Old 26-11-2007, 01:13 PM   #1 (permalink)
meowww meoww
Kenshin's Avatar
Red face Pidgin plugin problem installin
I am tryin to install a plugin for Pidgin called music tracker.Am gettin this.
kenshin@cutie:~/Desktop/musictracker-0.4.1$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking for correct ltmain.sh version... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for PIDGIN... configure: error:
*** Pidgin 2.0+ is required to build MusicTracker; please make sure you have the
*** Pidgin development files installed. The latest version of Pidgin is always
*** available at http://pidgin.im/.
kenshin@cutie:~/Desktop/musictracker-0.4.1$ make
make: *** No targets specified and no makefile found.  Stop.
I got it from here http://shreevatsa.wordpress.com/2007...-being-played/
"Microsoft: You've got questions. We've got a dancing paperclip."
Have fun,no worries..
Kenshin is offline
Old 26-11-2007, 01:23 PM   #2 (permalink)
18 Till I Die............
Default Re: Pidgin plugin problem installin
You will need pidgin dev package installed.
apt-cache search pidgin
and check if a package pidgin-dev or something similar exists.
http://www.bash.org/?258908
mehulved is offline
Old 26-11-2007, 01:24 PM   #3 (permalink)
meowww meoww
Kenshin's Avatar
k will try
Kenshin is offline
Old 26-11-2007, 01:30 PM   #4 (permalink)
Think Zen.
ray|raven's Avatar
AFAICR Pidgin comes with a plugin that allows setting the current song as status message .
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 26-11-2007, 01:38 PM   #5 (permalink)
meowww meoww
Kenshin's Avatar
I din find one.....but i managed to install the plugin. I installed the PCRE library and now it got installed
Kenshin is offline
problem installing sun java plugin in firefox silent008 Open Source 1 26-11-2007 11:46 AM
winamp ipod plugin problem? sidcool Software Q&A 1 17-12-2006 03:10 PM
problem with plugin. vandit Software Q&A 1 02-07-2006 02:05 AM
