15-11-2007, 11:23 AM
Ubuntu Problem
I got shipped Ubuntu cd's yesterday.I installed it.As all are aware there is a lack of multimedia support in Ubuntu.Now i want to make Ubuntu full multimedia ready.
The main problem is
I DONT HAVE AN INTERNET CONNECTION
I just recently downloaded some packs from the internet cafe.But it had dependices and i am unable to install it.
I tried all the linux softwares provided in the DIGIT.But in vain.All of them had dependices of one or the other package.
I tried googling but all the procedures required active internet connection for Ubuntu
So,please help me.Just give me the links of the packages that i should bring from internet cafe.
I could go to internet cafe and download packages.But it must be sure that the packages don't have any dependices
Apart from Ubuntu,i have opensuse 10.2,could any one suggest the solution for this also
15-11-2007, 11:31 AM
Think Zen.
Re: Ubuntu Problem
Here's an idea that might work.
Take the Ubuntu live cd to a net-cafe and boot from it.
Install all required packages in it.
The packages will be /var/apt/cache if i remember correctly.
Copy them into a USB drive and install back @ ur home.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
15-11-2007, 11:33 AM
Re: Ubuntu Problem
^^Not possible.I have to configure the internet settings then and defenitely cafe owner will not allow this.And more over majority of the systems in cafe are having 128 mb ram,So the live cd will work very very slow....And under this condition browsing and downloading is not possible.
15-11-2007, 11:47 AM
God of Mistakes...
Re: Ubuntu Problem
Surely go for OpenSuSE. It is having most of the Multimedia codecs installed.
And as it is RPM based, there is very less problem of dependencies.
Only thing is that, u have to keep DVD with u or copy it on ur HDD.
I've used OpenSUSE when I was not having internet connection @ home.
15-11-2007, 11:51 AM
Re: Ubuntu Problem
^^ didn't understand??
Open suse has codec only for mp3.But not for DVD,VCD.DIVX,WMA....and rpm files are difficult to install in Ubuntu.You have to convert them to .deb and there is very less chance that it will work.
Has Ubuntu shipped with rpm converter...
15-11-2007, 11:55 AM
Think Zen.
Re: Ubuntu Problem
The RPM Convertor is called Alien.
But it is not advisable to use it as sometimes packages are modified to suit the distro.
I'd suggest u try for Linux Mint.
Its ubuntu+codecs and drivers installed.
So u shudnt find any problems.
Regards,
ray
15-11-2007, 11:56 AM
God of Mistakes...
Re: Ubuntu Problem
I mean, Install OpenSUSE instead of Ubuntu !
15-11-2007, 11:57 AM
Re: Ubuntu Problem
^^I tried linux mint and it's good.But i want to use ubuntu now and enable it to become multimedia ready.I just wonder what if the digit gives all the packages required to enable multimedia in Ubuntu or even better customised multimedia ready Ubuntu
15-11-2007, 11:59 AM
God of Mistakes...
Re: Ubuntu Problem
If u want to use Ubuntu only, then try Ubuntu Ultimate.
15-11-2007, 12:03 PM
Re: Ubuntu Problem
i have both of them installed.
Open suse full installed --8GB(took 3 hrs to install) but even then only support for mp3
Ubuntu --2GB
nothing i can do to make this ubuntu multimedia ready without internet connection ????
Regarding Ubuntu Ultimate, i have to download it...   ..That too 700+ MB from outside.Defenitely not possible
Reason: Automerged Doublepost
Think Zen.
Re: Ubuntu Problem
Hmm,Well then u'd better ask someone here who uses Ubuntu(Must be using same version) to install all the codecs and then upload the file for you.
u can then download it and install the codecs.
Or i remember synaptic having an option to generate download links of selected packages,(Dont remember well,kinda used ubuntu long back)
In that case u can ask someone for the list and download the packages urself.
Alternatively,if the version of mint is same as the ubuntu version u are using u can use the cd to install the packages(If the mint cd is an alternative cd) as basically mint uses Ubuntu core.
Regards,
ray
15-11-2007, 12:05 PM
God of Mistakes...
Re: Ubuntu Problem
dude... it's more than 3 GB.
It is not available in CD. U have to download DVD. BTW, where is this hassan ??
15-11-2007, 12:08 PM
Re: Ubuntu Problem
The linux mint version that i have is old when compared to Ubuntu
and
^^ i would be happy if anyone make the list....
It is available in CD.link here
http://ubuntusoftware.info/Ubuntu_Ultimate_CD/
Hassan is in Karnataka near mysore..
15-11-2007, 12:10 PM
God of Mistakes...
Re: Ubuntu Problem
@Adi007,
can u please tell, where u live? I can send u an Ubuntu Ultimate DVD.
15-11-2007, 12:13 PM
Re: Ubuntu Problem
One thing is sure.If u don't have internet connection then Ubuntu is as good as dead...
15-11-2007, 12:16 PM
God of Mistakes...
Re: Ubuntu Problem
DON'T POST ADDRESS and ur details here...
Edit the post and remove it.
PM me..
15-11-2007, 12:27 PM
Re: Ubuntu Problem
private message sent..
I heard that there are some scripts called AUTOMATIX which makes the distro multimedia ready ??
Is there a offline version of it..?
have to go now..
Will be back at 1PM
15-11-2007, 12:30 PM
Think Zen.
Re: Ubuntu Problem
There are scripts called Automatix and EasyUbuntu that help you to install packages to make the distro ready for use.
But they only do the work for u by selecting the packages to be installed.
You need a working internet connection for those.
Besides they are known to break installs,
so better stay away from them.
Regards,
ray
15-11-2007, 01:14 PM
#19 (permalink)
Commander in Chief
Re: Ubuntu Problem
Aw man, just download the DEBs from Ubuntu's software pool along with the required and listed dependencies and be done with it
Harsh J
www.harshj.com
15-11-2007, 04:48 PM
#20 (permalink)
Techtree Reviewer
Re: Ubuntu Problem
How long does it take for the Ubuntu cd to get shipped here? The site says it can take upto 10 weeks. Does it really take that long? Also is it totally free. I want to get a disc too.
15-11-2007, 04:50 PM
#21 (permalink)
Commander in Chief
Re: Ubuntu Problem
I ordered like a week before its release and got it a week earlier than today. Wait, that'd be um, Order on - 12th October and I got it on 9th in the Wave 2 shipments. 1 Kubuntu CD + 1 Ubuntu CD. ( Just one is sufficient though it had options of 2 and 10  )
So yeah its like 4 weeks for me and its totally free as mentioned.
Harsh J
www.harshj.com
15-11-2007, 05:00 PM
#22 (permalink)
Re: Ubuntu Problem
it's not so easy.There are lots of dependencies for a single DEB and finding it is difficult.And since i have no internet connection ,it will be very difficult....It would take a lot of time and money.
If you could give me the list of files which are required ,then it will be easy...
15-11-2007, 05:12 PM
#23 (permalink)
Commander in Chief
Re: Ubuntu Problem
Harsh J
www.harshj.com
15-11-2007, 05:20 PM
#24 (permalink)
Re: Ubuntu Problem
^^from your mentioned thread..
libgstreamer-plugins-base0.10-0
libgstreamer-plugins-base0.10-dev
libgstreamer-plugins-pulse0.10-0
libgstreamer0.10-0
libgstreamer0.10-0-dbg
libgstreamer0.10-dev
libgstreamer0.10-ruby1.8
gstreamer0.10-plugins-base
gstreamer0.10-plugins-base-apps
gstreamer0.10-plugins-base-doc
gstreamer0.10-plugins-good
gstreamer0.10-plugins-good-dbg
gstreamer0.10-plugins-good-doc
gstreamer0.10-plugins-ugly
gstreamer0.10-plugins-ugly-multiverse
gstreamer0.10-plugins-bad
gstreamer0.10-plugins-bad-multiverse
gstreamer0.10-fluendo-mp3
gstreamer0.10-ffmpeg
gstreamer0.10-pitfdll
gstreamer0.10-doc
gstreamer0.10-alsa
gstreamer0.10-esd
gstreamer-tools
gxine
libxine-main1
libxine-extracodecs
ogle
ogle-gui
and their dependices
That means i have to download these and test in my system and have to go to cafe again to saisfy the dependices.And i think the same thing will be repeated again and agian   :
And by the way what does this mean
Q2: Their totally bugging out on me dude. Their saying that I need this dependecy and that dependency is saying I need this dependency. What do I do if they need each other to install itself?
A: Smart question. They way you go about doing this is that you have to install them through the terminal. Type in sudo dpkg -i /whatever/whatever to install manualy. then do the same for the other package. then go into the synaptic package manager and uninstall something. (Make sure that you don't uninstall anything inportant or something that will uninstall more things.) this will configure your two packages Then reinstall the package you uninstalled. Then your done.
Source
http://ubuntuforums.org/showthread.php?t=389149
15-11-2007, 05:27 PM
#25 (permalink)
Commander in Chief
Re: Ubuntu Problem
He probably means dpkg --configure -a for fixing dependencies. His method is silly though.
Well, do you have ANY friend with a net access? Use APTonCD there and make a disc?
Just hold on a minute, let me boot up a Live CD and run the command and give you the list. If I got time I'll make a linked line as well.
Harsh J
www.harshj.com
15-11-2007, 05:54 PM
#26 (permalink)
Techtree Reviewer
Re: Ubuntu Problem
Where do you stay in india? Would it be faster for me since i'm in Mumbai?
15-11-2007, 05:57 PM
#27 (permalink)
D i s t i n c t l y Ahead
Re: Ubuntu Problem
offtopic: Dude how u ordered for 1 Kubuntu CD + 1 Ubuntu CD ? have u given some special request ?
15-11-2007, 06:11 PM
#28 (permalink)
Commander in Chief
Re: Ubuntu Problem
@saurabh kakkar - I ordered a CD from Ubuntu's ShipIt and a CD from Kubuntu's ShipIt on the same day.
@krazyfrog - I think Mumbai gets it first, perhaps even Wave 1 reaches there.
And now the log of apt:
ubuntu@ubuntu:~$ sudo apt-get install ubuntu-restricted-extras
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
libfaad2-0 libxvidcore4 libmp4v2-0 libx264-54 libfaac0
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
flashplugin-nonfree gcc-3.3-base gstreamer0.10-plugins-ugly-multiverse
java-common libfaac0 libfaad2-0 liblame0 libmp4v2-0 libstdc++5 libx264-54
libxvidcore4 odbcinst1debian1 sun-java6-bin sun-java6-jre sun-java6-plugin
unixodbc unrar
Suggested packages:
konqueror-nsplugins msttcorefonts ttf-xfree86-nonfree xfs equivs
binfmt-support sun-java6-fonts libmyodbc odbc-postgresql libct1
Recommended packages:
gsfonts-x11 gstreamer0.10-plugins-ugly gstreamer0.10-plugins-bad
gstreamer0.10-plugins-bad-multiverse gstreamer0.10-ffmpeg libdvdread3
The following NEW packages will be installed:
ubuntu-restricted-extras unixodbc unrar
0 upgraded, 18 newly installed, 0 to remove and 24 not upgraded.
Need to get 34.9MB of archives.
After unpacking 99.9MB of additional disk space will be used.
Note that Java, though included in Ubuntu-Restricted-Extras, isn't necessary for codecs.
Harsh J
www.harshj.com
15-11-2007, 06:18 PM
#29 (permalink)
Wire muncher!
Re: Ubuntu Problem
Yes, it takes at least one month. Its totally free.
15-11-2007, 06:26 PM
#30 (permalink)
Techtree Reviewer
Re: Ubuntu Problem
Just placed a request for 1 cd. Hope it arrives soon.
