Old 24-11-2007, 03:30 PM   #1 (permalink)
Come get Some
DukeNukem's Avatar
Angry Fedora 8 Installation Problems
Hi to all of you
(these days iam really surrounded by problems)
Recently Ive get hold of 250GB HDD
My PC Conf is PIII 1GHZ/512 MB RAM/i815 DFI Board/Sea. 250GB HDD/SAM 16x DvDRW/LG 48x CDRW.
Earlier i used Sea. 160GB HDD Which is Partitioned like
C: 28GB/
D: 15GB/
(2GB SWAP/ 13GB EXT3)/
E: 30GB/
F: 30GB/
G: 30.9GB
Every thing work perfect here and iwas using it for XPSP2 and Fedora 8
Now Ive Partitioned my 250 GB HDD as
C: 34GB/
D: 20GB/
E: 42GB/
F: 42GB/
G: 52.90GB/
(29.89GB EXT3/ 2GB SWAP)/
Though XPSP2 is working Fine here, but After installing Fedora 8 (installation completes without any probs) on Booting System Hangs While Showing
"GRUB" (without ")
Can some one help me out ive wasted 2 Days By Installing XPSP2 and Fedora 8 again and again and again and again ......................
Please SOS... (iam using Only 250 GB HDD in this case )
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 25-11-2007, 05:32 PM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Default Re: Fedora 8 Installation Problems
So....
No one for a helping hand
Old 26-11-2007, 03:26 AM   #3 (permalink)
What is your main partition "FileSystem" ? ..
Actually right now getting no Idea, may be GRUB not able to load stage two ..
may be because of main partition being NTFS or something similar.
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 26-11-2007, 03:33 AM   #4 (permalink)
left this forum longback
praka123's Avatar
boot with a livecd run grub-install /dev/sdx where x depends on partn name.
also post the o/p as root in livecd terminal : "fdisk -l"
I think grub is not properly installed.try.
praka123 is offline
Old 27-11-2007, 12:45 PM   #5 (permalink)
Come get Some
DukeNukem's Avatar
Thanks a lot to reply
Problem solved but with diff solution
First i've installed windows XP (after removing all partitions)
then i've installed fedora 8
then booted into windows and created paritions
(but my three precious days are #$%^&* up, jus for this)
Old 27-11-2007, 03:48 PM   #6 (permalink)
praka123's Avatar
Will be good if u can troubleshoot and repair the install rather than reinstall
praka123 is offline
Old 28-11-2007, 02:04 AM   #7 (permalink)
hmm..
A agree to Praka.. reinstalling is not the solution !
But good to see that it is solved for u!
~Ricky
Ricky is offline
Old 28-11-2007, 02:07 PM   #8 (permalink)
Come get Some
DukeNukem's Avatar
Talking Re: Fedora 8 Installation Problems
I've Tried it Before Reinstallation Bro., But I thing the 43 GB Partition is the reason for my Problem
i.e When Ive created 43 GB Partition as Active (Primary)
and rest 189 GB as Extended One
232.88
43GB PRIMARY NTFS (WINDOWS XPSP2)
189GB EXTENDED
2GB SWAP (LINUX) (LOGICAL)
26GB EXT3 (LINUX) (LOGICAL)
50GB NTFS (MP3) (LOGICAL)
50GB NTFS (VDO) (LOGICAL)
50GB NTFS (DATA DUMP) (LOGICAL)
Installation Fails Every time for UBUNTU/FEDORA/SUSE
Ive LOST count how many times i've tried in 3 Days
here GRUB Fails .......................
BUT When I've tried This
232.88
2GB PRIMARY SWAP (LINUX)
26GB PRIMARY EXT3 (LINUX)
161GB EXTENDED
All went OK
Can Any One tell me Why
Earlier Conditions
149GB
28GB PRIMARY NTFS (WINDOWS XPSP2)
121GB EXTENDED
2GB SWAP (FEDORA) (LOGICAL)
13GB EXT3 (FEDORA) (LOGICAL)
15GB NTFS (DUMP) (LOGICAL)
30GB NTFS (VDO) (LOGICAL)
30GB FAT32 (MP3) (LOGICAL)
31GB NTFS (DUMP) (LOGICAL)
HERe every Combination was possible
I've tried
XP & SUSE
XP & UBUNTU
XP & FEDORA 7/8
Old 28-11-2007, 02:12 PM   #9 (permalink)
praka123's Avatar
Linux installs fine on logical partitions.for u,if u can complete any install leaving the grub error,u can restore grub.yes.u can restore/reinstall grub via livecd.
praka123 is offline
Old 28-11-2007, 02:24 PM   #10 (permalink)
Come get Some
DukeNukem's Avatar
Ive tried it with Ubuntu
Installed it parallel to Win XP
After installing it, grub Fails
Then Tried to restore the Grub
grub-install /dev/sda1
But the Same error comes.
grub starts and fail in between
Old 28-11-2007, 02:27 PM   #11 (permalink)
praka123's Avatar
^that is not the way i mentioned.u can install grub natively if ur sure ur distro is installed on logical partn.
sorry for copypasting as am very slow in typing
read below thing:
http://www.gnu.org/software/grub/man...-natively.html
praka123 is offline
Old 28-11-2007, 03:14 PM   #12 (permalink)
Come get Some
DukeNukem's Avatar
read below thing:
THx will try this (when in trouble again, as for now thin's are settled)
fedora 7 installation problem .. ninad_mhatre85 Open Source 3 27-09-2007 10:32 AM
Tutorial Req : Installation Of Fedora 7 BBThumbHealer Open Source 11 11-07-2007 01:23 PM
Fedora 6 post installation problems cranky Open Source 5 05-03-2007 07:11 PM
copying vcds in linux ? Fedora Core 2 installation problems! Krazy_About_Technology Open Source 1 08-12-2004 12:00 AM
