Old 04-11-2007, 08:59 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Lots Of Problems: Ubuntu 7.10/6.10 Installation on old system
I tried to install Ubuntu 7.10 on my friend's system with following Configuration
P4 3.00 GHZ, Intel 845G Mobo, 256 Mb Ram, 80 Gb IDE HDD.
Ubuntu main screen not loaded from live cd. System just freezed after ubuntu loading progress bar disappeared. I rebooted the system and this time i waited for ubuntu main screen to load. After odd 45 mins i got the screen n the shortcut to install. Clicked on it again the waiting session started. After around i had to reboot again as nothing seem to happen.
This time i choosed install in safe graphics mode. After the warning window(configure resolution) i clicked next n again black screen but this time with blinking cursor. Waited for long time and rebooted again.
I checked cd for defects and to my surprise it was ok.
Then i tried to install 6.10. Choosed default option to install ubuntu. Again progress bar came, disappeared and blank screen but this time with blinking
monitor light and nothing more.
Finally i choosed install in safe graphics mode in 6.10. This time i managed to install it . Now when i choose to boot from default option same thing happens again i.e. blank screen after progress bar with blinking cursor. It take some 3 0r 4 min to display login screen. But if boot in recovery mode then i type "exit " @ command prompt to start the graphics mode which is now only good way to srart UBUNTU 6.10
I have heard that 7.10 can work on 256 ram without any problem but here even 6.10 is not working properly. Also I am not getting the widescreen resolution 1680X1050. The maximum resolution i am getting is 1024x768. I installed 915resolution package to enable widescreen resolution on older intel chipsets but still not getting it. Also graphics performance is not so good.
I convinced my friend that 7.10 is way better than windows. Help me save my face. Please..................
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 04-11-2007, 09:17 PM   #2 (permalink)
18 Till I Die............
Default Re: Lots Of Problems: Ubuntu 7.10/6.10 Installation on old system
Use alternate install cd, live cd requires min. 512mb of RAM. And go for Xubuntu rather than ubuntu.
http://www.bash.org/?258908
mehulved is offline
Old 04-11-2007, 10:12 PM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Do you have a AsRock MoBo? I also have that brand's mobo with AGP and it stucks with the AGPGART of any new Linux Distro.
If you want to know about AGPGART solution, then specify it in reply post.
debsuvra is offline
Old 04-11-2007, 10:31 PM   #4 (permalink)
in search of myself
CadCrazy's Avatar
No its intel mobo
yes wana know more
Ok but also tried on another friend's system with AMD 3000+,ASUS M2N Mobo,512 MB Ram but almost same thing happened
No No can't do without eye candy
Unban Praka123
CadCrazy is offline
Old 04-11-2007, 10:52 PM   #5 (permalink)
What do you mean? What more eye candy will GNOME give over XFCE, specially with just 256MB of RAM?
mehulved is offline
Old 04-11-2007, 11:10 PM   #6 (permalink)
in search of myself
CadCrazy's Avatar
i have heard that it is very light on resources with less eye candy
Unban Praka123
CadCrazy is offline
Old 04-11-2007, 11:22 PM   #7 (permalink)
http://xubuntu.org/tour
http://xubuntu.org/press#screenshots
http://www.xfce.org/about/screenshots
http://lunapark6.com/overview-of-xfce-44.html
Just a few examples. Google can show you more about the how good XFCE can look while using less resources.
mehulved is offline
Old 04-11-2007, 11:35 PM   #8 (permalink)
quantum's Avatar
i dont think RAM is sufficient enough for GNOMe 2.2 if u can get your friend an older version like 6.06 with the repositories
quantum is offline
Old 04-11-2007, 11:49 PM   #9 (permalink)
UbuntuUser
cynosure's Avatar
6.06 will work fine, its will be supported for 5 years. Go for it if you want to install ubuntu. 7.0x will need atleast 512MB RAM.
cynosure is offline
Old 05-11-2007, 12:02 AM   #10 (permalink)
in search of myself
CadCrazy's Avatar
I currently installed Ubuntu 6.10 on his system . Tell me how to enable 3d/transparency effects. I have searched in synaptic with word compiz and installed all the packages under the search but still i am not getting the compiz configuration manager.
Also even 6.10 is not working properly through default boot option. I had to boot through recovery mode to get it working. Any possible cause/solution to this problem
Unban Praka123
CadCrazy is offline
Old 05-11-2007, 09:00 AM   #11 (permalink)
6.10 won't have compiz fusion. But luckily it has beryl. But, what graphics chipset does it have? And believe me go for xubuntu over ubuntu.
mehulved is offline
Old 05-11-2007, 09:18 AM   #12 (permalink)
Think Zen.
ray|raven's Avatar
Gnome is so damn sluggish on 256megs,
Go for xfce dude.its a lot better considering the low RAM.
Besides you wont feel any loss of looks either.
But on 256 megs Ubuntu itself feels sluggish.
Try something based on slackware if u really want speed.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 05-11-2007, 09:21 AM   #13 (permalink)
in search of myself
CadCrazy's Avatar
Intel 845G
Oh XUBUNTU haf to downlod it .
Unban Praka123
CadCrazy is offline
Old 05-11-2007, 09:26 AM   #14 (permalink)
Think Zen.
ray|raven's Avatar
Nah,Xubuntu isnt much but Ubuntu base with a set of apps for lower end machines,
Install Ubuntu and then remove
ubuntu-desktop and install
xubuntu-desktop.
Might be wrong names,used ubuntu quite some time ago.
Regards,
ray
Old 05-11-2007, 09:30 AM   #15 (permalink)
in search of myself
CadCrazy's Avatar
is it
install xubuntu-desktop and then remove ubuntu-desktop
or vice versa
Unban Praka123
CadCrazy is offline
Old 05-11-2007, 09:34 AM   #16 (permalink)
Yeah. xubuntu-desktop should be around 50MB package at the max. So, you can add it to your ubuntu install and thus have both GNOME and XFCE in the install.
mehulved is offline
Old 05-11-2007, 09:50 AM   #17 (permalink)
Think Zen.
ray|raven's Avatar
is it
or vice versa
I think if u select xubuntu-desktop for installation it automatically selects ubuntu-desktop for un-install.
Anyways its better to do this in init3 IMO.
Regards,
ray
Old 05-11-2007, 02:02 PM   #18 (permalink)
left this forum longback
praka123's Avatar
^No.all co-exists/be it kde or xfce(xubuntu)
praka123 is offline
Old 05-11-2007, 02:07 PM   #19 (permalink)
Think Zen.
ray|raven's Avatar
Yes,If you install the DE.
I think in Ubuntu only one desktop type package is available at once.
You can install the rest of the packages to make the DE available but if u install the desktop package its made the default DE and the previous Default DE is removed.
That's as i know in Ubuntu 6.06
Havent really used ubuntu after that.
Regards,
ray
Old 05-11-2007, 02:54 PM   #20 (permalink)
Proud to be Linux
abhinandh's Avatar
hey xfce is only a 14.3mb of download!!!
i have both gnome and xfce coexisting.
http://abhinandh.com
abhinandh is offline
Old 05-11-2007, 03:39 PM   #21 (permalink)
din
Tribal Boy
din's Avatar
Do not want to hijack this thread, but 256 + 512 (two RAM modules) MB Ram will be OK for Ubuntu 7.10 ? I mean smooth running of desktop version.
din is offline
Old 05-11-2007, 04:02 PM   #22 (permalink)
Think Zen.
ray|raven's Avatar
Hell yes.
What do u think Ubuntu is Vista?
For needing gigs of RAM
Ubuntu 7.10 should run smoothly with all compiz effects turned on.
Regards,
ray
Old 05-11-2007, 04:02 PM   #23 (permalink)
Regards,
ray
It shouldn't really do this but I believe it's a bug in gutsy which is causing this. AFAICR it was the person nicknamed slytherin on irc.freenode.net #ubuntu-in who had faced this too. Just try asking this there if anyone of you face it.
mehulved is offline
Old 05-11-2007, 04:11 PM   #24 (permalink)
Think Zen.
ray|raven's Avatar
Hmm,i dont know.
But i havent used gutsy.
Last i used ubuntu was version 6.06.
And i remember it selecting ubuntu-desktop for removal on selection of xubuntu-desktop for installation.
Might be wrong as it was some time ago.
Regards,
ray
Old 05-11-2007, 04:11 PM   #25 (permalink)
Wire muncher!
infra_red_dude's Avatar
More than enough!
Actually one of my fren runs 7.10 on 256MB DDR (some amount shared for vram), intel 865 comfortable widout compiz fusion. At least with the prev. release hafing GNOME 2.18, he was using beryl without much problems.
infra_red_dude is offline
Old 05-11-2007, 04:13 PM   #26 (permalink)
Commander in Chief
QwertyManiac's Avatar
Like rayraven said. 512 is just enough for a smooth experience. You can enable the Desktop Effects and get all the effects available too. (Depending on your Graphic Chipset)
And it'll all run smooth, right from startup to playing videos, etc and even Shut-down.
QwertyManiac is offline
Old 05-11-2007, 06:25 PM   #27 (permalink)
Hmm,i dont know.
Regards,
ray
I had xfcd + kde + gnome + ratpoison + fluxbox + xfwm + gnustep together on 6.10.
mehulved is offline
Old 06-11-2007, 10:01 AM   #28 (permalink)
in search of myself
CadCrazy's Avatar
So guys what you say Xubuntu 7.10 will work on system with 256 mb ram. I recently installed xubuntu-desktop on ubuntu 7.10 but it is still sucking. Take too long time to start.
Will the standalone xubuntu 7.10 be better or should i settle for some lower version of it .
Unban Praka123
CadCrazy is offline
Old 06-11-2007, 10:19 AM   #29 (permalink)
Think Zen.
ray|raven's Avatar
Ubuntu is a bit slow on 256 megs as i said before.
And a stock xubuntu install wudnt speed things much either.
If u want a really speedy boot go for a slackware based distro like Vector or Zenwalk.
Btw,did it select ubuntu-desktop for un-install on selecting xubuntu-dekstop for installation?
I'm kinda confused and a clarification would help.
Thanks.
Regards,
ray
Old 06-11-2007, 10:22 AM   #30 (permalink)
in search of myself
CadCrazy's Avatar
I am not sure as started installation in the night and found xubuntu installed in the morning
Unban Praka123
CadCrazy is offline
Lots of H.ware problems Keviv Hardware Q&A 4 22-05-2007 12:34 PM
Ubuntu 6.10 Installation from Hdd DukeNukem Open Source 3 02-03-2007 10:51 AM
Ubuntu installation help shaunak Open Source 8 27-09-2006 04:13 PM
Ubuntu Installation alltime.homie Open Source 10 11-09-2006 10:28 PM
Ubuntu Installation Problems adit_sen Open Source 13 10-08-2006 11:52 PM
- by soumya
