Old 06-11-2007, 08:51 PM   #1 (permalink)
Default problems with sound on ubuntu
hi,
i recently installed linux(ubuntu 7.04) and i have the following problem:
i have an intex sound card and it doesnt work always on linux.it usually works after 1 or 2 restarts.the sound icon has now dissappeared from the bottom right corner.can anyone help me.thanks
even my broadband connection(bsnl) does not work always
raviramgopal is offline
Old 06-11-2007, 08:54 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: problems with sound on ubuntu
try installing new drivers..
http://twitter.com/akshayms
nvidia is offline
Old 06-11-2007, 08:56 PM   #3 (permalink)
left this forum longback
praka123's Avatar
please refer open source section.alsa most prolly autodetects ur sound card.check that in BIOS if anything can be done to disable ur onboard sound card.if not,u can blacklist the onboard soundcard module from loading.even better give some details about intex sound card what chipset does it uses?
regarding adsl connections esp dataone,there is sticky in open source section which can help you.u need a lan card which ur mobo already may have to establish a pppoe connection.ask a mod to move this to open source section.there your question get more attention.
this is Linux dude
praka123 is offline
Old 06-11-2007, 11:00 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
More information about the soundcard would be helpful. Plz post the output of the command: lspci
Issue that command in a terminal window (Apps > Accessories > Terminal)
infra_red_dude is offline
Old 07-11-2007, 05:28 PM   #5 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Im fairly new to Ubuntu so Ill explained my dilemma I faced. I had problems with sound and had to recompile alsa for it to work. In your case that might not be the case though. Theres a Ubuntu sound FAQ on the site. Since Im on dialup I really prefer to not look for it. but just search on the site for Sound troubleshoot and it should bring up two troubleshooting threads labelled with [HOW TO]. Hope this helps somehow.
FilledVoid is offline
Sound problems with laptop swap_too_fast Software Q&A 1 24-10-2007 07:34 PM
[Ubuntu Fiesty 7.04] Sound Problems Maverick340 Open Source 13 05-08-2007 03:42 PM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
Sound problems !! hittheswitch Open Source 1 10-05-2005 02:56 PM
- by soumya
