Old 18-11-2007, 12:17 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Problem playing DVD video in ubuntu
Playing vcds is fine but whille playing DVD videos i got small thick lines along with the video in case of totem. Same is the case with VLC player. In windows the video playback is fine except the same problem while playing with VLC player. Is there some problem open source player in playing DVD videos ??
Tried it on my friends system (with ubuntu) same problem.Any solution plz
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 18-11-2007, 12:19 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Problem playing DVD video in ubuntu
Try installing ubuntu-restricted-extras package and mplayer
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 18-11-2007, 12:25 PM   #3 (permalink)
in search of myself
CadCrazy's Avatar
what. I have installed Gstreamer-ugly,bad(also multiverse)and ffmpeg as mentioned in ubuntu user guide.
Unban Praka123
CadCrazy is offline
Old 18-11-2007, 12:30 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try installing MPlayer and check if that one plays it well or not. VLC sometimes is just not the solution
sudo apt-get install mplayer
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-11-2007, 01:28 PM   #5 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Problem playing DVD video in ubuntu
vlc gives problem sometimes, you could also try xine player.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 18-11-2007, 02:17 PM   #6 (permalink)
in search of myself
CadCrazy's Avatar
Heres the screenshot
http://cid-382ddf3833ef404c.skydrive...Screenshot.png
Unban Praka123
CadCrazy is offline
Old 18-11-2007, 02:21 PM   #7 (permalink)
[xubz]'s Avatar
Thats Interlace Problem! Try a different DVD! (or see whether some 'De-Interlacing' is possible)
[xubz] is offline
Old 18-11-2007, 02:47 PM   #8 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
There is de-interlacing option in Totem Movie player,just press I during video playback or view->deinterlace.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 18-11-2007, 03:05 PM   #9 (permalink)
in search of myself
CadCrazy's Avatar
The deinterlacing is also not helping
But the same dvd is playing fine in windows
Unban Praka123
CadCrazy is offline
Old 18-11-2007, 05:39 PM   #10 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ You tried mplayer with w32codecs?
kalpik is offline
Old 18-11-2007, 05:59 PM   #11 (permalink)
in search of myself
CadCrazy's Avatar
Not yet. But the problem is solved to sum extent after choosing deinterlace option in VLC player. How to enable deinterlace option by default ? Is there any disadvantage of doing so as it is not enabled by default
Unban Praka123
CadCrazy is offline
Old 18-11-2007, 07:04 PM   #12 (permalink)
TheSaint
NucleusKore's Avatar
Change the output renderer if possible
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 18-11-2007, 08:23 PM   #13 (permalink)
left this forum longback
praka123's Avatar
did u sudo apt-get install libdvdcss2?it solves.for all players make sure xv(ideo) is used.
praka123 is offline
No audio while playing DVD-Video in WMP krazzy Software Q&A 2 13-11-2007 05:28 AM
problem while playing 3gp video in 7610 clmlbx Buying Advice 7 16-07-2007 03:36 PM
XP Hangs on playing video patkim Software Q&A 2 15-04-2007 11:49 AM
video not playing.. herc Software Q&A 8 05-03-2007 01:40 PM
- by soumya
