15-11-2007, 09:39 AM
Tribal Boy
Running Ubuntu in your laptop ? Have a look at these posts
This topic is discussed in Ubuntu bug report section, Linux Hero and in Orkut.
Anyway nothing to worry as the solution/details/updates are given by the author himself.
So here it goes
A recent bug report for Ubuntu Linux has confirmed that both the Feisty and Gutsy versions of Ubuntu cause some unnecessary wear and tear on a hard drive.
From same guy
EDIT: This problem seems to be limited to laptop mode. Read This if you want to see how to tell if you're affected.
So let me put this out there in capital letters, because I NEVER wanted any semblance of bad publicity for Ubuntu. UBUNTU DOES NOT OVERWORK YOUR HARD DRIVE UNLESS IT IS IN LAPTOP MODE.
So which articles gives more info and solution ?
1. Bug report details
2. Explanation of Ubuntu Hard Drive Wear and Tear
3. Ubuntu Hard Drive Explosions
And in my case, the grep ENABLE_LAPTOP_MODE /etc/default/acpi-support command returned false  So I guess nothing to worry.
Solution
Just a single line edit is the solution ! Isn't it pretty easy and simple ?
How can you tell if your machine is in laptop mode? Easy.
Type in terminal
sudo grep ENABLE_LAPTOP_MODE /etc/default/acpi-support
If the returned value is false (just like in my case), nothing to worry, no need to change even a single line !
If the returned value is true, your machine is in laptop mode and you may wish to alter your power management settings accordingly. I have not tested this, however I imagine you can choose a less aggressive number in the aforementioned script /etc/acpi/power.sh at the line that reads:
<code>$HDPARM -B 1 /dev/$drive 2>/dev/null</code>
When doing so, keep in mind that 255 completely disables power management, and 1 is the most aggressive setting. Find a happy medium that works for your laptop if you’re interested in striking a balance between battery life and hard drive longevity.
15-11-2007, 07:04 PM
left this forum longback
Re: Running Ubuntu in your laptop ? Have a look at these posts
yeah.its posted here already and the problem was(?) for laptop users.
15-11-2007, 07:08 PM
Tribal Boy
Opps sorry, I saw the discussion in Orkut, but thought no one here knew. Yes, it is for laptops only.
15-11-2007, 07:13 PM
GaurishSharma.com
sigh...
firstly i thought is was for desktops also.
i thought was my unichrome card is giving me a lot of problems and now comes other bug too
15-11-2007, 07:17 PM
@gary:get a nvidia card and give al-vida to these via onboard cr@p
15-11-2007, 08:38 PM
Rubik's Uncle!!
What this is been discussed in Orkut!!! :O .. I thought Orkut was only for flirting ( not me  )
EDIT: ok here is some thing from me .. I use a HP laptop but havent installed any Linux on that it has vista preinstalled. I use Sabayon linux DVD and run it live. everything works just fine.. the problem comes when I try to shutdown... err.. it doesnot shutdown at all .. I have to use the restart option and then manually press powerbutton for 5 seconds for turning off the lappy. Each time I do this .. during next vista boot I get a BSOD  .. I still cannot say if the problem is from sabayon. This happens every time when I try to shutdown.
Reason: Automerged Doublepost
15-11-2007, 09:02 PM
Tribal Boy
LOL
OK, Orkut has a group, I think Kerala Linux Club. Prakash, myself etc are members. The topic was posted by one of my friends there.
15-11-2007, 09:18 PM
Damn, I wanted to install 7.10 on my laptop, guess it would be sabayon then
15-11-2007, 09:28 PM
Rubik's Uncle!!
^^^ mohit .. read the links yar... always understand what the problem is and later decide.. posts here are just guidelines/alerts about the problems.. Even the answer is provided on how to avoid this..
15-11-2007, 09:30 PM
Tribal Boy
@kumarmohit
The fix (if the above command gives "true" as output) is very very simple and explained in the links. So please go ahead, nothing to worry. I love running Ubuntu in my lappy.
15-11-2007, 10:00 PM
i remember the article somewhere which states this problem will be there for windows series including vista or a mac also! also other Linux distros too.  but will not be noticed or researched by any unlike Linux community which finds such problems.Community rocks!
BTW,thanks for the last link.
15-11-2007, 11:38 PM
Wire muncher!
Yes, its true all OSs haf this problem. However, the damage depends on the extent to the frequency of read-writes by the OS. Not a problem to worry about. Go ahead and install Ubuntu
15-11-2007, 11:43 PM
^actually it is like {bcoz of hdd manufacturers(?) } do u want better battery life with hdd life reduced or good hdd life with low battery time.  solution is to fiddle with hdparm values.i hope Linux community will come up with some solution as no bios update or nothing of that sort will be supported by h/w people.
15-11-2007, 11:49 PM
Wire muncher!
Hey using hdparm the APM settings can be set to any value and this solves all the problems, if any
16-11-2007, 09:07 AM
Tribal Boy
Exactly
hdparm -B 255 /dev/sda
Done !
OK, To avoid further confusion, I am adding the solution (rip off from source -lol) in the first post.
16-11-2007, 02:11 PM
@kumarmohit
Teh only thing is that I do not want to make the effort, you see
if I can get a ready made solution in Sabayon, why bother!
16-11-2007, 06:01 PM
Tribal Boy
LOL, ok
I thought you want Ubuntu but worried on this issue.
16-11-2007, 11:13 PM
Darth Penguin
Does the same apply for Kubuntu 5.something? I've got a disk of that lying somewhere, i can always install that instead.
The Force. It surrounds us. It enfolds us. It gets us dates on Saturday Nights.
16-11-2007, 11:23 PM
#19 (permalink)
^what applies  the problem occurs only if u enable aggressive power management and that is in laptop mode.default install will not have any problems.
17-11-2007, 07:13 AM
#20 (permalink)
Tribal Boy
@Cyclone
I regret for posting this thread now !!! LOL
I think people get scared and confused. Nothing so serious about it, and evenif the laptop mode is enabled or power management settings is changed, just a single line command will make it ok
So do not worry at all, go ahead and install Ubuntu.
17-11-2007, 11:12 AM
#21 (permalink)
GaurishSharma.com
@Din
I accuse you of misleading people & force them believe that Ubuntu cause wear and tear HDD's.
Hence you are stopping them to install Linux.
so you you guilty of cheating,lying, 3rd degree fraud,havoc to the online community,knowingly committing crime hereby you are punished under Ubuntu penal code(UPC) of section 6.06,7.04,7.10 which gives you a death sentance but the as you are regret your crime. your punishment is reduced to life sentence.
Whole of your life you will remain in custody of Ubuntu linux.
17-11-2007, 11:54 AM
#22 (permalink)
^^ Hey Guyz, If you are fighting coz decided to switch from Ubuntu to Sabayon, please note that Sabayon is a Linux distro based on Gentoo, which is more Linuxy than Debian, on which Ubuntu is based.
OK- Not That I think you guys do not know it, but sorry, couldn't resist!
17-11-2007, 04:05 PM
#23 (permalink)
Wire muncher!
Hehe.. Gaurish is the new judge at OSS Supreme Court!
Nothing to worry guys. Its not a problem
17-11-2007, 04:25 PM
#24 (permalink)
Debian base is better any time.but thats my personal opin
hence Ubuntu too!bcoz of ubuntu,ubuntuforum gaves ur most linux problems an answer.the community everything rocks!Ubuntu made a change in linux world.admit that.
17-11-2007, 11:48 PM
#25 (permalink)
Hey I said Gentoo is more linuxy, not better. I think both are at par when it comes to all the concepts of being a better OS
18-11-2007, 12:54 AM
#26 (permalink)
@Din,
Thank you for spreading absolutely snip. Why don't you do some REASEARCH before copy pasting your senseless crap here in the forums, hence discouraging the few users who are migrating to linux ?
This problem is NOT CAUSED BY, AND NOT LIMITED TO UBUNTU ! This problem affects all other distros, and windows, this is a hard drive and laptop MANUFACTURER problem !
Please read http://mjg59.livejournal.com/77672.html for proper information, and Din, use GOOGLE to verify "facts" before posting !
18-11-2007, 01:36 AM
#27 (permalink)
18 Till I Die............
rohandhruva please mind your language, this isn't the first time you're doing it.
http://www.bash.org/?258908
18-11-2007, 01:40 AM
#28 (permalink)
Originally Posted by mehulved
rohandruhava please mind your language, this isn't the first time you're doing it.
Hard to do .. It irritates me when people spread FUD without researching .. It takes a few minutes to verify a story, before posting. And you can see for yourself what negative effect it had !
Anyway, I'm sorry.
Also, please copy paste the nick name, if you can't spell it right. Thank you.
18-11-2007, 11:31 AM
#29 (permalink)
Hmm if this is with all ditros guess it wud be BSD variant then!
LOL no guyz, I think that I shud research in this matter myself before I do anything else
18-11-2007, 03:08 PM
#30 (permalink)
GaurishSharma.com
Damm..if thing if going else where
i was joking, sorry din if it hurt you
