Old 06-11-2007, 10:59 PM   #1 (permalink)
harryneopotter's Avatar
Default Digit Nov Open Suse Prob...plz help
Hi friends .... today i got the Nov issue of digit and installed Open suse from it. It doesnt have Drivers for my Onboard GRFX Nvidia 6150 (M2NPV VM) .. Now i got LINUX DRIVERS on the MOBO Cd ....but i cant run the file which is named
"NFORCE-Linux-x86-1[1].0-0311-pkg1.run" ....
plz tell me how to execute it ..... and also tell which to install 32-bit or 64-bit drivers ?
I am on 64 kbps net connection ... so plz dnt suggest to download online ...
HELP PLZ ...
harryneopotter is offline
Old 06-11-2007, 11:05 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Digit Nov Open Suse Prob...plz help
Don't panic, you will have to download the drivers. Its a very small file, quite manageble on your 64 kpbs connection. Visit this link and do the one click install, you'll see how fast and easy it is
http://en.opensuse.org/NVIDIA
NucleusKore is offline
Old 06-11-2007, 11:08 PM   #3 (permalink)
let me try ......thnx.........
need Open SuSE 10.2 DVD Garbage Open Source 9 15-07-2007 08:08 PM
Java IDE for Open Suse 10.2 ilugd Open Source 5 27-05-2007 08:55 PM
prob wid suse 10.2 installation varunprabhakar Open Source 5 26-02-2007 03:35 PM
Open SuSE 10.1 update NucleusKore Tutorials 1 20-10-2006 04:11 PM
Prob in installing SuSE 9.0 N FC 3 ashu283 QnA (read only) 1 15-02-2005 08:33 AM
- by soumya
