Old 19-11-2007, 05:01 PM   #1 (permalink)
adi007's Avatar
Unhappy root password problem
I have forgotten my root password.
Now,I know that i can change the root password by using single user mode.But i don't want to chage the root password.Instead,I want to know the root password.Is it possible??
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 19-11-2007, 05:02 PM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: root password problem
No.AFAIK
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 19-11-2007, 05:14 PM   #3 (permalink)
adi007's Avatar
I beleive if one can change the root password,then one can know the exisiting root password in single user mode.But i don't know how??
adi007 is offline
Old 19-11-2007, 05:17 PM   #4 (permalink)
Think Zen.
ray|raven's Avatar
You cant.
When u start as single user mode it automatically logs you in.
There u can change ur password by supplying a new password.
But there's no way to know ur old one.
Why do u need to know anyways?
Regards,
ray
Old 19-11-2007, 05:20 PM   #5 (permalink)
adi007's Avatar
just curious to know whether i can know my old root password.
By the way,i know that the root password is encrpted in some file...Can't we decrypt the file containing root password??
adi007 is offline
Old 19-11-2007, 05:23 PM   #6 (permalink)
Think Zen.
ray|raven's Avatar
If you knew the exact algorithm they used and the key which might be a 64bit one then yea maybe ,
Dont even think of brute-force,u would have grand-kids before it broke
Regards,
ray
Old 19-11-2007, 05:24 PM   #7 (permalink)
adi007's Avatar
^^can u tell me where the root password is stored....
adi007 is offline
Old 19-11-2007, 05:27 PM   #8 (permalink)
Think Zen.
ray|raven's Avatar
/etc/shadow AFAICR.
Regards,
ray
Old 19-11-2007, 05:30 PM   #9 (permalink)
adi007's Avatar
^Thanks.Will try to hack...
adi007 is offline
Old 19-11-2007, 05:38 PM   #10 (permalink)
Think Zen.
ray|raven's Avatar
G'Luck
May the force be with you
Regards,
ray
Old 19-11-2007, 06:10 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
One can use john to view shadow files if he/she knows the root password.
sudo apt-get install john
And:
sudo john /etc/passwd
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-11-2007, 06:32 PM   #12 (permalink)
left this forum longback
praka123's Avatar
^but it wont work 100% with a good passwd
praka123 is offline
Old 19-11-2007, 06:34 PM   #13 (permalink)
Commander in Chief
Yeah at-least it can guess a bit
Harsh J
www.harshj.com
Old 21-11-2007, 12:26 PM   #14 (permalink)
adi007's Avatar
And:
downloaded john and used it but no result.
It's just mere guessing all the possibilites.I just ran it for 2 hrs and even then it was unable to find out.I think it is immpossible to detect good root password by this....
The one thing i liked int it was we can resume our search by using
 ./john --resume
and we can add custom rules
adi007 is offline
Old 21-11-2007, 12:27 PM   #15 (permalink)
praka123's Avatar
^yes,ofcourse
Description: active password cracking tool
john, mostly known as John the Ripper, is a tool designed to help systems
administrators to find weak (easy to guess or crack through brute force)
passwords, and even automatically mail users warning them about it, if it
is desired.
It can also be used with different cyphertext formats, including Unix's
DES and MD5, Kerberos AFS passwords, Windows' LM hashes, BSDI's extended DES,
and OpenBSD's Blowfish.
Homepage: http://www.openwall.com/john/
praka123 is offline
Old 21-11-2007, 12:29 PM   #16 (permalink)
adi007's Avatar
Default root password problem
I just did some R&D on shadow file.
I think the password is encrpted under MD5 algorithm or Blow fish.
So is there any software that converts the md5 encrpted or blow fish encrpted text into decrpted text
And the second thing i noticed was
i just backed up the file shadow and changed my root password.I again changed the root password to the first one.Now i compared the backed up file with shadow file and noticed that the two encrypted text are not same..
Even though the password is same,the encrpted text was not same.
Will that means it is taking time consideration also
adi007 is offline
Old 21-11-2007, 12:31 PM   #17 (permalink)
praka123's Avatar
^that is hard.afaik it will take yrs to crack a really good passwd that too not for sure
praka123 is offline
Old 22-11-2007, 12:13 PM   #18 (permalink)
adi007's Avatar
no reply to this
adi007 is offline
Old 22-11-2007, 02:09 PM   #19 (permalink)
Commander in Chief
LMAO, no software exists to do that, it'd take years to decrypt on a very fast computer! If decrypting MD5 were so easy, Raaabo would already know all our passwords.
And even after years, the final string would just be *near* to the actual one. No way to guess what it was exactly.
And about MD5 Hashes, you do know collisions in hash tables right? Read on: http://www.mathstat.dal.ca/~selinger/md5collision/
Harsh J
www.harshj.com
Old 22-11-2007, 07:27 PM   #20 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
yea man these hashing algorithms are pretty good.They are almost perfect specially md5hash(thats why it is so much used).
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 22-11-2007, 07:43 PM   #21 (permalink)
yeah thats MD5 hash used in linux to store password,
Check out wikipedia , we hav encryption in our syllabus this sem.
A seed is required to make 128 bit hash and depending upon keys and S functions ur password will vary considerably(cascading effect) even for one letter difference.
Brute force is the only way to decrypt and it will take ages to get password. If u remember the hash is in hex.
Faun is offline
Old 22-11-2007, 08:03 PM   #22 (permalink)
praka123's Avatar
so that means md5hash is broken
praka123 is offline
Old 26-11-2007, 05:19 PM   #23 (permalink)
adi007's Avatar
Is there no way that an md5 encrpted string can be decrypted...
But how does linux decryptes it and check whether the entered password is right or wrong...
I think there must be some method to decrpt the encrpted md5 string...
adi007 is offline
Recover Root password piyushp_20 Tutorials 1 05-07-2007 02:58 PM
Root password ra_sriniketan Software Q&A 4 15-11-2005 12:58 PM
Root password godsownman Open Source 5 01-08-2005 03:38 PM
Root Password godsownman Software Q&A 5 13-07-2005 08:59 AM
FORGOTTEN ROOT PASSWORD cool_techie Open Source 6 23-03-2005 11:27 AM
- by soumya
