus
^no jhanjhats
@cyrus:
u can open a terminal and type "su" and give root's password to have root privilage.it is not at all recommended to enable root account for login.yeah u can use gdmsetup to do that.
praka123 is offline
Old 29-11-2007, 02:01 AM   #9 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
right click upper pannel in the middle empty space.
click add to pannel
click "custom application launcher"
In the name part, type
Open as Root
in comment part, type
this opens any file/folder as root for you
in the command part, type
gksudo "gnome-open %u"
click the icon button and choose a good one.
this will add a launcher in the middle of your upper gnome pannel.
drag/drop a file in it and it will open as root user after asking for a password.
if you drag and drop any folder into it, it will also open as root user.
you can navigate to any file in it and do any action.
remember, the root user can do anything he likes. so be careful.
remember to close the window when done.
Beware: Root user often compromises security in the hands of n00bs
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 29-11-2007, 02:06 AM   #10 (permalink)
praka123's Avatar
nice tip there!
praka123 is offline
Old 29-11-2007, 03:08 AM   #11 (permalink)
another one dirty little trick is:
sudo nautilus
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is online now
Old 29-11-2007, 04:07 PM   #12 (permalink)
thanks a lot praka123,metalheadgautham,and T159(in order of appearence ).
Enabling Multimedia in Ubuntu catchjaga Open Source 1 22-12-2006 12:29 AM
enabling print option in protected pdf file? legolas Software Q&A 7 01-12-2006 05:38 PM
Enabling surround sound with Ubuntu 6.06 baccilus Open Source 4 26-11-2006 11:34 PM
File sharing permission for limited account amitsaudy QnA (read only) 1 17-03-2005 07:07 PM
want read/write/execute permission! naveenchandran Open Source 2 13-01-2005 06:14 PM
