| Forum |
#1 (permalink) |
in search of myself
eg. Amrok and K3B both are KDE applications and require KDE library. Suppose first i install amrok and KDE lib is also installed.Now i backup and delete all the packages from /var/apt/cache/archives/ and then if i install K3B and take backup of it, the backup will not include KDE lib as it is already installed on my system. So the backup is incomplete and can't be installed independentely. So plz suggest me good way to restore my system to fresh state for the purpose of taking independent backup of the packages
:::::::::::::::::::: Unban Praka123 :::::::::::::::::::: Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife "Ek Se Mera Kya Hoga" |
#2 (permalink) |
Commander in Chief
Hmm, delete your cache (Move it) before installing KDE stuff and then install all KDE stuff, or even one, Amarok say. Make an AptISO and later after you download K3B and such (And their requirements), keep adding them to this ISO?
Harsh J www.harshj.com |
#3 (permalink) |
in search of myself
But i want to make amrok and k3b independent of each other. So in k3b backup there ll be no kde stuff and it can't be installed.
#4 (permalink) |
The Devil's Advocate
see if ur doing this with regards to ur offline package use exaile instead of amarok - exaile is gnome based and not kde based
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#5 (permalink) |
in search of myself
its not the question of only amarok and k3b. There may be many packages having same dependencies. I want every package to be self dependent
#6 (permalink) |
Think Zen.
Dude,many apps have common dependencies,
you just cant keep on maintaining every app with its dependencies. Try,FlyBack. Its an attempt to clone TimeMachine for linux. http://code.google.com/p/flyback/ Regards, ray
Do what you will; but not because you must. -- Zen Quote |
#7 (permalink) | |
in search of myself
BTW thanks for info about flyback
#8 (permalink) | |
18 Till I Die............
Though it's not a very good idea.
http://www.bash.org/?258908 |
#9 (permalink) |
in search of myself
^^ Where i can get more info about this. Althogh cache backup technique is easy one
#11 (permalink) |
in search of myself
what is static lib ?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Regarding System Restore | CadCrazy | Software Q&A | 5 | 23-06-2007 01:31 AM |
| System restore | ThinkFree | QnA (read only) | 7 | 19-04-2007 09:46 AM |
| Cant restore system using 'System Restore' | Swappy | Software Q&A | 4 | 23-08-2006 10:33 AM |
| System Restore-- Big Help | s18000rpm | QnA (read only) | 8 | 23-03-2006 04:44 AM |
