Old 26-11-2007, 10:55 PM   #1 (permalink)
The Unknown's Avatar
Default Remove double versions ??
Hi
As you know I am using Fedora 7. I previously used the 'upgrade' option in yum to upgrade packages. But later I found that 'upgrade' option leaves the older version as it is. I upgraded my system like that. Now the disk usage is 6.xx GB. My files are only about 1 GB. I want to remove these double versions. How to do this ? Please help !!
KDE on ArchLinux
The Unknown is offline
Old 27-11-2007, 01:44 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Remove double versions ??
u may need to manually remove older versions.also install synaptic manager(rpm one is there!) and select the version u want to upgrade to.
praka123 is offline
Old 27-11-2007, 01:47 AM   #3 (permalink)
Didnt knew there was synaptic manager for FC too...
cool_techie_tvm is offline
Bug in all versions of Photoshop! go4saket Software Q&A 7 18-09-2007 04:39 PM
Bug in all versions of Photoshop! go4saket Software Q&A 3 17-09-2007 03:27 PM
Softwares, Stable Versions vs Previous Versions Aberforth Fight Club 15 23-12-2006 02:42 AM
lf2 versions utkarsh-techy Gamerz 1 04-09-2006 09:26 PM
